  3. Delay in luup requests
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
15 Posts 3 Posters 3.6k Views 2 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    I have a couple of luup request, one is a request to VeraAlexa pluging to make alexa speak, the other updating a variable in reactor. They all seem to have a 10-20 second delay
    example request
    http://192.168.1.134:3480/data_request?id=action&DeviceNum=44&serviceId=urn:toggledbits-com:serviceId:ReactorSensor&action=SetVariable&VariableName=A_home&NewValue=1
    I can not figure out what is causing the delay, does anyone have any ideas?
      What does the log show?
      • ElcidE Offline
        ElcidE Offline
        Elcid
        26.399   openLuup.server:: POST /data_request?id=action&DeviceNum=11&serviceId=urn:toggledbits-com:serviceId:ReactorSensor&action=SetVariable&VariableName=A_home&NewValue=0 HTTP/1.1 tcp{client}: 0xfc90558
        2020-11-17 14:53:31.400   luup.call_action:: 11.urn:toggledbits-com:serviceId:ReactorSensor.SetVariable
        2020-11-17 14:53:31.401   luup.call_action:: action will be handled by parent: 10
        2020-11-17 14:53:31.414   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpsplfxbw":{"evaledge":{"f":1605524998,"t":1605524998},"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplf... now: {"grpsplfxbw":{"evaledge":{"f":1605524998,"t":1605524998},"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplf... #hooks:0
        2020-11-17 14:53:31.419   openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0xfc90558
        2020-11-17 14:53:31.420   openLuup.server:: ...only 0 bytes sent
        2020-11-17 14:53:31.420   openLuup.server:: error 'closed' sending 137 bytes to tcp{client}: 0xfc90558
        2020-11-17 14:53:31.421   openLuup.server:: ...only 0 bytes sent
        2020-11-17 14:53:31.421   openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0xfc90558
        2020-11-17 14:53:31.422   openLuup.server:: ...only 0 bytes sent
        2020-11-17 14:53:31.422   openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0xfc90558
        2020-11-17 14:53:31.423   openLuup.server:: ...only 0 bytes sent
        2020-11-17 14:53:31.423   openLuup.server:: request completed (137 bytes, 1 chunks, 23 ms) tcp{client}: 0xfc9055
        • ElcidE Offline
          ElcidE Offline
          Elcid
          OK the issue is the POST request, it does not like it, if i make it GET everything is smooth.
            No idea.
            • I would like to see earlier in the log where there should be an initial connection message from the server module.
            • also would like to see the HTTP Server page at http://openLuupIP:3480/openLuup?page=http
            • the exact 5 second delay between the first and second lines would indicate a timeout...
            • ... but a valid request appears to be received and acted upon (very quickly)
            No indication of 10-20 second delays in this case.
            Do you always get those errors?
            • ElcidE Elcid
              @elcid said in Delay in luup requests:
              OK. Our messages crossed, but that's a good start.
              What is generating the request? Are you sure it's valid?
