  3. Plugins
  4. MQTT Plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
MQTT Plugin
72 Posts 8 Posters 37.0k Views 9 Watching
    Slightly OT. Overall I like lua, but I miss the simple approach to non-blocking code offered by c# and even JavaScript. That’s particularly bad when doing network/http call, because it’s very difficult to write async code.
      There’s no fundamental difficulty in writing non-blocking I/O. The openLuup server module and scheduler allow callbacks on incoming. The HTTP async code has a separate module simply because of its entanglement within the LuaSocket HTTP module.
        @akbooer said in MQTT Plugin:
        well, I was speaking about an async/await first approach, with lambdas/promises. co-routines are just OK.
        maybe I'm too biased because I'm used to the other approach and I still spend most of my time writing C#/Javascript instead of LUA. I wish it was simpler - let's say - to execute 3 HTTP calls under Vera in parallel, each having its own response handler inline.
          @therealdb said in MQTT Plugin:
          So this isn't good enough...?
          local async = require "http_async"
          async.request ("http://request1",
            function  (response, code, headers, statusline)
              -- response code 1 here
            end)
          async.request ("http://request2",
              -- response code 2 here
            end)
          async.request ("http://request3",
              -- response code 3 here
            end)
            Oh, I missed this.
            It could greatly benefit to my own HTTP plug-in. Any plan to release as a plug-in on Vera itself?
              #26
              Yes, it already works on Vera.
                ...if you excuse a link to the other place:
                https://community.getvera.com/t/openluup-asynchronous-i-o/206267/15
                  #28
                  Well my frustration is not so much with http, though I did have my run ins with it and ended up using libcurl due to... digest not working somehow on luajit with luasocket but at this moment, I am finding that:
                  1. the luarocks version of the MQTT library uses the luasocket in a blocking fashion. It does connect fine to the MQTT broker though.
                  2. the vera-mqtt plugin is full of little bugs causing it to not work as a subscription client. For example the library fails to declare the socket variable, It crashes with an empty socket call to SSL when SSL is not needed etc... I have not been able to make it connect to the mosquitto broker even after fixing all the problems I found...
                  Sadly, I may have to move back to python and have home-assistant being the MQTT bridge.
                  K 1 Reply Last reply
                    As I already said, I wrote my own bridge in c#. I might make it more general purpose and release it. It’s a process running inside .net core and as ha-bridge could be installed separately, but pointing to openluup.
                    Let’s see if I find some motivation. It’s very lightweight, since it’s just one library running in a console app, and .NET Core 3.1 is very performant.
                      K Offline
                      K Offline
                      kfxo
                      @rafale77 said in MQTT Plugin:
                      1. the vera-mqtt plugin is full of little bugs causing it to not work as a subscription client. For example the library fails to declare the socket variable, It crashes with an empty socket call to SSL when SSL is not needed etc... I have not been able to make it connect to the mosquitto broker even after fixing all the problems I found...
                      I have had good success with the plugin I linked to above. Currently I have 9 different child devices subscribing to at least 15 different topics. I did modify the plugin slightly, not to get it to work, but to allow for child devices to have any designated number of subscriptions, include availability, state, and command topic subscriptions, and I added actions/functions for reconnecting to the mqtt server and reconnecting subscriptions.
                        Well I made some progress and got it to connect to the broker but it is extremely fragile. Digging into it deeper, it actually relies on a periodic call of a "handler" function in the library to check for messages from the broker. The call fails regularly and is not very well written in the sense that it defeats the purpose of MQTT by doing a poll.
                        There are a number of forks of this library which attempted various fixes and they have had various degree of success.
                        Not judging the plugin itself but rather the MQTT library. I actually took quite a bit from the plugin for these tests. Still work in progress but I am pretty pessimistic.
                          #32
                          Update: I now have a kind of a working solution and it is interesting...
                          The fundamental problem is that setting up an MQTT client to listen to the broker blocks the luasocket and therefore openLuup.
                          The two libraries use different approaches to the problem.
                          The older library used by the vera MQTT plugin uses a handler function which polls the broker and gets and closes immediately regardless of getting a message or not. It therefore won't block the luasocket but it comes back empty 99% of the time and really relies on luck to catch a message as it can miss them. Basically unusable.
                          The newer lua library does the same but waits for a message back and blocks the luasocket while waiting. If one sets a high polling frequency without getting a message back, openLuup hangs. My solution to this has been to significantly increase the frequency of messages from the publishing client to unblock the socket. It really is no longer event based and this generates a lot of traffic.
                          If anyone has better suggestions (@therealdb I look forward to your bridge). I am also thinking that openLuup could use moving all its http traffic from luasocket to libcurl...
