  3. Altui file not found errors
openLuup email server
Hello AK
Have been writing about the openLuup email server as I was tinkering with it the other day. One minor problem: it looks like the domain part of the email address eg ...@openLuup.local is case sensitive in openLuup.
Looking round the net, it suggests that the local part is case sensitive but the domain part is not meant to be. To keep things so they are more likely to work, it's suggested the email address should be totally case insensitive regardless. Refer to rfc2821 page 13 or search on the word "sensitive". Suffice to say I was using mail@openluup.local rather than mail@openLuup.local, so it didn't work for me.
Next challenge was that the file saved in /etc/cmh-ludl/mail has "Content-Transfer-Encoding: base64" so the body of the email was encoded:
Received: from ((openLuup.smtp) [ip_address_1] by (openLuup.smtp v18.4.12) [ip_address_2]; Tue, 26 Nov 2024 14:21:22 +1000 From: "dali@switchboard" <dali@switchboard> To: "mail@openLuup.local" <mail@openLuup.local> Subject: Warning form R2E. MIME-Version: 1.0 Content-Type: text/plain Content-Transfer-Encoding: base64 QXV0byBXYXJuaW5nOiBDb2xkIHN0YXJ0IGV2ZW50
The above base 64 text translates to "Auto Warning: Cold start event".
Is it your preference to leave the saved files in the raw mode or would you consider translating the base64 text in the openLuup code base?
On a side note, does the reception of an email by openLuup generate some sort of trigger that can be watched. In the case above; the email represents the restoration of power after a power outage. I would like to know about that by the email triggering a "Telegram" notification on my mobile.
I see that the images@openLuup.local images@openLuup.local can be associated with I_openLuupCamera1.xml, which spawns a movement detector child. Anything similar for the other email addresses?
openLuup
Sorry if this has been covered before, just curious why triggers in openluup are not consistent..
I looked at a scene i’d created a while back via ALTUI using the Console view and noticed it didn’t show any Triggers, which was strange as it was my main front door event 🙂 . So I added the door tripped trigger again, but I’ve just noticed I now how two tiggers using this view.
In ALTUI it shows this.
openLuup
AK. Was doing an openLuup install and the installer errored with:
openLuup_install 2019.02.15 @akbooer getting openLuup version tar file from GitHub branch master... un-zipping download files... getting dkjson.lua... lua5.1: openLuup_install.lua:45: GitHub download failed with code 500 stack traceback: [C]: in function 'assert' openLuup_install.lua:45: in main chunk [C]: ?
The installer code was executing this URL:
http://dkolf.de/src/dkjson-lua.fsl/raw/dkjson.lua?name=16cbc26080996d9da827df42cb0844a25518eeb3
Running it manually gives:
dkolf.de The script could not be run error-free. Please check your error log file for the exact error message. You can find this in the KIS under "Product Management > *YOUR PRODUCT* > *CONFYGUAR* > Logfiles". Further information can be found in our FAQ. The script could not be executed correctly. Please refer to your error log for details about this error. You find it in your KIS under item "Product Admin > *YOUR PRODUCT* > *CONFIGURE* > Logfiles". Further information can also be found in our FAQ.
I'm thinking the dkjson code URL has been changed. On dkolf.de there is a download link:
http://dkolf.de/dkjson-lua/dkjson-2.8.lua
and dkjson code also seems to be in GitHub (I presume this is the same code?):
https://github.com/LuaDist/dkjson/blob/master/dkjson.lua
I'm don't know what dkolf.de looked like previously but I do see the dkjson code has been updated as of 2024-06-17. Hope this helps.
Oh - and by the way the dkjson.lua file seems to have been downloaded OK by the installer - error or no error, so go figure.
openLuup
It’s been a while since I looked at openLuup as it had been running nicely and quietly in the background doing some basic tasks. With my VeraPlus looking like it’s finally succumbing to old age, I want to shift a number of the global module I have over to openLuup.
