  3. Looking for alternative to Gcal3 in Vera for MSR and public calendar
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
2 Posts 2 Posters 730 Views 2 Watching
    Good morning all,
    I'm working on weaning myself off of being totally Vera dependent. I've installed MSR on my Fedora home server, and I've been migrating luup Reactor rules over little by little. My hope is to use Vera as a bare bones z-wave hub, until I replace it either with Ezlo (not so sure about), or perhaps Hubitat. I'm just tired of zero new development in Vera, empty promises of native device integration, and cloud services that go down and leave my automation hanging.
    In any case, I digress. I've attempted to use Gcal3 on Vera to integrate Public calendars, such as Federal Holidays, School Calendars, etc. It use to somewhat work, but more often than not, all I get from Gcal3 is "token error code: HTTP/1.1 400 Bad Request". The developer no longer is active, and it's effectively not working anymore.
    I'd like to use these public calendars as Entity Attributes or Constraints in MSR. For instance, if it's a Federal Holiday, I don't have to work, and I may want to sleep in, which means lights may not come on as early, window coverings in the bedrooms may open later in the day, etc. Similar idea with a school calendar. If "closed" is in the event, my daughter may want to sleep in, and not want the window coverings opened as early.
    I'm aware that Ezlo has integration through NuCal to all sorts of web based services, including Google Calendar, but as I stated earlier, I'm undecided on going down that path. Is there anyway to do this on MSR through any of it's abilities, such as HTTP calls or MQTT ( not experienced in MQTT, so I don't know now it works really).
    Has anybody already done this?
    Thanks for any advice in advance.
    • T tamorgen
      Good morning all,
      @tamorgen I'm using webcal.guru, but not under MSR (and for Italy), but here's the calendar for US Federal Holidays:
      https://www.webcal.guru/en-US/event_list?content=calendar_content&calendar_id=holidays
      it's free and it's very reliable and I'm using it for the very same reason, and to drive my RGB outdoor lights based on the variable holidays.
        164.7k
