  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
107 Posts 10 Posters 72.8k Views 7 Watching
  • A ArcherS
    I have the same problem with the Tasmota bridge
    Regarding the Tasmota bridge it creates one device per Tasmota, i.e. no additional child devices as for the Shellies. These you instead need to create yourself by e.g. using the Virtual Sensor plugin.
    In this post you can find more on how I have done that.
    Did you try with Mqtt Explorer? It is a very good tool to see that the Mqtt devices, both Tasmota and Shellies are working as they should, and also to look at what they send.
    @archers said in MQTT – setup and use:
    Did you try with MqttBridge?
    Do you mean MQTT Explorer?
      ArcherS
      @akbooer yepp, edited that typo. 🙂
      • C Offline
        C Offline
        christian_fabre
        MQTT Explorer
        ![alt text](image url)Capture d’écran 2021-05-01 101054.png It seems that the Shelly plug is sending some info, as well as the Tasmota module
        Capture d’écran 2021-05-01 101546.png The Shelly and Tasmota bridges are well created, and that's it.
        See log file above
        • C christian_fabre
          MQTT Explorer
          See log file above
          @christian_fabre
          Try this: delete the Shelly bridge and restart openLuup.
          • C Offline
            C Offline
            christian_fabre
            ok i just did it.
            After starting OpenLuup, the Shelly Bridge is created ...
            I attach the log
            2021-05-01 10:40:39.029 openLuup.mqtt:: mqtt-explorer-8cd8e0cf SUBSCRIBE to # tcp{client}: 0x1a575f0
            2021-05-01 10:40:39.032 luup.create_device:: [82] D_ShellyBridge.xml / I_ShellyBridge.xml / D_ShellyBridge.json (ShellyBridge)
            2021-05-01 10:40:39.033 openLuup.context_switch:: ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
            2021-05-01 10:40:39.033 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
            2021-05-01 10:40:39.277 openLuup.server:: request completed (509175 bytes, 32 chunks, 994 ms) tcp{client}: 0x1a51f78
            2021-05-01 10:40:39.277 openLuup.scheduler:: [82] Shelly device startup
            2021-05-01 10:40:39.277 luup.set_failure:: status = 0
            2021-05-01 10:40:39.277 luup.variable_set:: 82.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: EMPTY now: 0 #hooks:0
            2021-05-01 10:40:39.278 luup.variable_set:: 82.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0
            2021-05-01 10:40:39.278 openLuup.scheduler:: [82] Shelly device startup completed: status=true, msg=OK, name=ShellyBridge
            2021-05-01 10:40:39.279 luup.shelly:0: New Shelly announced: shellyplug-s-20E453
            2021-05-01 10:40:39.279 openLuup.context_switch:: ERROR: [dev #0] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
            2021-05-01 10:40:39.279 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
            2021-05-01 10:40:39.280 openLuup.mqtt:: mqtt-explorer-8cd8e0cf SUBSCRIBE to $SYS/# tcp{client}: 0x1a575f0
            • C christian_fabre
              ok i just did it.
              I attach the log
              ArcherS
              @christian_fabre my Plug (not the S version) looks like this in Mqtt Explorer:
              For some reason there is no announce message from your plug when comparing with my plug.
              • C Offline
                C Offline
                christian_fabre
                I just redid a screenshot of MQTT Explorer
                My Shelly plug has just been plugged in (control of the swimming pool pump)
                I have the announcement message
                • C christian_fabre
                  ArcherS
                  @christian_fabre that is good news, then it looks as the Shelly works as it should in respect of the Mqtt settings.
                  Just to rule out the obvious; the Shelly devices and Tasmota devices should show up in OpenLuup in the two rooms "Shellies" and "Tasmota" and not in "No room".
                  Maybe deleting the Shelly bridge and reloading as @akbooer suggests now that you have the announce message.
                  • C Offline
                    C Offline
                    christian_fabre
                    I have removed several of the Shelly and Tasmota bridges. But after the Reload, they are created in NoRoom.
                    The last thing I did was reload the OpenLuup files from GitHub OpenLuup Development, but I still have the same problem
                    • C Offline
                      C Offline
                      christian_fabre
                      more
                      I notice that the variable OffSet is missing in the variables of the Shelly bridge
                      • C christian_fabre
                        ArcherS
                        Yes, the bridges are created in "No room", but the child devices should be created in the two rooms "Shellies" and "Tasmota" respectively.
                        • C Offline
                          C Offline
                          christian_fabre
                          The "Shellies" room is well created but it remains empty.
                          On the other hand, I have the Tasmota bridge in Noroom, but I do not have a "Tasmota" room
                          ![0_1619878068306_Capture d’écran 2021-05-01 160702.png](Uploading 100%!
                          • C Offline
                            C Offline
                            christian_fabre
                            • C christian_fabre
                              more
                              more
                              Yes, that’s undoubtedly the problem... have not been able to work on this today. Sorry.
                                Have you tried the latest release in the testing branch?
                                • C Offline
                                  C Offline
                                  christian_fabre
                                  I just tried the testing version.
