  3. Occupancy - What are people using to check?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
20 Posts 6 Posters 4.7k Views 6 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    I have a lua/luup piece of code that checks, if any motion sensors have been tripped within the last 20 mins, and if not then to let me know.
    I then look at pinging TVs to see if they are on, in order to help rule out if someone’s just sitting still, and then I look at bluetooth sensors (RoomMe) and also Wi-Fi devices (UniFi) to help identify specific people’s active devices.
    I know there’s no perfect solution, but I was wondering what are other people using ?
    • parkercP parkerc
      @parkerc motion sensors obviously, but also Netatmo's noise sensor and if lights are on. Geofencing woud be helpful, but haven't used that.
      parkercP 1 Reply Last reply
        I’m just using OwnTracks to my own endpoint saving the messages in a mqtt queue. In the past I used to mix things, but OwnTracks is very good precise.
        House modes are driven by the alarm, other modes by tvs.
          parkercP Offline
          parkercP Offline
          parkerc
          @tunnus said in Occupancy - What are people using to check?:
          That’s a new one, I did a quick search and couldn’t see anything specific about that - do you have a link ?
            parkercP Offline
            parkercP Offline
            parkerc
            Hi @therealdb
            @therealdb said in Occupancy - What are people using to check?:
            other modes by tvs.
            Sorry, what do you mean by ‘tvs’?
              Sorry, I meant Televisions. I have a couple of scenes looking at them to adjust lights, or notify people in the room via Alexa only if the tv is on.
                parkercP Offline
                parkercP Offline
                parkerc
                I meant Televisions
                Sorry, I see it now 😂
                What are you doing to check if the TV is on/off, do you have energy metered plugs, or do you have an api call direct to the TV?
                  Both. Dummy TVs are behind a plug and I’m watching for watts to know if it’s on or off. Smart TVs are LG and I have api in place to report current input and volume. Plus, I have a sky Q device to know the current channel being watched on the main tv.
                  I’m turning lights on and off automatically with TVs and adjusting the TTS announcements volume in order to increase it when volume is very high. I also have notifications in place on the TVs (similar to push notification, but local).
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Thanks @therealdb
                    I’m keen to build upon my initial set of scripts, to create something a little more accurate
                    The motion sensors seem to be the best 1st check, but as people can just be sitting still, it’s not perfect, so it’s then those secondary checks I’m keen to do too..
                    I’m using the following script to check for movement via my DSC motion sensors
                    module("xxoccupancy", package.seeall)
                    -- first check if any motion sensors have tripped in the last 15 minute
                    local tt = {}
                    local SEC_SER = "urn:micasaverde-com:serviceId:SecuritySensor1"
                    local sensorsum = 0
                    local sum = 0
                    local next = next -- https://stackoverflow.com/questions/1252539/most-efficient-way-to-determine-if-a-lua-table-is-empty-contains-no-entries
                    for n,d in pairs(luup.devices) do
                     	if d.id:lower():match( "^zone%-" ) and d.category_num == 4 and d.subcategory_num == 3 then
                    		sensorsum = sensorsum + 1
                        	local lasttrip = tonumber(luup.variable_get (SEC_SER, "LastTrip", n) or os.time())
                        	local timeString = os.date(" %Y/%m/%d - %X", lasttrip)
                    		local timediff = os.time() - lasttrip
                        		if lasttrip > 0 and timediff < 900 then
                    				sum = sum + 1
                            		table.insert(tt, { devnum=n, name=d.description, last=lasttrip, ltimeHR=timeString, td=timediff })
                    table.sort(tt, function(a,b) return a.last > b.last end) -- sort highest to lowest
                    if next(tt) == nil then
                    	print("No one is moving")
                    	xxprowl.send_prowl ("VeraPlus (Home)", "Occupancy Notification", "No motion sensors have reported movement within the last 15 mins")
                    	return true
                    else
                    	print(sum.. " out of " ..sensorsum .. " motions sensors, reported movement within the last 15 mins")
                    	for n,d in ipairs(tt) do
                    		print(d.name .. ' was last tripped on ' .. d.ltimeHR .. " - " .. d.td .. " seconds ago")
                    return false
                    I have a Sonos one too, checking to see if anything is being listened to, and an API for Panasonic TVs to check if any are on.
                    I don’t have Sky Q, I’m still on Sky HD, but I’m not checking anything to do with that (yet). You mentioned that you check the channel being watched, what do you do off the back of that information ?
                    • parkercP parkerc
                      Thanks @therealdb
                      local tt = {}
                      local sensorsum = 0
                      local sum = 0
                      				sum = sum + 1
                      	return true
                      else
                      return false
                      @parkerc I have hue lights and I’m adjusting them based on what’s on TV. So, it’s basically doing light automation based on 3 programs (normal, sport, cinema).
                      I’ll probably add an home theater setup later and I’ll use the cinemas and series channels (plus netflix/prime/Disney+) to adjust audio as well.
