  4. Can't upgrade package dependencies [Windows10]
6 Posts 2 Posters 1.4k Views 2 Watching
    Andr
    Preparing for an upgrade to latest msr build, and got stuck on upgrade package dependencies.
    Then I remembered that this was the case last time the upgrade package dependencies was required also. After a lot of trying i gave up and did a clean install of everything. But since this happens again I would love to get this sorted out.
    It might be that the manual regarding node js should be updated. Or more noob-proof? I have a vague memory that the very first install required som searching to get node js up and running.
    What I have done so far.
    Stop reactor service.
    Delete package-lock.json
    Uninstall reactor service. (command prompt with admin)
    c:\reactor>node tools\install_reactor_windows_service.js -u .
    Uninstalling Reactor service c:\reactor
    Reactor service uninstalled.
    Unzip new version.
    Delete package-lock.json (again)
    c:\reactor>npm install --no-save --omit dev
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module 'C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
      throw err;
    ←[90m    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)←[39m
    ←[90m    at Function.Module._load (node:internal/modules/cjs/loader:778:27)←[39m
    ←[90m    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)←[39m
    ←[90m    at node:internal/main/run_main_module:17:47←[39m {
      code: ←[32m'MODULE_NOT_FOUND'←[39m,
      requireStack: []
    Going wild and testing command from new installations.
      throw err;
      requireStack: []
      throw err;
      requireStack: []
    c:\reactor>npm install --loglevel error --no-save --omit dev
      throw err;
      requireStack: []
      throw err;
      requireStack: []
    What module is needed?
    Were to find it?
    What to do with it?😕
      Andr
      Finally!
      Tried out almost every google result I could find I found something that worked.
      Repair the nodejs install from windows control panel did the trick ✌
      npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
      added 1 package, removed 6 packages, changed 3 packages, and audited 91 packages in 6s
      13 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      npm notice
      npm notice New minor version of npm available! 8.11.0 -> 8.18.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.18.0
      npm notice Run npm install -g npm@8.18.0 to update!
      npm notice
      c:\reactor>
        Yeah, your NPM was broken.
          Andr
          Any idea what could cause this?
            I trust the government more than I trust Windows. I'll leave it at that.
              Andr
              @toggledbits said in Can't upgrade package dependencies [Windows10]:
              Hard choice... 😁
                154.3k
