  4. Issue with HTTP API
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Issue with HTTP API
8 Posts 2 Posters 2.6k Views 2 Watching
  • E Offline
    E Offline
    eonnet
    Hello @toggledbits I have a strange issue with the HTTP request that i send to Reactor.
    I have two reactors one on a Unraid server and one on Ubuntu server installed as a docker, when i send http get request to the Unraid server to control home assistant entity everything is going ok, but when i send the same request to the ubuntu modified accordingly it says "Request failed" but when i try to run reaction via http request it works.
    When i go to entities and try to control the entity manually its working.
    Any idea's?
    Best regards
      First, you need to show your work (per the posting guidelines). That means showing the reactions, and the requests, and the responses to the requests, and describe how you are making the requests (curl, etc.-- what is the "it" that is giving you "Request failed"). If the requests are being made in Reactor, what is being logged?
      Second, I find this statement contradictory, and it needs clarification:
      Please update your original post.
      • E Offline
        E Offline
        eonnet
        wrote on last edited by eonnet
        Hello @toggledbits im trying to control reactor from external source, for this example i'm using web browser.
        (this is example for the docker installation on ubuntu server)
        When i hit a web page http://192.168.0.39:8111/api/v1/entity/hass_container>climate_vivax/perform/hvac_heating_unit.set_setpoint?setpoint=26
        i get a response
        'Request failed'
        and the action is not executed
        When i hit a web page http://192.168.0.39:8111/api/v1/reaction/re-lb1bejbo/run
        i get response
        {"status":true,"message":"Vivax Off started"}
        and the action is executed
        On the unraid server docker installation when i hit http://192.168.0.81:8111/api/v1/entity/hass>climate_vivax/perform/hvac_heating_unit.set_setpoint?setpoint=26
        i recieve a response
        {"status":true,"message":"Performed hvac_heating_unit.set_setpoint on Thermostat#hass>climate_vivax"}
        when i hit http://eonnet.duckdns.org:8112/api/v1/entity/hass>climate_vivax/perform/hvac_control.set_mode?mode=off
        {"status":true,"message":"Performed hvac_control.set_mode on Thermostat#hass>climate_vivax"}
        and the action is executed.
        Best regards
        • E Offline
          E Offline
          eonnet
          I tried tonight with curl and postman i get the same response
          request failed
          no further info.... this is only happening when i try to make a request to entity.
          I also tried to make a reaction with the http request to reactor and the response is:
          Reaction "re-lb2sork5" (re-lb2sork5) step 1 http request failed
          Error: HTTP request failed: 400 Bad Request
          I hope this gives you more info
            What did you find in the reactor.log file?
            E 1 Reply Last reply
              E Offline
              E Offline
              eonnet
              @toggledbits here is the log
              [latest-22328]2022-11-30T19:58:30.832Z httpapi:ERR httpapi: perform hvac_heating_unit.set_setpoint on Thermostat#hass>climate_vivax failed: [TypeError]Typ>
              [latest-22328]2022-11-30T19:58:30.834Z httpapi:CRIT TypeError: Type mismatch on config reactor.engine.monitored_entities, expecting array, got object
              at Configuration.getConfig (/opt/reactor/server/lib/Configuration.js:163:23)
              at Function.getConfig (/opt/reactor/server/lib/Configuration.js:151:82)
              at HTTPAPI._handlePerformRequest (/opt/reactor/server/lib/httpapi.js:834:56)
              at /opt/reactor/server/lib/httpapi.js:396:61
              at Layer.handle [as handle_request] (/opt/reactor/node_modules/express/lib/router/layer.js:95:5)
              at next (/opt/reactor/node_modules/express/lib/router/route.js:144:13)
              at Route.dispatch (/opt/reactor/node_modules/express/lib/router/route.js:114:3)
              at /opt/reactor/node_modules/express/lib/router/index.js:284:15
              at param (/opt/reactor/node_modules/express/lib/router/index.js:365:14)
              and another on with different request
              [latest-22328]2022-11-30T20:02:22.335Z httpapi:ERR httpapi: perform hvac_control.set_mode on Thermostat#hass>climate_vivax failed: [TypeError]TypeError: T>
              [latest-22328]2022-11-30T20:02:22.336Z httpapi:CRIT TypeError: Type mismatch on config reactor.engine.monitored_entities, expecting array, got object
                OK. It looks like you've formatted your monitored_entities configuration incorrectly on that Reactor install. That seems to be the error. Either remove that section, or review the documentation and get it fixed.
                • E Offline
                  E Offline
                  eonnet
                  @toggledbits yes that was the problem, thanks on the fix.
                  Best regards
                    165.7k
