  3. A topic for self learning...
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
3 Posts 2 Posters 951 Views 2 Watching
    ...which I'd like to do. I know I go about these things all wrong (namely think of something I'd like to do, then try and work out what I need to know) but that's me 🙂
    Just looking for some pointers on what I should google for really:
    What I'd like is to provide a selection of (basically two word) phases which I can select from randomly (or even pseudo randomly) and pass to Alexa to be spoken. There are 10 such phrases only.
    So what should I be reading up on to get me started?
    TIA for any guidance
      Which bit of that is the one you need to research?
        @akbooer <hangs head>
        Um all of it except (probably) sending the message to Vera TTS
        I imagine I might be able to make 10 separate reactions and somehow fire them pseudo randomly, but that seems in-elegant and I suspect there would be a far better way
          154.3k
