Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
Having issues with a shell command
For the value in the expression "ps4powerstatus" its either going to be:
200 = ON
620 = OFFHow can I have another expression that will translate those code numbers in to human text that I can then send to Vera / Home Remote ?
By the way, it's much more efficient to use expressions in ps4powerstatus and ps4runningapp
Understood I have changed it and removed the set variable actions:
EDIT:
Don't think it likes that, I get these error when I press the "Reset" button on the rule.
That's right.
Show all the values when you post an error, please.
No errors there.
Have you removed the Set Variable actions?
Yes
The bell icon goes red when the rule is Reset.
Removing the actions is/was correct. I'll give this a try later today and see
Using a Vera Multistring plugin device.
I added these in the rules Reaction to send the values to the generic sensor device in Vera etc.
Just need to translate codes 200 and 620 to "On" and "Off" instead.
I could maybe delete these two expressions from the rule also.
EDIT:
I've just seen a new field called "status" maybe I can use that instead.
On = "OK"
Off = "Standby"
I had a moment to do a quick test. Duh; I'm forgetting my own code's behavior. This is actually pretty simple. When you reset the rule, all state and expression/variable values are removed, so effectively, everything is null. When the rule is then re-evaluated, expressions are evaluated first, and since
ps4wakercheck
is null at that point because the action has not yet run, thenps4wakerparse
is also null, so the last two expressions can't dereference through null and throw an evaluation error. This is actually all expected, correct behavior.You can probably just clear these two spurious errors (caused by the reset/no data condition at rule "boot"), as they will not happen again, typically. The only other way you would see this is if the command actually fails hard in some way and produces no parseable JSON output. Then you'll get alerts again, but that's probably good because you might want to know that.
Another way to handle it is to simply modify the last two expressions like this:
- ps4powerstatus =
ps4wakerparse?.statusCode
- ps4runningapp =
ps4wakerparse?["running-app-name"]
The
and?[
operators, described in the docs, are special coalescing versions of the standard.
and[
operators that guard null on their left-hand operands. If the left-side operand value is null, the coalescing operator will simply return null and no error will be issued. I think this also makes sense in this application. These coalescing operators are provided for exactly this kind of case, so this is a perfect example of their use, and you should familiarize yourself with them (and apply them often). - ps4powerstatus =
You can map a value from one to another using a simple map object, like this:
mappedStatus =
( { '200': 'On', '620': 'Off' } )?[ ps4wakerparse.statusCode ] ?? "unknown"
Here, we create an object on the fly (the
part), dereference through it using the?[
coalesce operator, which will return null if the value ofstatusCode
doesn't match anything in the object, and then use a final??
coalesce operator to change an unmapped/null to the wordunknown
The ?. and ?[ operators
That fixes it the red alerts don't appear any more when Resetting the rule.
Finished device in Vera:
Home Remote dashboard tile:
Had to just add an additional ? to this code to stop the red alert appearing again.
( { '200': 'On', '620': 'Off' } )?[ ps4wakerparse?.statusCode ] ?? "unknown"
And now the alert doesn't come back again when resetting the rule.
So I think everything is all working fine now, at least while the PS4 is turned ON.
So everything last night was working OK when the PS4 was turned ON.
I am now testing when the PS4 is OFF.
Some issues the shell command doesn't seem to be populating the ps4wakercheck variable for some reason and its null.
Vera device when PS4 is OFF
If I run the "ps4-waker check" command in terminal it outputs correctly as expected.
root@HP-Thin01:/home/stuart# ps4-waker check { "type": "device", "statusLine": "620 Server Standby", "statusCode": "620", "status": "Standby", "host-id": "C863F1400EF1", "host-type": "PS4", "host-name": "PS4-806", "host-request-port": "997", "device-discovery-protocol-version": "00020020", "system-version": "08520011", "address": "192.168.0.201" }
Log file:
2021-08-02T10:51:27.077Z <Engine:NOTICE> Starting reaction PS4 Waker Check<SET> (rule-krq612qx:S) 2021-08-02T10:51:27.077Z <Engine:5:Engine.js:1378> Engine#1 reaction rule-krq612qx:S step 1 shell command { "command": "ps4-waker check", "rule": "rule-krq612qx", "rvar": "ps4wakercheck", "ignore_exit": true } 2021-08-02T10:51:27.094Z <Engine:5:Engine.js:1105> _process_reaction_queue() task returned, new status 3; task 19 2021-08-02T10:51:27.098Z <Engine:5:Engine.js:1140> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting 2021-08-02T10:51:27.617Z <Engine:ERR> Engine#1 reaction PS4 Waker Check<SET> step 1 error executing shell `ps4-waker check': Error: Command failed: ps4-waker check 2021-08-02T10:51:27.620Z <Rule:5:Rule.js:674> Rule#rule-krq612qx rule set variable ps4wakercheck = (object) (null) 2021-08-02T10:51:27.621Z <Engine:5:Engine.js:940> Engine#1 set variable rule rule-krq612qx ps4wakercheck=(null), requesting re-eval 2021-08-02T10:51:27.624Z <Rule:5:Rule.js:962> Rule#rule-krq612qx (PS4 Waker Check) evaluate() acquiring mutex 2021-08-02T10:51:27.625Z <Engine:5:Engine.js:1140> _process_reaction_queue() wake-up! 2021-08-02T10:51:27.625Z <Rule:5:Rule.js:966> Rule#rule-krq612qx._evaluate() mutex acquired, evaluating 2021-08-02T10:51:27.626Z <Rule:5:Rule.js:970> Rule#rule-krq612qx update rate is 2/min limit 60/min 2021-08-02T10:51:27.627Z <Rule:5:Rule.js:892> Rule#rule-krq612qx evaluateExpressions() with 3 expressions 2021-08-02T10:51:27.628Z <Rule:5:Rule.js:982> Rule#rule-krq612qx._evaluate() trigger state now false (was false) 2021-08-02T10:51:27.629Z <Rule:5:Rule.js:984> Rule#rule-krq612qx._evaluate() constraints state true 2021-08-02T10:51:27.629Z <Rule:5:Rule.js:993> Rule#rule-krq612qx rule state now false, changed no 2021-08-02T10:51:27.631Z <Engine:5:Engine.js:1101> _process_reaction_queue() running task 19 { "tid": 19, "id": "rule-krq612qx:S", "rule": "rule-krq612qx", "__reaction": [RuleReaction#rule-krq612qx:S], "next_step": 2, "status": 1, "ts": 1627901487069, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 } 2021-08-02T10:51:27.632Z <Engine:NOTICE> Resuming reaction PS4 Waker Check<SET> (rule-krq612qx:S) from step 2 2021-08-02T10:51:27.632Z <Engine:NOTICE> PS4 Waker Check<SET> delaying until 1627901492632<02/08/2021, 11:51:32> 2021-08-02T10:51:27.633Z <Engine:5:Engine.js:1105> _process_reaction_queue() task returned, new status 2; task 19 2021-08-02T10:51:27.636Z <Engine:5:Engine.js:1140> _process_reaction_queue() ending with 1 in queue; waiting for 1 (next delayed task)
If I turn ON the PS4 it starts working again and the variable is populated with data via the shell command.
Make sure you restarted Reactor after installing the update. The ignore flag is in the action data (so the UI has done the right thing), but the log file content looks like an older version of the Engine running.
Any update on this?
Sorry for the delay.
Yes its working now after restarting MSR.
So when the PS4 is OFF its now reporting the status correctly from the ps4-waker check variables.
So its working when its on and off now.
However I am still getting some alert errors sometimes occasionally.
This seems to happen if the shell command doesn't return any response on the first go, but maybe on the second attempt it works and then populates the variables OK.
When this happens these alerts remain in the MSR gui etc.
Use your coalesce operators on those expressions to suppress the reference errors and just yield a null result.
The actions in the Reaction that send the data to the Vera MutliString device, didn't have "?" in their expressions.
I have just added them like this:
EDIT:
It doesn't like the first one " mappedstatuscode? " I've removed the question mark for that one.
I've also now added a virtual switch in Vera, this works with two new MSR rules (#3 and #4).
First rule (#4), that when the virtual switch it turned on or off manually in Vera / Home Remote app, it will send the appropriate power command to the ps4 via shell command:
ON = ps4-waker
OFF = ps4-waker standby
The second rule (#3) updates the state of the Vera virtual switch, if the PS4's power is controlled by some other outside means.
This rule monitors the "mappedstatuscode" expression variable, which will either say "On" or "Off" and then it adjusts the Vera virtual switch accordingly to match that current actual state of the PS4, so the virtual switch doesn't get out of sync.I am still experimenting with this, but my thinking was to have an additional "switch" in Vera / Home Remote app, to be able to manually / directly control the PS4's power (outside of a Harmony activity) as a backup switch. Say if the PS4 didn't turn on when the Harmony Activity for it was started and the other MSR rule (#1) didn't work with its attempt and didn't turn on the PS4.
Although having said that, I guess some kind of test and retry (in rule #1) to attempt to turn on the PS4 power again, might be a better way of doing it, if it failed to do so initially.
So in total I currently have four rules.
- "Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command"
Turns on PS4 when Harmony Activity is starting.
- "PS4 Waker Check"
This is the rule with all the expressions in it for the MultiString Vera device. Displays the PS4's current status etc
- "Playstation 4 Virtual Switch Status from PS4-Waker"
Controls the virtual switch in Vera based on the actual state of the PS4 power, info as coming from ps4-waker check and rule #2
- "Playstation 4 Virtual Switch ON / OFF"
Sends either the on or off shell commands to the PS4 based on the virtual switch in Vera / Home Remote app being manually operated.
Home Remote tiles:
I am sure there must be better / easier ways of doing all this.
