  3. Ways to identify and calculate energy usage (watts) ?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
16 Posts 8 Posters 2.5k Views 7 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi all
    I’ve been on a mission for a while now to try and track down where all the energy we use is going (so I can explain the exorbitantly high electricity bill !) .
    I’ve done a few posts on this subject already, see below..
    • https://smarthome.community/topic/534/unifi-energy-report-how-can-i-retrieve-the-value-via-http/6
    • https://smarthome.community/topic/584/luup-hue-energy-watts-calculator/17?_=1623603224863
    Plus I’ve got various energy meter plugs around the house to help me too, but when compared to my CurrentCost (whole house) energy meter, I’m still unable to account for 200+ watts when i believe everything of note are switch off (so no dishwasher, no washing machine running etc.)
    Tracked items so far include.. Media Centre (TV/NAS etc.), Office Desk (Laptop/PC/Monitor etc.), Hue Lights, Fridge…
    1. What items/devices could I be missing ?
    2. What else could i create a pseudo energy (watts) calculations for ?
    For example (2), I‘ve got a couple of Sonos Music players, which are always on, so I’m thinking as they are a media device that report their status, i can calculate a pause/stop watts rating vs a play rating..
    Any thoughts on what the missing power hungry items are in a normal house, and/or any new pseudo watt calculator ideas?
      Look for old appliances. One of the first TV I got 15 years ago was a Sharp tv consuming 31 watts at standby and 300 when on. The new LG/Samsung/Philips I have now are under 1 watt when idle, and 70/200 when on, depending on the size.
      My house is consuming 300 watts at idle, and that’s because I have mini PCs, two fridges, and so on. Placing simple meters on the appliances could help to track them.
        Some initial thoughts, partly based on past experience:
        1. Don't forget the attic. Some attics have powered fans, and these are easy to forget.
        2. I love my Kill-A-Watt power measurement device, since it can be placed temporarily in line with any (110V) appliance to reveal its power draw at various phases of operation.
        3. I'd use MSR exclusively to create a catch-all Rule that sums up the proportional wattage for all "ON" devices.
        4. Tracking usage with an array in Expressions, charting with HundredGraphs, or exporting to Google Sheets (via a Form link) are all viable options.
        5. Perhaps the most "serious" way to track down vampire power consumption in the home is using a basic ammeter at the panel, and testing circuit-by-circuit after shutting off all others.
          A few adds to @LibraSun 's list from own experience:
          1. Many dimmers "leak" enough energy to be relevant, and since they can be present in relatively large numbers in a home, even a modest leak can add up across multiple dimmers. I discovered this some years ago when my wife had me switch out a halogen vanity light bar in my older son's bathroom with an LED model. The light bar glows like a night light when the dimmer was fully off. I tried swapping the older dimmer (Leviton VRMX1) for a newer model (DZ6HD) but no change in results. When we later changed the ceiling fan bulb in my younger son's room from halogen to LED, the same thing happened. With incandescent or halogen loads, these leaks aren't enough to light the filament, generally, but some LED bulbs/fixtures don't require much current to glow. Be suspicious of any dimmer that has an "air gap" in particular--it's there because they know the device is passing current even when "off."
          2. And keep in mind that leaking or not, all line-powered ZWave devices of every kind are active electronics with power supplies (often terrible cap droppers with poor power factors to boot, particularly in the cheaper models). If it has an LED pilot lamp, maybe it's pulling 3-5 milliamps just for that, and if the supply and other electronics double that, you're at maybe 6-10ma per device. Times 20 devices may be 200ma total or about 40W right there.
          3. Smoke alarms, garage door openers, safety lights...
          IIRC, you're in the UK, where electrical panels tend to have fewer breakers than here in the US, so that makes isolating things a bit more of a challenge. Here in the US, it's usually not a big issue to remove the cover from the breaker panel, put a clamp meter on the main, and just start flipping breakers until the measurement drops, then go isolate down that circuit from there. Codes here increasingly require dedicated circuits for all kinds of things, and of course, GCFIs and AFCIs (our version of RCDs and... I don't know what the UK equivalent is called, but it's an arc-detecting device) which have power supplies as well. So panels here are getting bigger, and electricians are having no problems sending their kids to college.
          • parkercP Offline
            parkercP Offline
            parkerc
            Thanks all,
            Reading my initial post back again, I noticed I made a mistake, in that I said I was unable to account for 200 watts, it’s actually closer to 400 watts !!!
