  3. Bluegiga’s BLED112, Raspberry Pi (Ser2net) & Vera/Node-Red
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
1 Posts 1 Posters 780 Views 1 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Sorry for the long title 🙂
    After building, for the want of a better term, a “Ser2net Server” in order to share various USB/Serial devices With Vera/Node-Red etc.
    I’ve recently added Bluegiga’s BLED112 Bluetooth (https://www.silabs.com/wireless/bluetooth/bluegiga-low-energy-legacy-modules/device.bled112) with the goal that I can integrate all the personal bluetooth devices worn in the house (i.e fitness trackers etc.) into some sort of presence awareness set-up.
    All my other usb/serial devices, such as a Current Cost energy monitor, DSC Alarm Panel and a RFCOM Rfxrtx433 transceiver which are connected are all working well, and with the ability to share each device I’ve been able to integrate them into the different HA solutions I use.
    So getting back to the point of my post, and with the BLED112 connected, I can access it via the pi no problem and using this .py script (. https://github.com/jrowberg/bglib/blob/master/Python/Examples/bled112_scanner.py) - so I can do a few things when logged into the pi, but what I’m struggling with at the moment is how to get clean information out via ser2net. Currently everything looks jumbled/corrupted and I’ve tried to change the Ser2net serial/connection settings for it but that hasn’t resulted in any noticeable improvements .
    Ser2net .conf settings.
    4004:raw:0:/dev/ttyACM0:115200 8DATABITS NONE 1STOPBIT max-connections=4
    Is anyone on this forum using the BLED112 in any capacity today ? Ideally with Vera/OpenLuup ?
    Screenshot below of what’s seen via telnet (Remoter is the iOS app I’m using , but the N065H is a model of fitness band my wife has.
    And attached below is what seen from the pi when the python script is run..
    Within the above you have the MAC of the Bluetooth device, plus the strength of the signal, so the makings of some good presence/range automation capabilities 🤩
      161.3k
      1.3k