                      • parkercP parkerc
                        @parkerc something here, in practice I'm using Netatmo plugin in Vera that delivers sound/noise level through API
                          Re. Sound, just be aware that the sampling rate of the Netatmo app is, at best, 10 minutes. So this is probably OK for occupancy when supported by other measurements, but not, for example, for intruder detection!
                          • Black CatB Offline
                            Black CatB Offline
                            Black Cat
                            I mentioned the Merrytec previously, now I've tried it out, it does what it claims.
                            I guess the negative to it is that it needs to be hardwired in.
                            Breathing Detecting Technology
                            Innovative patent energy saving switch.
                            Dry Contacts - Control Lights.
                            ON-OFF automatically, supersedes traditional switch.
                            Only very slight movements are required, detects human breathing.
                            Variable delayed shutdown if light control is enabled.
                            Interference free of flying insects, falling leaves, air flow and wireless signals (WiFi, Bluetooth, 4 or 5G).
                            Adjustable detector settings, suitable for various locations.
                            Available in KNX or Zigbee models.
                            You would need to do a google search to find it in your region
                            aka Zedrally
                            • Black CatB Black Cat
                              @black-cat said in Occupancy - What are people using to check?:
                              Amazing! Just imagine if all HA products did that!
                              Black CatB 1 Reply Last reply
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                One thing I’ve not explored yet, is the seismic sensor that’s in one of the Fibaro motion sensors i have - the manual talks about Earthquake detector mode
                                “FIBARO Motion Sensor can be configured to work as a simple earthquake detector, by setting tparameter 24 value to 4. Reports with scale of the vibrations (dimensionless) will be sent at the time intervals specified in parameter 22. First report will be sent immediately after vibrations have been detected. The minimum value of the vibrations, resulting in report being sent, can be defined in parameter 20. Once the vibrations cease, reports will stop being sent. “
                                Now admittedly I’m in the UK , so not really in earthquake city, but there are some very heavy foot’d people in my house who i could potentially test some occupancy scenarios with e.g. when a particular chair/sofa is sat on, or stepping on something like a door mat, or perhaps it’ll sense when someone walks across a wooden the floor..
                                Any other ideas for a seismic sensor ?
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  To keep the code sharing going, this is what I have to check if any Sonos device in the house is being used.. (I’m always open to any feedback on my coding quality etc.)
                                  module("xxactivesonoscheck", package.seeall)
                                  -- spot check to see any Sonos devices are being used
                                  local sonosserv = "urn:upnp-org:serviceId:AVTransport"
                                  local sonosdevices = 0
                                  local nonactivesonos = 0
                                  	if d.id:match( "^RINCON" ) then
                                      	local state = luup.variable_get (sonosserv, "TransportState", n)
                                  		local status = luup.variable_get (sonosserv, "CurrentStatus", n)
                                  		if string.match(status, "Group driven") ~= "Group driven" then
                                  			sonosdevices = sonosdevices + 1
                                     			if state == "STOPPED" or state == "PAUSED_PLAYBACK" then
                                  				--print(d.id, d.description, state, status)
                                  				nonactivesonos = nonactivesonos + 1
                                  if sonosdevices == nonactivesonos then
                                  	print("Nothing is being played on a sonos device")
                                  	return true
                                  else
                                  	print("Something is being played on a sonos device")
                                  	return false
                                    The d.id:match( "^RINCON" ) is a little crafty. You're relying on the contents of private data of the implementation, which could change any time. Unlikely to change is the device type, so a better check is d.device_type == "urn:schemas-micasaverde-com:device:Sonos:1"
                                    Style-wise, the indenting is corrupted by the mixed use of tabs and spaces for indents. Choose one or the other, but don't mix.
                                    • parkercP parkerc
                                      @parkerc I have some friends using pressure mats attached to sensors to detect chairs or coach being in use. I’m not sure earthquake sensors make any sense, even if I’m living in an active earthquake zone.
                                        Black CatB Offline
                                        Black CatB Offline
                                        Black Cat
                                        @akbooer said in Occupancy - What are people using to check?:
                                        and there lays the difference between Home Automation and Building Management products - notably the price difference between amateur and professional use.
                                        At the end of the day you get what you pay for.
                                        aka Zedrally
                                        • parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          Hi all,
                                          In the process of doing this, I’ve created a number of occupancy check scripts, each one of them is currently it’s own module (i think that’s the correct term)?
                                          xxoccupancy-motion.lua
                                          xxoccupancy-sonos.lua
                                          xxoccupancy-lights.lua
                                          xxoccupancy-tvs.lua
                                          I’ve done this to make each one manageable, with each one ultimately running a global function that will return either true or false if the occupancy criteria check is meet (true for no activity, false for recent activity)
                                          • Although saying that, I’m probably going to make the ‘lights’ one the target now, , so if no motion, tvs or sonos are found in use, (thus all true) then run the other one, to turn off all known lights.
                                          Is that a good approach, or would dofile() be better, or should I simply put them all to one ‘module’ ? How would you approach doing multiple assessment/checks ?
                                            retireditguy
                                            143.4k