              • ElcidE Offline
                ElcidE Offline
                Elcid
                A get request
                2020-11-17 15:45:24.304   luup.variable_set:: 10186.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:1
                2020-11-17 15:45:24.305   luup.watch_callback:: 10186.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [10]reactorWatch() function: 0xf0d38d0
                2020-11-17 15:45:24.321   luup.variable_set:: 14.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"condpxw4kq6":{"evaledge":{"t":1605296162,"f":1605296163},"stateedge":{"t":1605296162,"f":1605296163},"id":"condpx... now: {"condpxw4kq6":{"evaledge":{"t":1605296162,"f":1605296163},"stateedge":{"t":1605296162,"f":1605296163},"id":"condpx... #hooks:0
                2020-11-17 15:45:24.324   luup.variable_set:: 14.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1605627873 now: 1605627924 #hooks:0
                2020-11-17 15:45:24.325   luup.variable_set:: 14.urn:toggledbits-com:serviceId:ReactorSensor.Message was: Not tripped now: Not tripped #hooks:0
                2020-11-17 15:45:25.310   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=296260928&Timeout=60&MinimumDelay=1500&_=1605627659979 HTTP/1.1 tcp{client}: 0xf3e3758
                2020-11-17 15:45:25.427   openLuup.server:: request completed (40635 bytes, 3 chunks, 116 ms) tcp{client}: 0xf3e3758
                2020-11-17 15:45:26.315   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=296260933&Timeout=60&MinimumDelay=1500&_=1605627659980 HTTP/1.1 tcp{client}: 0xf3e3758
                2020-11-17 15:45:28.614   luup.variable_set:: 10090.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1605627908 now: 1605627928 #hooks:0
                2020-11-17 15:45:29.028   openLuup.server:: request completed (17279 bytes, 2 chunks, 2711 ms) tcp{client}: 0xf3e3758
                2020-11-17 15:45:30.058   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=296260935&Timeout=60&MinimumDelay=1500&_=1605627659981 HTTP/1.1 tcp{client}: 0xf3e3758
                2020-11-17 15:45:38.635   openLuup.io.server:: HTTP:3480 connection from 192.168.1.10 tcp{client}: 0xff28f20
                2020-11-17 15:45:38.638   openLuup.server:: GET /data_request?id=action&DeviceNum=11&serviceId=urn:toggledbits-com:serviceId:ReactorSensor&action=SetVariable&VariableName=A_home&NewValue=0 HTTP/1.1 tcp{client}: 0xff28f20
                2020-11-17 15:45:38.639   luup.call_action:: 11.urn:toggledbits-com:serviceId:ReactorSensor.SetVariable
                2020-11-17 15:45:38.640   luup.call_action:: action will be handled by parent: 10
                2020-11-17 15:45:38.652   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpsplfxbw":{"evaledge":{"f":1605524998,"t":1605524998},"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplf... now: {"grpsplfxbw":{"evaledge":{"f":1605524998,"t":1605524998},"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplf... #hooks:0
                2020-11-17 15:45:38.657   openLuup.server:: request completed (137 bytes, 1 chunks, 18 ms) tcp{client}: 0xff28f20
                2020-11-17 15:45:38.659   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0xff28f20
                2020-11-17 15:45:38.775   openLuup.server:: request completed (43132 bytes, 3 chunks, 8716 ms) tcp{client}: 0xf3e3758
                2020-11-17 15:45:39.715   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpsplfxbw":{"evaledge":{"f":1605524998,"t":1605524998},"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplf... now: {"grpsplfxbw":{"evaledge":{"f":1605524998,"t":1605524998},"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplf... #hooks:0
                2020-11-17 15:45:39.719   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1605627571 now: 1605627939 #hooks:0
                2020-11-17 15:45:39.722   luup.variable_set:: 10.urn:toggledbits-com:serviceId:Reactor.runscene was: {} now: {} #hooks:0
                2020-11-17 15:45:39.724   luup.variable_set:: 10.urn:toggledbits-com:serviceId:Reactor.runscene was: {} now: {"ctx11.scgrpv8xitp8.true":{"starttime":1605627939,"context":11,"scene":"grpv8xitp8.true","taskid":"ctx11.scgrpv8xi... #hooks:0
