  3. Homer Dashboard - Vera/OpenLuup
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
4 Posts 2 Posters 1.9k Views 2 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi all
    I’ve recently started to build out my own ‘Homer’ dashboard (https://github.com/bastienwirtz/homer) and I must admit I really like what it’s given me.
    Thinking about future use-cases. I can see potential for this being an alternative (albeit simple ) UI for Vera/OpenLuup..
    Is anyone else using Homer ?
    parkercP 1 Reply Last reply
    • parkercP parkerc
      Hi all
      parkercP Offline
      parkercP Offline
      parkerc
      Quick update on this thread as Homer has become my go-to-place now for accessing all my applications - attached is a screenshot of one of my Homer pages..
      If anyone’s wondering that ‘cabin’ is the glorified name for the shed at the end of the garden we converted 🙂 (Sadly nothing as luxurious as it sounds.)
      • P Offline
        P Offline
        pvklink
        Hi, I also installed homer today and made my first menu.
        Still strugling to get another page working, it gives for now an error!
        I downloaded the the docker version from b4bz/homer:latest
        • parkercP Offline
          parkercP Offline
          parkerc
          Hi @pvklink
          I have another page working, can you post the section on your .yaml file ?
          Also if I recall correctly, the default .config template they give you does much of it for you ?
          I just have the following in the config.yml
          links:
            - name: "Contribute"
              icon: "fab fa-github"
              url: "https://github.com/bastienwirtz/homer"
              target: "_blank" # optional html a tag target attribute
            - name: "Wiki"
              icon: "fas fa-book"
              url: "https://www.wikipedia.org/"
            - name: "Homer Github"
            # this will link to a second homer page that will load config from additionnal-page.yml and keep default config values as in config.yml file
            # see url field and assets/additionnal-page.yml.dist used in this example:
            - name: "another page!"
              icon: "fas fa-file-alt"
              url: "#additionnal-page"
          And then I have a second file, stored in the same location called additionnal-page.yml
            retireditguy
            143.2k