To do this, I have added the files (example would be xxpushover.lua to the cmh-ludl folder and the following to the startup
require “xxpushover”
The xxpushover.lua file itself starts with the following..
module("xxpushover", package.seeall)
And I always have a line in these files to allow me to check it’s been read in the start up related logs, which in this case it is..
The challenge I’m having is that when I try to call any of the functions within the module, it returns the following error..
"[string "ALTUI - LuaRunHandler"]:1: attempt to index global 'xxpushover' (a nil value)”
I’m no doubt missing something obvious, can anyone help me find out what it is ? Many thanks
openLuup
Currently I have some Whisper files used by DataYours that been working well for ages and do what I want.
One of the files is called Watts_L1.d.wsp and uses this retention from "storage_schemas_conf" in openLuup file virtualfilesystem.lua:
[day] pattern = \.d$ retentions = 1m:1d
Inside the actual "Watts_L1.d.wsp" file is a header like so:
1, 86400, 0, 1 84, 60, 1440
The 1, 86400 is one minute & one day (in minutes) as per the retention listed above. As a side issue I would like to know what the other header values mean ie what's the syntax here?
New challenge: I now have three Shelly variables named:
em1/0/act_power
em1/1/act_power
em1/2/act_power
with a device ID of "10006" and a SID of "shellypro3em"
And I would like to plot them using the Historian, just like I do with Watts_L1.d.wsp in DataYours. So I need a file in the history directory for the data. So I looked at doing this:
local whisper = require "openLuup.whisper" -- Syntax: history/0.deviceNumber.shortServiceId.variableName local filename = "history/0.10006.shellypro3em.em1/0/act_power.wsp" local archives = "1m:1d" whisper.create (filename,archives,0)
Problem is that the variable names contains forward slashes, which are invalid filename characters. What to do?
Also should the retentions now be (to suit the latest openLuup software)?:
local archives = "1m:1d,10m:7d,1h:30d,3h:1y,1d:10y"
Also "shellypro3em" is not a "shortServiceID" as per those listed in "servertables.lua". So can "shellypro3em" be used instead? ie can both short and long service IDs be used in the above call to whisper.create?
openLuup
To try and minimized the frequency of writing to the SD card I want to move these log files to a RAM drive, like I already do with /var/log. Is there an 'official' way of doing this?
_John.
openLuup
openLuup: Version Log
master – stable, and infrequently updated, development – latest updates and bug fixes, testing – use only when advised!
A long while ago (May, 2015) I wrote my 2000-th post on another forum: openLuup - running unmodified plugins on any machine.
Here’s the gist of it:
1. UI
2. scheduler
3. web server
4. Luup compatible API
6. Zwave bridge to Vera
We have, courtesy of @amg0, the most excellent AltUI: Alternate UI to UI7, and that, I think, is probably the hardest one to do in the above list. Items 2 - 5, and 7, I’ve prototyped, in pure Lua, and posted elsewhere: DataYours on Raspberry Pi, running selected plugins unmodified, including: DataYours, EventWatcher, Netatmo, RBLuaTest, altUI. See screenshot attached.
Is it worth the effort? Probably not. Will I pursue this quest? Yes.
openLuup was the result.
openLuup
ZWaveJS and MQTT
Re: openLuup: MQTT server
@ronluna
openLuup
Awesome MQTT - GitHub list
openLuup
sidereal time clock
openLuup
Set up:
2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88
Re: socket.select() not ready to send
openLuup
Hi @akbooer
openLuup
openLuup and room names
openLuup
Hey guys...
Long time... 😉
For example..
AND
AND
AND
IF binary-light1 is OFF
AND
IF binary-light2 is OFF
THEN
execute LUA code
WAIT 2 minute
execute LUA code
openLuup
Zigbee2MQTT
AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code.
