  3. Help please cannot login to Debian / MSR box
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
7 Posts 2 Posters 1.4k Views 2 Watching
    The Debian Linux machine that MSR is running on, has developed an issue and I can no longer login to it via SSH or directly on its terminal.
    It was fine earlier this morning I connected to it via WinSCP to copy all the MSR files down for a backup to my laptop.
    Then a bit later I could no longer connect to it. Either in WinSCP or Putty SSH, it now says access denied, even though my password is correct.
    I then connected a monitor and keyboard up to the Debian box and I cannot login to it directly either, I put in the username and hit enter and I am not given a password prompt to enter it and something I could not read flashes up on the screen very fast and then disappears. I had to record a video and skip through it to capture what is says, see screen capture below.
    I tried logging in as user root and my own username same thing happens, it does not even give me a prompt to enter a password.
    If I boot the box in to Debian recovery mode instead I am able to login as the root user OK.
    Any ideas how to fix this?
    • cw-kidC cw-kid referenced this topic on
      Wow I managed to actually fix something in Linux 🤣
      I moved the pam.d folder back into the root of the /etc folder and now I can login again in the regular terminal.
      WinSCP and Putty are working again also.
      No idea how that pam.d folder got moved I didn't do it to my knowledge.
      • cw-kidC cw-kid
        @cw-kid when you boot into recovery mode, have you checked the available disk space? Often when a volume gets full, it has nasty effects on the daemons. And of course, you should look in the system log files for clues.
          Disk space looks OK I think.
            These are the log files I can see in /var/log
            There is a lot of log files in there, wouldn't really know where to start looking through that lot..
            However looking in auth.log now, I see a lot of failed login attempts from my laptop via SSH for some reason and also entries for failed login /dev/tty1
            PAM no modules loaded for login service.
              I don't appear to have a /etc/pam.d folder on this Debian 10 box with the login issues.
              Looking on another Debian 11 box that is currently running Ezlo SoftHub / Vidoo (CCTV stuff) I do see an /etc/pam.d folder on that one.
              Could this be the problem ?
              Just aimlessly Googling but not many search results about it.
                Ran this command
                find / -type d -name "pam.d"
                The only result was
                /etc/python2.7/pam.d
                  • cw-kidC cw-kid has marked this topic as solved on
