  4. Critical Error after update
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
10 Posts 3 Posters 1.6k Views 3 Watching
    I updated MSR to 21239 and now no rules will run. The log files shows
    Rule:CRIT Error: Cannot find module 'common/util'
    I updated per the docs like always. I have also tried rebuilding the docker image from scratch with the same result. (not changing the data folders) This is Synology Docker Image, latest-generic-amd64. Build number from MSR says latest-21239-b87b5b9
    @toggledbits , What did a break?
    Log File:
    2021-08-28T16:19:12.102Z Rule:5:777:Rule.js Rule#rule-kpw0p0rl dependency notification entity-changed Entity#hubitat>12 from Entity#hubitat>12
    2021-08-28T16:19:12.103Z Rule:5:783:Rule.js Rule#rule-kpw0p0rl requesting eval; entity-changed Entity#hubitat>12
    2021-08-28T16:19:12.103Z Rule:5:993:Rule.js Rule#rule-kpw0p0rl (Pantry Light) evaluate() acquiring mutex
    2021-08-28T16:19:12.104Z Rule:5:997:Rule.js Rule#rule-kpw0p0rl._evaluate() mutex acquired, evaluating
    2021-08-28T16:19:12.104Z Rule:5:1001:Rule.js Rule#rule-kpw0p0rl update rate is 1/min limit 60/min
    2021-08-28T16:19:12.104Z Rule:5:921:Rule.js Rule#rule-kpw0p0rl evaluateExpressions() with 0 expressions
    2021-08-28T16:19:12.105Z Rule:CRIT Error: Cannot find module 'common/util'
    Require stack:
    • /opt/reactor/server/lib/Engine.js
    • /opt/reactor/server/lib/httpapi.js
    • /opt/reactor/app.js
      Require stack:
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      at Module.require (internal/modules/cjs/loader.js:974:19)
      at require (internal/modules/cjs/helpers.js:92:18)
      at Engine._get_lexp_extensions (/opt/reactor/server/lib/Engine.js:857:25)
      at Rule.evaluateExpressions (/opt/reactor/server/lib/Rule.js:921:286)
      at Rule._evaluate (/opt/reactor/server/lib/Rule.js:1011:323)
      at processTicksAndRejections (internal/process/task_queues.js:95:5)
      at async /opt/reactor/server/lib/Rule.js:980:17
    • S SweetGenius
      Log File:
      Require stack:
        Require stack:
      @sweetgenius and @toggledbits I also had a lot of errors in my log after update on my bare metal Ubunu. I had to revert to 1.0.0-21200 to have a clean log again.
        How are you starting Reactor on Ubuntu?
          @toggledbits With systemd.
            Add the following line to the Service section of the service file in /etc/systemd/system:
            Environment=NODE_PATH=/home/myuser/reacto
            Then:
            sudo systemctl daemon-reload
            sudo systemctl restart reactor
              Then:
              @toggledbits I suspected you would suggest that so I've just tried that and updated but same errors so I reverted again.
                OK. You need to have that line in there, pointing to the correct (reactor) directory.
                I've just respun the builds as well, missing a new file. Please pull the docker image and redownload the bare metal package/reinstall.
                And while you're at it, do a npm update --no-save on the Ubuntu side.
                  Yes, definitely keeping the environment config and will do npm update. There's no new timestamps on the builds in latest directory though?
                    @toggledbits Still no luck. npm updated to latest and all other suggestions applied. Should there be a new filename or timestamp on the tar.qz download?
                    Reactor starts but when I run a reaction this shows in alerts:
                    Reaction task "1" failed due to an exception. Please see the log.
                    Require stack:
                    - /home/user/reactor/server/lib/Engine.js
                    - /home/user/reactor/server/lib/httpapi.js
                    - /home/user/reactor/app.js
                    and the log is full of related erros.
                      I pulled a new Docker image and it appears to have fixed the issue. Thank You.
                        2.1k
