  3. Plugins
  4. Alarm Clock
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
Alarm Clock
44 Posts 5 Posters 16.9k Views 4 Watching
    What @Elcid said. Plus, an Alexa routine has the ability to have delay. So you are able to trigger a virtual sensor, then wait some seconds, then execute other logic. I'm using to lower the light gently, that's what you want, after all (but applied to volume).
    You're using my own VeraAlexa, so you can always write a scene to increment volume recursively. it's not that difficult, and I think you'd do the same with Reactor.
    Meta code:
    • Start a radio station
    • Every 30 seconds increment volume by 10%, unless you reach 60%
    Since you're on openluup, you can execute anything you want from VeraAlexa, or just trigger routines. Your options are endless 😉
      So, to be more useful to you 😄
      • Option A: do everything in an Alexa Routine
      • Option B: trigger a virtual sensor from an Alexa Routine, then execute the logic in Reactor
      • Option 😄 trigger a virtual sensor from an Alexa Routine, then execute some login in Reactor, and use delay in Alexa Routine to manipulate its volume
      On the when in Alexa routine, choose "when an alarm is dismissed" or similar. Sorry, I've the Italian version right now, but that should be very similar in words.
        Cheers, but you misunderstand the problem :). (Which is pretty much solved)
        I have a virtual switch that triggers a reactor sensor and deals with all the volume (through a decent sounding system, not an Alexa) 😉
        What I wanted was the ability to tell Alexa. 'Flick this switch at 0630'. Which does not appear to be possible.
        'Run routine A' where 'routine a' has a delay before it does anything seems possible, but not really what I want. That would be like going to bed and setting your alarm clock to wake you up in 8 hours and 27 minute. Plus you'd have to change the delay every time, or trigger the routine at the same time every day, which puts us back to square one....
        I'm probably missing something 😄
        ElcidE 1 Reply Last reply
          ElcidE Offline
          ElcidE Offline
          Elcid
          Ok this is possible in node-red just trying to figure out how to cancel the alarm after it is set up. At the moment this works but alarm volume would have to be 0.
          The flow listens for alarm to be set, then sets a timer according to alarm set time. It the waits and turns on the virtual switch at set time (or within 30 seconds on set time)
            Cunning. I don't use node red (yet)
            Hell I barely use Z-way. The alarm clock plug is not perfect but it's pretty close. I wonder if it's possible to use HA bridge to send the hh🇲🇲ss data to it. I shall have a prod
            Cheers!
              Cheers!
              ElcidE Offline
              ElcidE Offline
              Elcid
              wrote on last edited by Elcid
              #26
              Ok when you do, I figured out how to set alarm, then dissmiss it. Then set delay and turn on a smart devce. Silently.
              [{"id":"8bedb699.d603f8","type":"tab","label":"Flow 5","disabled":false,"info":""},{"id":"432fd979.196188","type":"alexa-remote-event","z":"8bedb699.d603f8","name":"","account":"f4d129f8.797b8","event":"ws-device-activity","x":100,"y":120,"wires":[["754b28f7.c15cb8"]]},{"id":"754b28f7.c15cb8","type":"function","z":"8bedb699.d603f8","name":"","func":"if (msg.payload.description.summary.includes(\"set alarm for\")) {\n    var d = new Date();\n    msg.delay =  Math.round(msg.payload.domainAttributes.triggerTime - Date.now() );\n    //msg.payload = { \"type\": \"music\", \"payload\": { \"device\": \"Lounge\", \"provider\": \"SPOTIFY\", \"search\": \"cancel alarm\", \"duration\": 0 }}\n    return msg;\n}else{\nreturn [null,msg];\n}","outputs":2,"noerr":0,"x":270,"y":120,"wires":[["4e3f2fe.02b6c5","1c963ab3.8c9cad"],[]]},{"id":"fc90f5eb.556d18","type":"alexa-remote-routine","z":"8bedb699.d603f8","name":"","account":"f4d129f8.797b8","routineNode":{"type":"node","payload":{"type":"serial","children":[{"type":"smarthome","payload":{"entity":"6da282d1-a18e-477e-a4f4-c377ed4f4f2b","action":"turnOn"}}]}},"x":630,"y":120,"wires":[[]]},{"id":"4e3f2fe.02b6c5","type":"delay","z":"8bedb699.d603f8","name":"","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":440,"y":120,"wires":[["fc90f5eb.556d18"]]},{"id":"1c963ab3.8c9cad","type":"alexa-remote-other","z":"8bedb699.d603f8","name":"","account":"f4d129f8.797b8","config":{"option":"removeNotification","value":{"notification":{"type":"msg","value":"payload.domainAttributes.notificationId"}}},"x":660,"y":60,"wires":[[]]},{"id":"f4d129f8.797b8","type":"alexa-remote-account","z":"","name":"alexaremote2","authMethod":"cookie","proxyOwnIp":"192.168.1.25","proxyPort":"3456","cookieFile":"","refreshInterval":"15","alexaServiceHost":"layla.amazon.co.uk","amazonPage":"amazon.co.uk","acceptLanguage":"en-UK","userAgent":"","useWsMqtt":"on","autoInit":"on"}]
                Amazing thanks. I think I'll try HA as well 🙂
                  Well:
                  curl 'http://127.0.0.1:3480/data_request?id=action&output_format=json&DeviceNum=46&serviceId=urn:upnp-org:serviceId:VClock1&action=SetAlarmTime&newAlarmTimeValue=08:00:00'
                  Sets the alarm time to 08:00:00 which is perfect. Just need to pass the value from Alexa now
                  • ElcidE Offline
                    ElcidE Offline
                    Elcid
                    So how do you make it dynamic, i.e. "set alarm for 6.45 am" or "set alarm for 7pm monday"
                      Well that's the interesting bit. With most HA stuff you pass a variable.
