  3. Alexa TTS troubleshooting
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 3 Posters 1.8k Views 3 Watching
    Evening (at least here)
    Alexa TTS has suddenly stopped here (mid afternoon)
    Normally I'd replace the cookie.
    When I went to the domain, I was forced to change my password. Did that and exported the cookie. But still no voice.
    I can't see anything at all in the logs:
    2021-02-12 18:05:02.869   luup_log:0: ALTUI: runLua(local GardenTemp = math.floor(0.5+luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 20415))
    luup.call_action("urn:dlna-org:serviceId:DLNAMediaController1", "Say", {Text="The temperature outside is" ..GardenTemp.. "degrees.",Volume=40,GroupZones="Everywhere"}, 22))
    2021-02-12 18:05:02.870   luup.call_action:: 22.urn:dlna-org:serviceId:DLNAMediaController1.Say
    2021-02-12 18:05:02.870   luup_log:22: VeraAlexa: addToQueue: added to queue for 22
    2021-02-12 18:05:04.035   luup_log:0: ALTUI: Evaluation of lua code returned: nil
    But I'm sure I need to look somewhere else and damned if I can recall where. Someone give me a pointer?
    TIA
      Give the oath tool a try. It’s very easy to setup and once done no password are needed.
        @therealdb said in Alexa TTS troubleshooting:
        Thanks. Having a nightmare troubleshooting at the moment. Brain seems everywhere :(. First thing I remembered was the cookie this morning! So back up and running.
        Where's the oath tool, chap?
        Cheers
          From the original read me on https://github.com/thorsten-gehrig/alexa-remote-control
          In order to use MFA, one needs to obtain the MFA_SECRET from Amazon account:
          • You should have MFA using an App already working before proceeding
          • Add a new app
          • When presented with the QR-code select "can't scan code"
          • You will be presented with the MFA shared secret, something like 1234 5678 9ABC DEFG HIJK LMNO PQRS TUVW XYZ0 1234 5678 9ABC DEFG
          • Now you have to generate a valid response code via oathtool -b --totp "<MFA shared secret from above>" and enter that in the web form
          Going from here the MFA shared secret becomes the MFA_SECRET for the alexa_remote_control script Treat that MFA_SCECRET just like your password - DO NOT share it anywhere!!!
          It is assumed that MFA secured accounts are less likely to get a captcha response during login - that's why MFA might yield better results if the plain username/password didn't work for you.
            Right gotcha!
            May well give it a try, thanks, as ever 🙂
              I'm back to testing Vera Alexa (now rev. 0.97) and thus far no improvement. 99% silence despite being correctly configured.
              Here's a data point to mull over:
              luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command='-e weather -d "Living Room"'}, 366)
              yields this LatestResponse on Vera:
              sending cmd:weather to dev:Living Room type:A15ERDAKK5HQQG serial:eb48978706f5459f890ef0ec5aa9fce9 customerid:A3SL3Z0HELH3YG
              and this in Vera's LuaUPnP Log (among other lines):
              Device_Variable::m_szValue_set device: 366 service: urn:bochicchio-com:serviceId:VeraAlexa1 variable: LatestResponse was: ERROR: unknown option weather /storage/alexa/alexa_remote_control.sh [-d <device>|ALL] .......
                376
                151.4k