                2020-11-17 15:45:39.727   luup_log:10: Reactor: "Reactor Sensor 1" (#11) Performing "Device Action" ("grpv8xitp8.true" group 1 step 1)
                2020-11-17 15:45:39.729   luup.call_action:: 10165.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                2020-11-17 15:45:39.731   luup.call_action:: action will be handled by parent: 5
                2020-11-17 15:45:39.732   luup.variable_set:: 10.urn:toggledbits-com:serviceId:Reactor.runscene was: {"ctx11.scgrpv8xitp8.true":{"starttime":1605627939,"context":11,"scene":"grpv8xitp8.true","taskid":"ctx11.scgrpv8xi... now: {"ctx11.scgrpv8xitp8.true":{"starttime":1605627939,"context":11,"scene":"grpv8xitp8.true","taskid":"ctx11.scgrpv8xi... #hooks:0
                2020-11-17 15:45:39.735   luup.variable_set:: 10.urn:toggledbits-com:serviceId:Reactor.runscene was: {"ctx11.scgrpv8xitp8.true":{"starttime":1605627939,"context":11,"scene":"grpv8xitp8.true","taskid":"ctx11.scgrpv8xi... now: {} #hooks:0
                2020-11-17 15:45:39.736   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorGroup.GroupStatus_grpv8xitp8 was: 0 now: 1 #hooks:0
                2020-11-17 15:45:39.738   luup.variable_set:: 11.urn:toggledbits-com:se
                a post request
                :10.738   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=296261179&Timeout=60&MinimumDelay=1500&_=1605627660009 HTTP/1.1 tcp{client}: 0xf5f46e0
                2020-11-17 15:48:28.610   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpsplfxbw":{"statestamp":1605524998,"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplfxbw","evalstamp":16... now: {"grpsplfxbw":{"statestamp":1605524998,"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplfxbw","evalstamp":16... #hooks:0
                2020-11-17 15:48:28.614   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1605628086 now: 1605628108 #hooks:0
                2020-11-17 15:48:28.615   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.Message was: Not tripped now: Not tripped #hooks:0
                2020-11-17 15:48:28.644   luup.variable_set:: 10090.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1605628088 now: 1605628108 #hooks:0
                2020-11-17 15:48:29.084   openLuup.server:: request completed (69817 bytes, 5 chunks, 18345 ms) tcp{client}: 0xf5f46e0
                2020-11-17 15:48:30.151   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=296261184&Timeout=60&MinimumDelay=1500&_=1605627660010 HTTP/1.1 tcp{client}: 0xf5f46e0
                2020-11-17 15:48:48.627   luup.variable_set:: 10090.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1605628108 now: 1605628128 #hooks:0
                2020-11-17 15:48:48.745   openLuup.server:: request completed (33122 bytes, 3 chunks, 18590 ms) tcp{client}: 0xf5f46e0
                2020-11-17 15:48:49.782   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=296261186&Timeout=60&MinimumDelay=1500&_=1605627660011 HTTP/1.1 tcp{client}: 0xf5f46e0
                2020-11-17 15:48:55.201   openLuup.io.server:: HTTP:3480 connection from 192.168.1.10 tcp{client}: 0xf8bd6d8
                2020-11-17 15:48:55.202   openLuup.server:: POST /data_request?id=action&DeviceNum=11&serviceId=urn:toggledbits-com:serviceId:ReactorSensor&action=SetVariable&VariableName=A_home&NewValue=0 HTTP/1.1 tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.203   luup.call_action:: 11.urn:toggledbits-com:serviceId:ReactorSensor.SetVariable
                2020-11-17 15:49:00.204   luup.call_action:: action will be handled by parent: 10
                2020-11-17 15:49:00.217   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpsplfxbw":{"statestamp":1605524998,"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplfxbw","evalstamp":16... now: {"grpsplfxbw":{"statestamp":1605524998,"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplfxbw","evalstamp":16... #hooks:0
                2020-11-17 15:49:00.222   openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.223   openLuup.server:: ...only 0 bytes sent
                2020-11-17 15:49:00.224   openLuup.server:: error 'closed' sending 137 bytes to tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.224   openLuup.server:: ...only 0 bytes sent