Now here's the query:
GitHub - dbochicchio/vera-VirtualDevices: Virtual HTTP Devices plug-in for Vera and openLuup GitHub - dbochicchio/vera-VirtualDevices: Virtual HTTP Devices plug-in for Vera and openLuup
Virtual HTTP Devices plug-in for Vera and openLuup - dbochicchio/vera-VirtualDevices
openLuup
openLuup
AltUI access over VPN
Bit of an odd one this:
I can ssh into all my servers
TIA for any thoughts
openLuup
Hi Ak,
This is in the init function:
luup.call_timer("HouseDevice1_PumpCommand", 2, "2:15:00", hm_Heating.PumpHealthRunDay, hm_Heating.PumpCMD.HEALTH.."1", true)
This is in the function to schedule to off command giving the global function name not found:
luup.call_delay("HouseDevice1_PumpCommand", hm_Heating.PumpHealthOnDuration, hm_Heating.PumpCMD.HEALTH.."0")
Is it because I use the "TRUE" parameter that is openLuup specific so the timer does not fire just once?
openLuup
OpenLuup installation
Regards
Jan
no file ‘./socket/http.lua’
no file ‘./socket/http.so’
no file ‘./socket.so’
stack traceback:
[C]: in function ‘require’
openLuup
Unexpected stop of openLuup
2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548
And then in syslog:
Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
21 Posts 2 Posters 1.7k Views
  • B Offline
    B Offline
    Buxton
    Here is a snippet of the log:
    2021-08-22 16:57:28.106   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/jquery-ui.css
    2021-08-22 16:57:28.107   openLuup.server:: request completed (150 bytes, 0 chunks, 1 ms) tcp{client}: 0x564e387b57a8
    2021-08-22 16:57:28.114   openLuup.server:: GET /etc/cmh-ludl/localcdn/font-awesome.min.css HTTP/1.1 tcp{client}: 0x564e38b3af28
    2021-08-22 16:57:28.116   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/font-awesome.min.css
    2021-08-22 16:57:28.116   openLuup.server:: request completed (157 bytes, 0 chunks, 1 ms) tcp{client}: 0x564e38b3af28
    2021-08-22 16:57:28.117   openLuup.io.server:: HTTP:3480 connection from 10.17.1.100 tcp{client}: 0x564e385a7098
    2021-08-22 16:57:28.123   openLuup.server:: GET /etc/cmh-ludl/localcdn/bootstrap.min.css HTTP/1.1 tcp{client}: 0x564e385a7098
    2021-08-22 16:57:28.123   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/bootstrap.min.css
    2021-08-22 16:57:28.124   openLuup.server:: request completed (154 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e385a7098
    2021-08-22 16:57:28.124   openLuup.server:: GET /etc/cmh-ludl/localcdn/jquery.bootgrid.min.css HTTP/1.1 tcp{client}: 0x564e387b57a8
    2021-08-22 16:57:28.125   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/jquery.bootgrid.min.css
    2021-08-22 16:57:28.126   openLuup.server:: request completed (160 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e387b57a8
    2021-08-22 16:57:28.127   openLuup.io.server:: HTTP:3480 connection from 10.17.1.100 tcp{client}: 0x564e38ea35a8
    2021-08-22 16:57:28.127   openLuup.io.server:: HTTP:3480 connection from 10.17.1.100 tcp{client}: 0x564e3882e378
    2021-08-22 16:57:28.133   openLuup.server:: GET /etc/cmh-ludl/localcdn/joint.css HTTP/1.1 tcp{client}: 0x564e3882e378
    2021-08-22 16:57:28.134   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/joint.css
    2021-08-22 16:57:28.135   openLuup.server:: request completed (146 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e3882e378
    2021-08-22 16:57:28.136   openLuup.io.server:: HTTP:3480 connection from 10.17.1.100 tcp{client}: 0x564e36e44d08
    2021-08-22 16:57:28.136   openLuup.server:: GET /etc/cmh-ludl/localcdn/spectrum.min.css HTTP/1.1 tcp{client}: 0x564e38ea35a8
    2021-08-22 16:57:28.137   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/spectrum.min.css
    2021-08-22 16:57:28.137   openLuup.server:: request completed (153 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e38ea35a8
    2021-08-22 16:57:28.141   openLuup.server:: GET /etc/cmh-ludl/localcdn/jquery.min.js HTTP/1.1 tcp{client}: 0x564e36e44d08
    And here is a screen shot showing the files exist:
    Altui will not load. Using the current openLuup dev version 2021.08.16 which was updated today. There is a forward slash in front of etc for the get but not for the file not found error.