                          Edit:
                          I ended up giving up on trying to make it work with luasocket and spent 2min setting up 4 MQTT subscriptions on Home Assistant and another 10 to build the bridges back into openLuup. I really hoped to be able to do have a direct pipe into openLuup...
                          akbooerA B 2 Replies Last reply
                            @rafale77 right now I'm using it to process incoming messages and update variables on Vera/Openluup. Do you want to call service endpoints as well? I can make it really generic and call HTTP endpoints, if needed. So you can
                            I don't use it so much to send messages, but I think we could add this later, if needed.
                            I can also try to put a relay feature, to receive incoming messages and then publish them back to another broker.
                            It's based on a JSON config file and you have to map it manually, but then it's transparent. Give me a couple of days to polish and I'll publish it on GitHub, with instructions on how to build, and install it.
                              Edit:
                              This just sounds like a lack of understanding on behalf of the module authors, ...or possibly me. I can’t believe that it could possibly be so difficult.
                              These are the two libraries you referenced st the start?
                                @akbooer
                                Or it could very well be that I missed something but looking at reports from github, I am not the only one observing it. These library work very well for publishing to the broker. They don't work unless you want to dedicate an instance of lua to be the listener...
                                @therealdb
                                This could potentially be the base for a bridge to so many things for openLuup!!
                                  @rafale77 I have a simple version almost ready. I'll debug later today or tomorrow, and put on GitHub. Here's an excerpt of the config:
                                  	"MQTT": {
                                  		"Username": "vera",
                                  		"Password": "openluup",
                                  		"Port": 1883
                                  	"Devices": [
                                  			"Name": "Pool",
                                  			"ClientID": "sonoff-pool",
                                  			"TopicName": "tele/tasmota/SENSOR",
                                  			"TopicPath": "AM2301.Temperature",
                                  			"DeviceID": 12,
                                  			"Service": "urn:upnp-org:serviceId:TemperatureSensor1",
                                  			"Variable": "CurrentTemperature"
                                  			"Name": "DeHumidifier",
                                  			"ClientID": "tasmota-dehum",
                                  			"TopicName": "stat/sonoff/POWER",
                                  			"TopicValue": "ON",
                                  			"DeviceID": 12,
                                  			"Service": "urn:upnp-org:serviceId:HVAC_UserOperatingMode1",
                                  			"Variable": "ModeTarget",
                                  			"Value": "HeatOn"
                                  			"TopicValue": "OFF",
                                  			"DeviceID": 12,
                                  			"Value": "Off"
                                  I think it's more than enough to understand how the things will gonna work 😄
                                    Edit:
                                    B Offline
                                    B Offline
                                    Buxton
                                    @rafale77 hey Rafale,
                                    I went down the very same road a while back and threw in towel because the polling by the MQTT plugin created CPU drags that stopped openLuup from functioning "reliably". The instability was also in part because I use two other must-have plugins that rely on polling, and I imagine that the combination of the three was creating a scenario that caused intermittent failures. And I too ended up implementing MQTT in Home Assistant and then using RealDB's virtual HTTP plugin to send commands to my WiFi devices--albeit not knowing the status of the devices in openLuup after the send.
                                    I'm looking at RigPapa's socket proxy and WebSocket plugins to see if I can transform my polling plugins to Async. The MQTT plugin is too complex for me to convert though, so if you take a crack at it, and are successful, I would very much appreciate you publishing your results, as MQTT is becoming a must for me.
                                    GitHub - toggledbits/sockproxyd: A socket proxy for Vera/openLuup systems
                                    A socket proxy for Vera/openLuup systems. Contribute to toggledbits/sockproxyd development by creating an account on GitHub.
                                    GitHub - toggledbits/LuWS: A WebSocket client implementation for Luup (Vera and openLuup) systems, with optional async receive (responsive)
                                    A WebSocket client implementation for Luup (Vera and openLuup) systems, with optional async receive (responsive) - toggledbits/LuWS
                                    • B Buxton
                                      I was also thinking about using a proxy for this but it is really adding a layer of complication. For MQTT it might be work it though, I think @therealdb 's solution is likely a better approach... basically also kind of a proxy written in C to act as the client and seems to be very lightweight.
                                        I had a brief health problem in the latest days that put me completely KO, but I'm recovering. Code is almost done, I just need some time to test it under load and write some doc. I hope to finish it later today.
                                          here we are: https://github.com/dbochicchio/luup-mqtt
                                          Try it and let me know. It should be easy to acquire .NET Core SDK and build the app. It's very minimal, fast and should be easy to understand. Right now it's only updating variables (with virtual device I think it's more tha enough), but I could add other actions if needed.
                                          rafale77R A 2 Replies Last reply
                                            146.9k
