  3. MIOS - UI5 web login
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
10 Posts 4 Posters 2.7k Views 3 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    Can anyone help with the MIOS UI5 weblink? Not the getvera one.
    Still running UI5 on a couple of sensors & lights and need to tweak PLEG but for the life of me I can't remember the link to tunnel back to the trusty machine....
    aka Zedrally
      Black CatB Offline
      Black Cat
      bump....anyone, I surely can't be the last person with a Vera Lite still deployed?
      aka Zedrally
      • C Offline
        C Offline
        christian_fabre
        MiOS
        • C Offline
          C Offline
          christian_fabre
          https://cp.mios.com/login.php```
          MiOS
            Black CatB Offline
            Black Cat
            ^^^ Thanks, unfortunately it returns
            Not Found
            The requested URL /login.php``` was not found on this server.
            Looks like MIOS have retired the site. Vale Vera Lite & Vera 3, you both gave more than expected and I'll miss you.
            aka Zedrally
              I tried this yesterday and it seemed to work to the extent that I could see that the UI5 VeraLites that I used to have were still registered…
              • C Offline
                C Offline
                christian_fabre
                MiOS
                click on the link(cp.mios.com/mysystems.php)
                • D Offline
                  D Offline
                  dcmChrissy
                  wrote on last edited by dcmChrissy
                  After a long (8+ months) period of non-access, I am again able to login remotely through mios. Believed (unconfirmed) the issue was a redirection to fwd4 vs. fwd3 which was my previous default. I can currently successfully test by:
                  1. Browsing to https://status.getvera.com/
                  2. Under Portal (Legacy - UI5) clicking the "Login & User Accounts" link redirects to my Vera 3 (UI5)
                  Keep in mind that this did NOT work for the longest time. I tried a few Tech Support tickets via the Vera and also a plea on their forum. For the heck of it, I tried to access via status.getvera.com and one day I was surprised that it works again (but now using fwd4)
                  Also, the less secure link via ALTUI of:
                  https://fwd4.mios.com/USER/PASSWORD/ACCESSPOINT/data_request?id=lr_ALTUI_Handler&command=home#
                  . . . works again.
                  ![UI5-RemoteLogin.PNG](Something went wrong while parsing server response)
                  (Unable to upload screenshot .png at this time)
                  EDIT: perhaps not enough posts to allow me to "Upload Image"
                    Black CatB Offline
                    Black Cat
                    Thanks for the help but now I've forgotten my User name, Password and the email that I used all those years ago.
                    As much as I hate to do it, I have no option other than to retire the unit.
                    aka Zedrally
                      A factory reset, and re-registering doesn’t work? Perhaps it’s not allowing new accounts, though… Ah well, it had to happen sometime.
                        141.4k
