  4. Critical Error after update
10 Posts 3 Posters 2.6k Views 3 Watching
    I updated MSR to 21239 and now no rules will run. The log files shows
    Rule:CRIT Error: Cannot find module 'common/util'
    I updated per the docs like always. I have also tried rebuilding the docker image from scratch with the same result. (not changing the data folders) This is Synology Docker Image, latest-generic-amd64. Build number from MSR says latest-21239-b87b5b9
    @toggledbits , What did a break?
    Log File:
    2021-08-28T16:19:12.102Z Rule:5:777:Rule.js Rule#rule-kpw0p0rl dependency notification entity-changed Entity#hubitat>12 from Entity#hubitat>12
    2021-08-28T16:19:12.103Z Rule:5:783:Rule.js Rule#rule-kpw0p0rl requesting eval; entity-changed Entity#hubitat>12
    2021-08-28T16:19:12.103Z Rule:5:993:Rule.js Rule#rule-kpw0p0rl (Pantry Light) evaluate() acquiring mutex
    2021-08-28T16:19:12.104Z Rule:5:997:Rule.js Rule#rule-kpw0p0rl._evaluate() mutex acquired, evaluating
    2021-08-28T16:19:12.104Z Rule:5:1001:Rule.js Rule#rule-kpw0p0rl update rate is 1/min limit 60/min
    2021-08-28T16:19:12.104Z Rule:5:921:Rule.js Rule#rule-kpw0p0rl evaluateExpressions() with 0 expressions
    2021-08-28T16:19:12.105Z Rule:CRIT Error: Cannot find module 'common/util'
    Require stack:
    • /opt/reactor/server/lib/Engine.js
    • /opt/reactor/server/lib/httpapi.js
    • /opt/reactor/app.js
      Require stack:
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      at Module.require (internal/modules/cjs/loader.js:974:19)
      at require (internal/modules/cjs/helpers.js:92:18)
      at Engine._get_lexp_extensions (/opt/reactor/server/lib/Engine.js:857:25)
      at Rule.evaluateExpressions (/opt/reactor/server/lib/Rule.js:921:286)
      at Rule._evaluate (/opt/reactor/server/lib/Rule.js:1011:323)
      at processTicksAndRejections (internal/process/task_queues.js:95:5)
      at async /opt/reactor/server/lib/Rule.js:980:17
    • S SweetGenius
      Log File:
      Require stack:
        Require stack:
      @sweetgenius and @toggledbits I also had a lot of errors in my log after update on my bare metal Ubunu. I had to revert to 1.0.0-21200 to have a clean log again.
        How are you starting Reactor on Ubuntu?
          @toggledbits With systemd.
            Add the following line to the Service section of the service file in /etc/systemd/system:
            Environment=NODE_PATH=/home/myuser/reacto
            Then:
            sudo systemctl daemon-reload
            sudo systemctl restart reactor
              Then:
              @toggledbits I suspected you would suggest that so I've just tried that and updated but same errors so I reverted again.
                OK. You need to have that line in there, pointing to the correct (reactor) directory.
                I've just respun the builds as well, missing a new file. Please pull the docker image and redownload the bare metal package/reinstall.
                And while you're at it, do a npm update --no-save on the Ubuntu side.
                  Yes, definitely keeping the environment config and will do npm update. There's no new timestamps on the builds in latest directory though?
                    @toggledbits Still no luck. npm updated to latest and all other suggestions applied. Should there be a new filename or timestamp on the tar.qz download?
                    Reactor starts but when I run a reaction this shows in alerts:
                    Reaction task "1" failed due to an exception. Please see the log.
                    Require stack:
                    - /home/user/reactor/server/lib/Engine.js
                    - /home/user/reactor/server/lib/httpapi.js
                    - /home/user/reactor/app.js
                    and the log is full of related erros.
                      I pulled a new Docker image and it appears to have fixed the issue. Thank You.
                        152.5k