                                  same problem
                                  2021-05-01 21:05:13.495 openLuup.io.server:: MQTT:1883 connection from 192.168.1.149 tcp{client}: 0x23a2148
                                  2021-05-01 21:05:13.530 luup.create_device:: [87] D_ShellyBridge.xml / I_ShellyBridge.xml / D_ShellyBridge.json (ShellyBridge)
                                  2021-05-01 21:05:13.531 openLuup.context_switch:: ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                  2021-05-01 21:05:13.531 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                  2021-05-01 21:05:13.533 openLuup.scheduler:: [87] Shelly device startup
                                  2021-05-01 21:05:13.533 luup.set_failure:: status = 0
                                  2021-05-01 21:05:13.533 luup.variable_set:: 87.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: EMPTY now: 0 #hooks:0
                                  2021-05-01 21:05:13.534 luup.variable_set:: 87.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0
                                  2021-05-01 21:05:13.534 openLuup.scheduler:: [87] Shelly device startup completed: status=true, msg=OK, name=ShellyBridge
                                  2021-05-01 21:05:13.535 luup.shelly:0: New Shelly announced: shellyplug-s-20E453
                                  2021-05-01 21:05:13.535 openLuup.luup:: creating room [10] Shellies
                                  2021-05-01 21:05:13.536 openLuup.context_switch:: ERROR: [dev #0] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                  2021-05-01 21:05:13.536 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                  2021-05-01 21:05:13.541 openLuup.server:: request completed (1033 bytes, 1 chunks, 609 ms) tcp{client}: 0x2222010
                                  2021-05-01 21:05:13.542 openLuup.context_switch:: ERROR: [dev #0] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    I should have time to address this tomorrow. Sorry for all the false leads (and the problem in the first place.)
                                    B 1 Reply Last reply
                                      B Offline
                                      B Offline
                                      Buxton
                                      @akbooer I hate to add more to the pile... but I'm still seeing a receive error for the connection to mosquitto. openLuup 2021.04.29b
                                      Here's the log error:
                                      2021-05-01 14:22:38.815   openLuup.io.server:: MQTT:1882 connection closed  tcp{client}: 0x5579919e9c58
                                      2021-05-01 14:22:38.816   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x5579919e9c58
                                      2021-05-01 14:22:43.935   luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x557990e7f528
                                      2021-05-01 14:22:48.435   luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x557990e7f528
                                      2021-05-01 14:22:49.763   luup.variable_set:: 10181.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1619904116 now: 1619904168 #hooks:0
                                      2021-05-01 14:22:50.158   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557991971ff8
                                      2021-05-01 14:22:53.834   openLuup.io.server:: MQTT:1882 connection from 127.0.0.1 tcp{client}: 0x5579920dc0b8
                                      2021-05-01 14:22:53.834   openLuup.mqtt:: client is in ERROR empty
                                      2021-05-01 14:22:53.834   openLuup.mqtt:: credentials is in ERROR empty
                                      2021-05-01 14:22:53.834   openLuup.mqtt:: subscriptions is in ERROR empty
                                      using the below error trapping in function "MQTTservlet"
                                        local function MQTTservlet (client)
                                      	if client == nil then
                                      	  _log ("client is in ERROR nil")
                                      	else
                                      	  	if table.concat(client) == "" then
                                      		_log ("client is in ERROR empty")
                                      		else
                                      	   _log (table.concat {"MQTT ERROR: ", table.concat(client)})
                                      	if credentials == nil then
                                      	  _log ("credentials is in ERROR nil")
                                      	else
                                      	  	if table.concat(credentials) == "" then
                                      		_log ("credentials is in ERROR empty")
                                      		else
                                      	   _log (table.concat {"MQTT ERROR: ", table.concat(credentials)})
                                      	if subscriptions == nil then
                                      	  _log ("subscriptions is in ERROR nil")
                                      	else
                                      	  	if table.concat(subscriptions) == "" then
                                      		_log ("subscriptions is in ERROR empty")
                                      		else
                                      	    _log (table.concat {"MQTT ERROR: ", table.concat(subscriptions)})
                                          return function () incoming (client, credentials, subscriptions) end
                                      I can't find a deeper layer in the stack where I can trap for the incoming message to see what's in the message that is throwing the error. As near as I can tell, if openLuup tries to connect to a running mosquitto instance, then it fails to see the topics and messages, and passes empty--but not nil--strings when the servlet interface sees incoming bytes.
                                      If I restart mosquitto, openLuup then sees the topics and messages and the error messages stop--and the connection to mosquitto remains stable.
                                      This behavior does not occur when I aim an IOT device directly at openLuup--in that the connection to the device always resumes when openLuup reloads--in other words, I don't need to restart the IOT device to enable the connection.
                                      • C christian_fabre
                                        same problem
                                        @christian_fabre
                                        I simply cannot reproduce this error, so can I ask you to try it again after having added this line to openLuup Startup (which enables debog logging for the MQTT server):
                                        luup.attr_set ("openLuup.MQTT.DEBUG", true)
                                        That may give a little more to go on.
                                        I've have tried everything I can think of, deleting the Shelly plugin, and reproducing the announce message from your device. It all works just fine.
                                        • C Offline
                                          C Offline
                                          christian_fabre
                                          I added "luup.attr_set (" openLuup.MQTT.DEBUG ", true)"
                                          and I did a RELOAD
                                          here is the log
                                          2021-05-02 14:03:57.914   openLuup.io.server:: MQTT:1883 connection from 192.168.1.149 tcp{client}: 0x11320b0
                                          2021-05-02 14:03:57.941   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.941   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.943   luup.shelly:87: New Shelly announced: shellyplug-s-20E453
                                          2021-05-02 14:03:57.944   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                          2021-05-02 14:03:57.944   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                          2021-05-02 14:03:57.945   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.946   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.947   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.947   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.949   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.949   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.989   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.989   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.994   openLuup.server:: request completed (664 bytes, 1 chunks, 1140 ms) tcp{client}: 0x1403478
                                          2021-05-02 14:03:57.995   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.995   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.997   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.997   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.998   openLuup.context_switch::  ERROR: [dev #87] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:57.999   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                          2021-05-02 14:03:58.000   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x11320b0
                                          2021-05-02 14:03:58.002   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x11320b0
                                          2021-05-02 14:03:58.003   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x11320b0
                                            154.1k