      AFAIK there’s been no change at all in the file loader code. AltUI seems to work for me, but I don’t use a local CDN.
      Did you do anything other then just update openLuup?
      Edit: I just tried getting a non-existent file and see this log:
      2021-08-23 07:43:12.984   openLuup.server:: GET /foo HTTP/1.1 tcp{client}: 0x55adcd32ec28
      2021-08-23 07:43:12.984   openLuup.servlet:: file not found:foo
      So I don’t think that the missing ‘/‘ is of significance.
      • B Offline
        B Offline
        Buxton
        No. The update started it. Is it possible to see the actual call through debug. Because obviously the files reported as not there, are there. So something is wrong or different in the call.
          Can you just check by reverting to an older version? The master branch is just a couple of revisions behind, or v21.4.26 would do.
            Alternatively, try to see if the server can actually read one of the files by requesting it manually. For example:
            http://openLuupIP:3480/localcdn/joint.css
            B 2 Replies Last reply
            • B Offline
              B Offline
              Buxton
              replied to akbooer on last edited by
              @akbooer said in Altui file not found errors:
              localcdn/joint.css
              Yes, that http command returns the file.
              • B Offline
                B Offline
                Buxton
                replied to akbooer on last edited by Buxton
                @akbooer and the standard plugin altui js files load from the cmh-ludl folder. It's the localcdn folder js that is not loading. Odd that the server is saying the request completed, but the servlet says that the file is not found.
                2021-08-23 10:55:28.520   openLuup.server:: request completed (202128 bytes, 13 chunks, 10 ms) tcp{client}: 0x55c768bab068
                2021-08-23 10:55:28.520   openLuup.server:: GET /J_ALTUI_multibox.js HTTP/1.1 tcp{client}: 0x55c7693511b8
                2021-08-23 10:55:28.522   openLuup.server:: request completed (40237 bytes, 3 chunks, 1 ms) tcp{client}: 0x55c7693511b8
                2021-08-23 10:55:28.524   openLuup.server:: GET /J_ALTUI_iphone.js HTTP/1.1 tcp{client}: 0x55c7688d4168
                2021-08-23 10:55:28.526   openLuup.server:: request completed (22770 bytes, 2 chunks, 1 ms) tcp{client}: 0x55c7688d4168
                2021-08-23 10:55:28.526   openLuup.server:: GET /J_ALTUI_uimgr.js HTTP/1.1 tcp{client}: 0x55c7693240b8
                2021-08-23 10:55:28.571   openLuup.server:: request completed (717146 bytes, 45 chunks, 44 ms) tcp{client}: 0x55c7693240b8
                2021-08-23 10:55:28.571   openLuup.server:: GET /etc/cmh-ludl/localcdn/altui/joint.min.js HTTP/1.1 tcp{client}: 0x55c7690878c8
                2021-08-23 10:55:28.572   openLuup.servlet:: file not found:etc/cmh-ludl/localcdn/joint.min.js
                2021-08-23 10:55:28.572   openLuup.server:: request completed (155 bytes, 0 chunks, 0 ms) tcp{client}: 0x55c7690878c8
                • B Offline
                  B Offline
                  Buxton
                  I was able to get altui back up by deleting the contents of the localcdn state variable and the bootstrap variable (this action will then pull files from the internet). So it may be that the altui installation was corrupted when I installed the dev version of openLuup. I tried re-installing altui, but it didn't improve things and in the process I further managed to erase all my cached ui settings. Anyway, I'd still like to see why the file not found message is in the logs, when the files are actually there.