                      With my thermostat:
                      http://127.0.0.1:3480/data_request?id=action&output_format=json&DeviceNum=20300&serviceId=urn:upnp-org:serviceId:TemperatureSetpoint1_Heat&action=SetCurrentSetpoint&NewCurrentSetpoint=${intensity.percent}
                      So if I say 'Alexa, set the thermostat to 22, the call beccomes:
                      http://127.0.0.1:3480/data_request?id=action&output_format=json&DeviceNum=20300&serviceId=urn:upnp-org:serviceId:TemperatureSetpoint1_Heat&action=SetCurrentSetpoint&NewCurrentSetpoint=22
                      Obviously if I was to say '99' we'd have a problem but I'm unlikely to....
                      Not finding a way to send '07:00:00' yet though
                        Well got as far as setting it to the hour:
                        http://127.0.0.1:3480/data_request?id=action&output_format=json&DeviceNum=46&serviceId=urn:upnp-org:serviceId:VClock1&action=SetAlarmTime&newAlarmTimeValue=${intensity.percent}:00:00
                        Not sure there's anyway of passing the minute variable, sadly
                          #32
                          Hmm, apparently there is, but struggling with Alexa at the moment:
                          For the items that want to have a date time put into the message, utilize ${time.format(yyyy-MM-ddTHH🇲🇲ssXXX)} where "yyyy-MM-ddTHH🇲🇲ssXXX" can be any format from the Java SimpleDateFormat documented here: https://docs.oracle.com/javase/8/docs/api/java/text/SimpleDateFormat.html. Also, there is a ${time.millis} which will put the millis timestamp where this replacement control is located.
                          I only want to pass HH:mm. I can tag 00 at the end but there's something amiss.
                          http://127.0.0.1:3480/data_request?id=action&output_format=json&DeviceNum=46&serviceId=urn:upnp-org:serviceId:VClock1&action=SetAlarmTime&newAlarmTimeValue=${time.format(HH:mm)}:00
                          If anyone can point me in any direction, that would be lovely but...
                            I don't think it can pass more than one number. Remember that the habridge is actually a hue emulator. It passes light commands which is why it works locally because it was one of the two devices the amazon echo talks to directly without going to the cloud.
                            The trick to pass the number was to make alexa think it was passing a dim level.
                              “Alexa, wake me up at 8 am”.
                              Then, an Alexa routine will do whatever you want, when the alarm goes off. Believe me, it’s simpler than you think. Try it.
                                @rafale77 said in Alarm Clock:
                                Seems a bit odd specifying in the documentation that it can pass date / time formats then, no?
                                Oh well 😉
                                  @therealdb said in Alarm Clock:
                                  Trying it now but I expect it to play a noise (as well as possibly trip the switch).....
                                  I created a routing called 'Wake up' which runs when I say 'Alexa, wake me up'
                                  We shall see in about 5 minutes
                                  Cheers
                                    Oh well 😉
                                    @CatmanV2
                                    I just went and check and I think you misread the documentation. The bridge can pass time format to devices. Alexa can't. Other hubs can talk to one another and the bridge can pass time between them if they can send it to the bridge. Or you can define a time manually within the bridge to pass it to another hub. The echo cannot pass time to a hue hub so it can't do it with the habridge either. These are the commands the echo support with the bridge:
                                    Ask Alexa
                                    After this Tell Alexa: "Alexa, discover my devices". If there is an issue you can go to the Menu / Settings / Connected Home for the echo on the mobile app or your browser and have Alexa forget all devices and then do the discovery again.
                                    Then you can say "Alexa, Turn on the office light" or whatever name you have given your configured devices.
                                    Here is the table of items to use to tell Alexa what you want to do, this has changed over time due to Amazon reserving words for skills:
                                    To do this...	Say this...
                                    ON Commands	Alexa, turn on <Device Name>
                                    OFF Commands	Alexa, turn off <Device Name>
                                    DIM Commands	Alexa, brighten <Device Name> to <Position>
                                    DIM Commands	Alexa, dim <Device Name> to <Position>
                                    DIM Commands	Alexa, set <Device Name> to <Position>
                                    To see what Alexa thinks you said, you can check in the home page for your Alexa.
                                    To view or remove devices that Alexa knows about, you can use the mobile app Menu / Settings / Connected Home or go to http://echo.amazon.com/#cards.
                                      @CatmanV2
                                      Ask Alexa
                                      Ahhh gotcha! Shame that 🙂
                                        Cheers
                                        @CatmanV2 said in Alarm Clock:
                                        Cheers
                                        Yep it played a noise which is exactly what I don't want it to do. All I want it to do is silently flick a switch at a dynamic time. Routines can be scheduled on a regular basis which would do the same as setting the alarm clock in Openluup, a bit easier than the on the web UI I guess but looks like that's the limit. Unless I'm (still) missing something! 😉
                                        • ElcidE Offline
                                          ElcidE Offline
                                          Elcid
                                          #40
                                          I now have node-red setting a silent switching of a v device, by saying "wake me up at [any time and/or day]". also depending which echo i use i can set a different v device, so different morning routines for each bedroom.
                                          @catman you can also do all your H A Bridge devices in node red to, as it has the local hue lights bridge to. So you could replace H A Bridge with node-red. It would not be difficult to set a http request to set your virtual alarm.
                                            145.2k