                2020-11-17 15:49:00.225   openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.225   openLuup.server:: ...only 0 bytes sent
                2020-11-17 15:49:00.226   openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.226   openLuup.server:: ...only 0 bytes sent
                2020-11-17 15:49:00.227   openLuup.server:: request completed (137 bytes, 1 chunks, 23 ms) tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.228   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0xf8bd6d8
                2020-11-17 15:49:00.753   openLuup.server:: request completed (58975 bytes, 4 chunks, 10970 ms) tcp{client}: 0xf5f46e0
                2020-11-17 15:49:01.682   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpsplfxbw":{"statestamp":1605524998,"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplfxbw","evalstamp":16... now: {"grpsplfxbw":{"statestamp":1605524998,"stateedge":{"f":1605524998,"t":1605524998},"id":"grpsplfxbw","evalstamp":16... #hooks:0
                2020-11-17 15:49:01.687   luup.variable_set:: 11.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1605628108 now: 1605628141 #hooks:0
                2020-11-17 15:49:01.688   luup.variable_set:: 10.urn:toggledbits-com:serviceId:Reactor.runscene was: {} now: {} #hooks:0
                2020-11-17 15:49:01.689   luup.variable_set:: 10.urn:toggledbits-com:serviceId:Reactor.runscene was: {} now: {"ctx11.scgrpv8xitp8.true":{"starttime":1605628141,"context":11,"scene":"grpv8xitp8.true","taskid":"ctx11.scgrpv8xi... #hooks:0
                2020-11-17 15:49:01.691   luup_log:10: Reactor: "Reactor Sensor 1" (#11) Performing "Device Action" ("grpv8xitp8.true" group 1 step 1)
                2020-11-17 15:49:01.691   luup.call_action:: 10165.urn:upnp-org:serviceId:SwitchPower1.SetTa
                the server page is code 200 for all items wxcept favicon which is 404.
                /cgi-bin/cmh/sysinfo.sh 	3 	200
                /openLuup 	63 	200
                D_ALTUI.xml 	7 	200
                D_AltAppStore.xml 	7 	200
                D_BinaryLight1.xml 	8 	200
                D_BluetoothNetwork.xml 	6 	200
                D_BroadLink_Mk2_1.xml 	6 	200
                D_DimmableLight1.xml 	6 	200
                D_DimmableRGBLight1.xml 	6 	200
                D_DoorSensor1.xml 	6 	200
                D_EzloBridge.xml 	6 	200
                D_GenericSensor1.xml 	6 	200
                D_LightSensor1.xml 	6 	200
                D_MotionSensor1.xml 	6 	200
                D_PowerMeter1.xml 	9 	200
                D_Reactor.xml 	6 	200
                D_ReactorDeviceInfo.json 	5 	200
                D_ReactorSensor.xml 	6 	200
                D_SceneController1.xml 	9 	200
                D_SiteSensor1.xml 	6 	200
                D_SmartHomeHelper.xml 	6 	200
                D_Switchboard1.xml 	6 	200
                D_TemperatureSensor1.xml 	6 	200
                D_VeraAlexa1.xml 	6 	200
                D_VeraBridge.xml 	6 	200
                D_WindowCovering1.xml 	6 	200
                D_ZWaveNetwork.xml 	6 	200
                D_ZigbeeNetwork.xml 	6 	200
                D_openLuup.xml 	10 	200
                J_ALTUI_api.js 	12 	200
                J_ALTUI_iphone.js 	12 	200
                J_ALTUI_jquery.ui.touch-punch.min.js 	12 	200
                J_ALTUI_multibox.js 	12 	200
                J_ALTUI_plugins.js 	12 	200
                J_ALTUI_uimgr.js 	12 	200
                J_ALTUI_upnp.js 	12 	200
                J_ALTUI_utils.js 	12 	200
                J_ALTUI_verabox.js 	12 	200
                J_ReactorSensor_ALTUI.js 	12 	200
                J_ReactorSensor_UI7.js 	3 	200
                J_Reactor_ALTUI.js 	12 	200
                J_SiteSensor1_ALTUI.js 	12 	200
                S_HaDevice1.xml 	1 	200
                S_ReactorSensor.xml 	1 	200
                S_SecuritySensor1.xml 	1 	200
                S_SwitchPower1.xml 	1 	200
                favicon.ico 	5 	404
                icons/AltAppStore.svg 	7 	200
                icons/VeraBridge.svg 	5 	200
                icons/dimmable_light_10.png 	3 	200
                icons/dimmable_light_100.png 	1 	200
                icons/dimmable_light_20.png 	1 	200
                icons/dimmable_light_50.png 	1 	200