                    Is there an AltUI parameter which defines the location of the local CDN?
                    I really have no explanation… you’re sure that nothing else changed?
                    B 1 Reply Last reply
                    • B Offline
                      B Offline
                      Buxton
                      @akbooer Yes, these two variables control location:
                        Remind me how to create a local CDN so that I can try myself…
                        • B Offline
                          B Offline
                          Buxton
                          @akbooer You would copy the folder localcdn and its subfolders from the github repo Altui to a similar folder structure on your openLuup cmh-ludl installation. Then place the full path in the LocalCDN variable via the altui device. For the LocalBootstrap, I believe it's just the bootstrap.min.js file name:
                            @Buxton
                            At last, I've had a chance to try this.
                            It all appears to work as expected. I can be sure that it's using the localcdn/ by renaming one of the files in there and seeing an 'file not found' error message.
                            To clear, I have the localcdn in cmh-ludl/ (ie. the openLuup home folder) and my AltUI LocalCDN variable is set to localcdn/altui/
                            • B Offline
                              B Offline
                              Buxton
                              Yes, that is the same as my setup (I also tried storing the files in the altui sub folder with no change). My installation worked fine for more than a year. It broke on the openLuup update, leading me to believe there was some sort of local file corruption.
                              However, I also believe there must be a difference between the path that is being used by the openLuup routine to grab a file, and the path that is displayed in the log, as the log display path pointed to the folder where the localcdn files are stored (as seen in the the first post's screen shot of the directory structure.)
                                Do you know what version you were running previously? Have you tried reverting. I still can’t see anything that could cause this. I will enhance the error message to specify the exact path.
                                  OK, I've checked the code. The openLuup server's root folder is cmh-ludl. All paths are relative to this, hence any leading '/' is removed from the given path. In common with other web servers, you cannot access an arbitrary path on the system, which is why it also disallows '..' in a pathname. There are also a limited number of path aliases built into the system, mostly to do with CGI handling, and nothing to do with localcdn.
                                  The filtered pathname is already displayed in the error messages. Nothing has changed in this area of code for quite a while. I still cannot see how the latest update could have changed anything. It all seems to be working as it should.
                                    Just noticed in your very first post that the given path is
                                    Whereas you should have just this:
                                    localcdn/
                                    Did you inadvertently change this after the update??
                                    • B Offline
                                      B Offline
                                      Buxton
                                      That's probably the reason this happened. I had the full path in the variable. Though, the full path did work for more than a year.....
                                      However, that still leaves the issue of why the path as seen in the log is different from the actual path being used in the routine that looks for the files...... For diagnostic reasons alone, the two paths should be an exact match.
                                      B akbooerA 2 Replies Last reply
                                      • B Offline
                                        B Offline
                                        Buxton
                                        replied to Buxton on last edited by
                                        @buxton The relative path works.
                                        Can you make the "file not found" error a red highlit error like the other system errors. This would flag in the log any odd files that are not within the relative path scope, as the relative paths are not explicitly known to the end user....
                                          @buxton said in Altui file not found errors:
                                          I have no explanation for how that could be.
                                          I don’t understand this. It isn’t. It’s the actual path used by the open routine (which is relative to the base folder.)
                                          Yes, I’d planned to do that, but it happens rather often in a benign way, for example, the browser often tries to get favicon.ico, but if you haven’t got one, it keeps trying…
                                          The console HTTP has a list of all file requests and their latest status.
                                          • Disaster recovery and virtualisation
                                          • Remote access of Zwave stick from Z-wave server
                                          • Organizing/ structuring rule sets and rules
                                          • Moving MSR from a QNAP container to RP 5 - some issues
                                          • Widget deletion does not work and landing page (status) is empy
                                          • Need help reducing false positive notifications
                                            35.1k
                                          • Deleting widgets
                                          • MQTT configuration question
                                          • System Configuration Check - time is offset
