  3. Separate switching bulb in one ceiling light
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
  • P Offline
    P Offline
    phaetoncz
    Hello guys,
    I would like to achieve two different things with lights, but I am not sure it could be done. I am starting with smart things, and I am far from any electrician knowledge, wo any help is really appreciated.
    I have dumb switches in my hall, controlled from 3 places. I understood that installing one smart module before first switch will make them "hybrid", both smart controlled and dumb controlled.
    I would like to buy ceiling light with two bulb sockets. What I would like to achieve is I would like to have one bulb for normal daily usage (lets say cold white full brightness), and second for night time (aprox from 10pm till morning) with some red/orange - minimum brightness.
    So question are:
    1. Is there a way to keep both bulbs turning-on separated? So only one will be on during day, and then only second during night?
    2. And could that be done with pressing dumb switch? What would I need to achieve it? (maybe another module into the ceiling lights)
    Thank you in advance
      Yes. You'd need to have one of the switches as a smart switch which can control the bulbs remotely. I'm thinking of Shelly devices for this application, where they would control the smart bulbs over WiFi, or Bluetooth, and not actually remove power from the light itself.
        Sounds like your best bet would be two smart bulbs if you want to achieve independent operation.
        • P Offline
          P Offline
          phaetoncz
          Thank you @akbooer, counting with that. But I am afraid that remaining dumb switches would turn both lights on at once, is that so? Not really sure what all I can do within smart bulb settings.
            • P Offline
              P Offline
              phaetoncz
              Thank you. Those shelly modules looks really well made (hardware and more importantly software-wise). However I wanted to go zigbee way with bulbs etc. Do you think I can do that?
              • P phaetoncz has marked this topic as solved on
                138.0k
