  3. Yale Smart Lock
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
Yale Smart Lock
2 Posts 2 Posters 1.6k Views 2 Watching
  • N Offline
    N Offline
    Nick521
    Looking for a recommendation:
    1. Locksmith is trying to talk me into the Yale Assure Lock Touchscreen with Wi-Fi and Bluetooth - the original 1st generation because they said it's built better than the Assure Lock 2. Any thoughts on this? Which would you recommend?
    2. I see Mul T Lock makes a cylinder (KW-KIDYRL) for Yale Smart Locks. Would this fit the 1st gen Assure Lock, as well as Assure Lock 2? Has anyone tried replacing the cylinder with this on either lock?
    3. Other smart lock I was considering is the Schlage Encode Plus.
      theabraham90
      Hi, @Nick521
      I see the Yale Assure Lock Touchscreen 1st gen a sturdy choice, but newer versions might have extra perks. The Mul T Lock cylinder could fit, but it's wise to double-check with the manufacturer or locksmith for compatibility on both Assure Lock versions.
      On the flip side, the Schlage Encode Plus is a strong contender with its advanced security features. It's like navigating a maze of options, but consider what features matter most to you and if they align with your needs. It's a bit of a tech puzzle, but finding the right fit is worth the effort!
        376
        151.4k
