  3. Logrotate advice
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Logrotate advice
8 Posts 3 Posters 1.1k Views 3 Watching
    Hi all
    Ran into an issue last month where my Open Luup box ran out of disk space in /var/log. It's Debian with a separate partition so everything carried on working but it had some very interesting effects on my network.
    Culprit was the z-way server log which was at about 5G....
    So I thought I'd set up logrotate on it. Dead simple. And so it seems. Log is rotate just fine but z-way-server carries on writing to the old log. Any ideas how to fix that (apart from re-starting the server every time we rotate?).
    Entry from logrotate.d is here:
    catman@openluup:/etc/logrotate.d$ cat z-way-server
    /var/log/z-way-server.log {
    	weekly
    	rotate 4
    	compress
    	delaycompress
    	missingok
    	notifempty
    	create 644 root root
    z-way-server config:
    <config>
        <automation-dir>automation</automation-dir>
        <log-file>/var/log/z-way-server.log</log-file>
        <log-level>2</log-level>
        <debug-port></debug-port>
    </config>
    config.xml (END)
    TIA
      I wonder what happens if you move/delete the log file? Does it just carry on with a new one?
        @akbooer said in Logrotate advice:
        No. Carries on writing to the old one. I've amended it the config to use copytruncate. In theory this copies the existing file to $file.log.1 and then truncates the original file (and the app keeps writing to it)
        There is a timeslice where entries may be lost but I'm not concerned. I'm just waiting for the next rotate now
        Cheers
          Cheers
          @catmanv2 said in Logrotate advice:
          That's because the inode (basically a structure that represents allocation of space on disk) still exists in the file system and the service still has the file descriptor open on that inode. Changing the name or location of a file does not change the inode itself, but just a field on it (like renaming a device on Vera doesn't change the device number or ZWave node ID).
          In fact, if you delete the file, that just marks it deleted on the inode, but does not delete the inode or free up the space associated with it unless and until all file descriptors open on the inode are closed. Those open file descriptors can continue to write (and consume disk space) now to a file you can't actually see in ls, so the services that use them are still writing to the now-invisible file. Only when that open descriptor count is 0 is the file actually deleted and the inode and its allocated blocks free'd.
          Most services need to be notified that the log file has changed, so they can close their file descriptors and open new ones, and you can see this expressed in a variety of ways in the various configs for the system services that are rotated. It's not unusual to see a service configured for restart at the time of log rotation, and this is why.
            Yeah, I copied the config for something else. Only a few have a restart and none use copytruncate. I don't really want to restart z-way-server every time though....
              Have you seen this thread?
              https://smarthome.community/topic/112/logrotate-for-z-way-server
                @toggledbits said in Logrotate advice:
                I actually contributed to it! my memory really is going.
                I'll see how the truncate works
                  Worked perfectly
                    831
                    3.7k
                    3.2k
                    820