            Admittedly I know i’m never going to be able identify everything, but 400 watts !!, that’s more than @therealdb home in its idle state !! 😫
            @LibraSun and @toggledbits - the breaker panel, (or consumer unit as we call it in the UK) is a good call, and UK regulations are pretty strict too, so much of the house is broken up/out on the board so I can isolate various areas. That sounds like my weekend sorted ..
            Other than that, I’m beginning to wonder if I’m powering other people within my neighbourhood too. !😃🤞
            • parkercP parkerc
              Thanks all,
              Have a look at any split aircons or aircons in general. Older models had sump heaters that could use anything from 30W to 300W. These were permanently on. Also iron core transformers that are permanently connected eg door bells and alarm systems - they can be quite lossey. Older PCs also drew a far bit even when "off". In fact, lots of older equipment can draw substantial power when on standby. So much so the One Watt Initiative was instigated.
              • A a-lurker
                @a-lurker said in Ways to identify and calculate energy usage (watts) ?:
                In the UK? 😄
                parkercP 1 Reply Last reply
                • B Offline
                  B Offline
                  Buxton
                  Buy yourself one of these to get accurate energy usage : https://www.energyswitching.co.uk/best-energy-monitors-of-2021/ The US equivalent is "Kill a Watt" and that brand of device works well, though I don't believe they make a UK version.
                  Once you dial in the actual watts to your calcs, you'll probably see some of your unexplained energy use disappear. When I went through this process, and as mentioned above by several, the vampire devices in my home were the main contributors to my unknown energy usage. I was able to claw some of that back by using myriad smart switches for always on (sleeping) devices, albeit with a loss of instant on capability.
                  • B Offline
                    B Offline
                    Buxton
                      In the UK? 😄
                      parkercP Offline
                      parkercP Offline
                      parkerc
                      @catmanv2 said in Ways to identify and calculate energy usage (watts) ?:
                      In the UK? 😄
                      While they are irare in the home over here; I could certainly do with an one at the moment, as it’s quite toasty in the UK at the moment. 🙂
                      I’ve placed energy monitor wall-plugs in all the main places I can think of, which means everything left is theoretically a small thing, like a phone charger, an Amazon Echo, a clock, or a night light etc.
                      Which means I’m finding it hard to believe that all of those little things will come up to 400 watts…
                        I once found a walled off ventilation fan in an old kitchen that was still energized and conceivably could have burned many watts without rotating and I'm surprised it did not start a fire. I've also discovered doorbells that were stuck on because of a faulty Ring device wired in parallel with it. Finally, there's no end to the way that poorly grounded appliances can divert current directly to ground which you will never find through conventional testing means.
                        My central point being that you never know what you're going to find in around and under a house when it comes to electrical things. And that is absolutely why you really need to unplug and disconnect every single thing in this quest to isolate phantom power consumers.
                          And the light someone left on in the roof space or under the floor.
                          • parkercP parkerc
                            In the UK? 😄
                            @parkerc said in Ways to identify and calculate energy usage (watts) ?:
                            I know! I live in Essex 🙂
                              wrote on last edited by Elcid
                              Hi to find the source you would be best to use a clamp meter on the outgoing live cable at each mcb in the consumer unit, once everything is turned off, that way you can zero in on the circuits that are still using power. Do you have a rcd/s fitted in your consumer unit if so ground leakage would only account for 7 watts max per rcd unit, before rcd would trip, unless faulty.
                              [edit] on socket ring ciruits put both live wires in clamp meter.
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                I’ll tell you what trying to understand your energy usage while the family is in the house is next to impossible, no matter how many times i told them what i was doing , i would suddenly struggle to add up up the wattage numbers - only later to find out that they’d plugged something in or turned something off !!! Add to that things that come on by themselves at random times such as the fridge or the freezer and you really are scratching your head what the hell is going on - not matter what systematic approach I followed.
                                Cut along story short, the best I could come up with today is that my office/man cave - has an idle usage of about 250 watts (not surprising as this is where all the networking kit and media devices are stored/connected into) after that it’s the kitchen with about 150 watts too (due to a small HA hub and fridge/freezer) and the shed/cabin (100 watts) - which leaves the rest of the house using the remainder which is approx 350-400 watts..
                                  The new smart meters installed across many U.S. municipalities derive actual usage in real time (whether you believe they are accurate or not -- this is a troublesome source of debate among many smart people). Some utility companies offer a companion "reader", which wirelessly displays your home's current demand, by minute, hour, day, month, total, etc.
                                  That's about as close as I've ever come to instant readings. The rest, as you rightly point out, is likely folly.
                                    110.7k
                                  • Integrations and 'Loaded'
