  3. Alexa skill for Open Luup / Zway
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
8 Posts 4 Posters 2.1k Views 4 Watching
    Is there one? I know TTS is working but suddenly woke up at 0300....
    ...or does it just use Vera. That seems unlikely from what I know of the architecture
    TIA
      There isn’t one no.
      A skill is a plugin stored in your amazon echo account in the cloud. It relies on a cloud to cloud structure by binding to another cloud service which then has access to your vera. OpenLuup does not offer such a cloud service.
      There is however a Habridge which emulates a Philips hue bridge locally and offers a similar service and instead of running in the cloud, can run on anything which runs java... Which is pretty much anything. I run mine on my openLuup machine.
      The advantages is massive:
      No more cloud to cloud which exposed your hub directly to another server. It is much more secure. It is also much more reliable since it does not rely on another cloud server and its connections which all have their reliability issues. It is also significantly faster with your command travelling a much shorter distance and the lag now being reduced to only the cloud based voice processing.
      The downside is that all your commands need to be sent as if they were lights and get some getting used to... “turn on the curtain” etc but you can dim. “Set the radio volume to 20”.
      https://smarthome.community/topic/41/voice-control-and-tts-projects
      It seems like there is a skill for z-way but I never tested it. Have no interest or need for it since the habridge is a superior solution in every way.
      TTS is something else...
        Cheers chap!
          I was toying in the past with this idea, but LUA is still hard for me. Something like ha-bridge, but offered as a native plugin in openluup/vera, just like the components you can find in Home Assistant or openHab.
            @therealdb I got this running in about 30 minutes tops.....
              So, I finally switched myself to HA bridge. This was caused by me using IFTTT with some local commands (bridged thru my own cloud server).
              Wow, I'm impressed 🙂 and that's because I can call my own local endpoints, so I can finally build more routines to please the wife. Happy wife, more automations! 😄
                sender
                HA bridge is really great! It works fast and stable. One other big advantage is that it is capable of doing mapping of "multiple names to 1 device"... alexa turn on cast, did you mean guest? No cast, did you mean cause? No! I have now multiple line for 1 device, never an issue...
                As you say...
                Happy wife more automations <--> more automations happy wifE.
                  Yes, I grouped a couple of roller shutters and lights. Plus, I can call my own http modules. Wonderful piece of tech.
                    147.1k