                icons/dimmable_light_off.png 	17 	200
                icons/door_window_untripped.png 	15 	200
                icons/light_sensor_default.png 	13 	200
                icons/meter_default.png 	16 	200
                icons/motion_sensor_tripped.png 	11 	200
                icons/motion_sensor_untripped.png 	13 	200
                icons/openLuup.svg 	66 	200
                icons/switch_off.png 	14 	200
                icons/switch_on.png 	13 	200
                icons/temperature_sensor_default.png 	15 	200
                icons/window_covering_10.png 	13 	200
                icons/zwave_default.png 	15 	200
                id=action 	807 	200
                id=actions 	15 	200
                id=lr_ALTUI_Handler 	36 	200
                id=lr_ALTUI_LuaRunHandler 	154 	200
                id=lr_HTTP_VeraBridgeMirror_192.168.1.11 	0
                id=lr_Reactor 	24 	200
                id=lr_SiteSensor 	0
                id=lr_Switchboard 	0
                id=lu_action 	2 	200
                id=lu_status2 	2158 	200
                id=scene 	1 	200
                id=sdata 	9 	200
                id=status 	3 	200
                id=user_data 	13 	200
                id=variableget 	16 	200
                id=variableset 	12 	200
                w3.css 	60 	200
                having troble with this forum, not allowing image upload.
                • ElcidE Elcid
                  A get request
                  a post request
                  /openLuup 	63 	200
                  D_ALTUI.xml 	7 	200
                  D_Reactor.xml 	6 	200
                  favicon.ico 	5 	404
                  id=action 	807 	200
                  id=actions 	15 	200
                  id=lr_SiteSensor 	0
                  id=lr_Switchboard 	0
                  id=lu_action 	2 	200
                  id=scene 	1 	200
                  id=sdata 	9 	200
                  id=status 	3 	200
                  id=user_data 	13 	200
                  w3.css 	60 	200
                  ...need to flag this to @DesT
                  DesTD 1 Reply Last reply
                  • ElcidE Offline
                    ElcidE Offline
                    Elcid
                    Automate is generating the requests when phone leaves home wifi.
                      ...so it looks like Automate doesn't like chunked responses to the POST request.
                      The logs are a bit misleading, because action requests are processed asynchronously as jobs, so things don't always appear in the order that you might expect.. The timeouts should precede the action execution, and they are, almost definitely, what is delaying it.
                      • ElcidE Offline
                        ElcidE Offline
                        Elcid
                        Ok i will have to edit my automate http request forwarder so i can specify request type in the payload. i.e post,get,put,etc
                          DesTD Offline
                          DesTD Offline
                          DesT
                          @akbooer said in Delay in luup requests:
                          Are you still having an issue ?
                          • ElcidE Offline
                            ElcidE Offline
                            Elcid
                            @DesT
                            ye.
                            seems certain buttons are working.
                            none of the buttons/icons on reply page.
                            the 4 black icons to left of reply, above quick reply input.
                            Also the context menu chevron on the reply button/icon.
                            i can not edit or delete a post either.
                            • ElcidE Offline
                              ElcidE Offline
                              Elcid
                              Dark mode has disappeared and there is no longer an icon in the title bar.
                              • ElcidE Offline
                                ElcidE Offline
                                Elcid
                                Still not working for me @DesT
                                  retireditguy
                                  143.3k
