  3. Recover an ‘assumed bricked’ Vera Secure
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
45 Posts 5 Posters 21.5k Views 5 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi @therealdb - yep and they finally got back to me..
    It seems according to their records, the controller I picked up 2nd hand was declared defective and replaced a while back. And when this happens, and the hardware is not returned, a call is sent to the unit to deactivate it and it gets permanently banned from their servers. This means the controller will not connect anymore so it won’t pick up an updates and they are not allowed/able to provide support...
    As I have command like access to it, I’m wondering what I can still do with it.
    Any ideas anyone ?
      #42
      That makes sense. One thing you can do with it is to not use it as a vera anymore and "nuke" it... Turning it into a zwave and zigbee radio host for another controller (homeseer, home assistant, domoticz). It is very likely that it was bricked due to a flash memory failure which is a sign that it would not have run reliably with any vera firmware anyway. You can look up my nuke vera script here:
      GitHub - rafale77/Nuke-Vera: Script to neuter the vera and broadcast its zwave and zigbee serial ports
      Script to neuter the vera and broadcast its zwave and zigbee serial ports - rafale77/Nuke-Vera
      I have run this way for quite sometime using the vera's zigbee hardware as a zigbee stick for home assistant's ZHA component and the same can be done with zwave using any other controller software.
      • parkercP Offline
        parkercP Offline
        parkerc
        Nice idea - can any other controller software be installed directly on the Vera ?
          Theoretically yes but I wouldn't know why. It has limited storage space which is poorly partitioned, runs on a very old version of openWRT OS and the CPU is weak. It would take you to recompile the controller to MIPs from source. Really not worth the trouble IMHO when computing power has become as cheap as it has.
          • parkercP Offline
            parkercP Offline
            parkerc
            Thanks @rafale77
            I’ll admit it feels like a bit of a waste not to be able to make use of it all - but you make a very good point -
            My next challenge then will be getting your nuke-Vera script onto the controller via the usual/external USB port..
              162.9k
