  3. Vera/openLuup plugins
  4. altUI
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
altUI
59 Posts 6 Posters 23.0k Views 6 Watching
    Is there any chance of @amg0 becoming an active member, do you think?
    He appears to be not responding on GitHub (I opened my licensing query a month back)
    There are also some challenges around how things like thermostats behave in their display which would be great if we could get them fixed. Well beyond my capability 😞
      He has reached out to me a couple of months ago about his credential here. He seems to have tuned down his activity to a minimum and I have just submitted a pull request for ALTUI on github. Generally speaking he seems to be willing to take in PRs but is not going to invest himself in larger projects. He was not very active in the old place either.
      If there are things you need to get done, I can give it a shot but I am very much a newb in javascript.
        @rafale77 thanks chap. Seems a little unfair (to you!)
        I guess there are two issues (so far)
        Thermostats don't work properly under Altui. Or at least mine doesn't There's no way of adjusting the set point in the web interface. Works fine in Homewave but....
        The other is the licencing issue previously mentioned. A minor peeve.
        But this raises some concern that if the UI is not maintained, in a couple of years, how functional will it be?
          I would not call it "unmaintained", @amg0 has just recently taken my localcdn updates and has upgraded bootstrap. I can't help with the licensing unfortunately. Maybe @akbooer can. About the setpoint problem with the thermostat, can you provide more details? I don't think this would be an ALTUI issue and more of a vera device file issue since that's what is controlling it. I have personally wrote a plugin to control my thermostat which integrates door/motion sensors/vents (The US mostly use forced air HVAC) and calculates a virtual home temperature. (Kind of like ecobee but much better as it shuts off vents for rooms with open windows, ignores and shuts off unoccupied rooms etc...)... and my thermostat works. What model and what errors/issues are you seeing?
            @rafale77
            Maybe 'unmaintained' is unfair, not my intention. But if support has stopped (no response to a follow up on my licensing query) and the other issue raiser in 2018 was directed to Vera forum, not sure what's going to happen.
            Ref the Thermostat, I guess it may be the device file since it doesn't 'work' in the console either. This is all I get in AltUI
            So there's no way to adjust the set point.
              Can you show me the device attributes? And action screen? What are you expecting to be able to do? Only change setpoints (heat/cool?) do you need to change also mode?
                @rafale77
                Here you are 🙂
                I guess all I expect to change (and display) is the current set point. Heat on and off would be cool as well.
                As far as I am aware there is only one (functional) setpoint. Although I suspect it has rather more than that. And only one mode (heat) although again I suspect it has more of them as well. Which is probably a failure in the file attributed to the device?
                I can see it has in its variables two CurrentSetpoints. One is probably my fault trying to control it. But it also has Energymodes and Fanspeed.
                It's really a very simple on / off stat 😉
                Tangentially this feels like the kind of issue that we should be able to provide a quick and easy solution to the average user. You know I'm going to be happy to ask and fire commands, but for basic users, it's a simple device and it's effectively un-usable.
                I use it with Homewave (not exactly simple) and Alexa / HA Bridge (not quite user hostile, but verging on it) 🙂 So I don't need this functionality, it just feels like quite a big miss.
                  ouch... this is through the z-way bridge. Need @akbooer here. It looks like this device was not recognized by the z-way bridge as a thermostat. I am curious as to what command class it is showing on z-way. Can you please take a look at the expertUI on z-way and show what command classes it is presenting on the interview screen?
                    @rafale77 of course. Seems to have correctly IDed it
                    and
                      I just looked at the z-way bridge code... and it shows that the bridge should create a thermostat device instead of a combo device.
                      You may have installed this on an older version of the z-way bridge.
                      Solution:
                      Update the z-way-bridge if it isn't already the latest version, delete the child device and reload luup.
                      See what device file you get.
                        So this is the Z-way plugin on AltUI?
                        Showing 20.7.14
                          Showing 20.7.14
                          @catmanv2
                          The latest development version should be 2021.1.19
                            OK. If I delete the child device, am I going to lose all my automations and actions around it?
                            Sorry to be a PITA....
                              Not on openLuup. That was a vera "feature" luckily openLuup didn't reproduce. Upon luup reload, the device will be recreated and no automation should be broken. Make sure you only delete the thermostat device.
                              The device created should show you the thermostat temperature and at least one setpoint.
                                @rafale77
                                OK
                                So used the App store to select Github.development
                                Plugins now shows 21.1.19
                                Deleted the device that I thought was the Thermostat (i.e. the one I showed you earlier)
                                Reloaded Luup and I have a device that was recreated in my Z-Way-nnnnnn room
                                But...
                                Nothing appears to have changed:
                                I assume I've done something dumb 🙂
                                  Nope... there is something missing: the bridge has linked the variables but did not use the right device files.
                                  Go into attributes and change the device json from ComboDevice1.json to D_HeaterStelpro.json and the device file to D_Heater1.xml
                                  I think that you have a heater rather than a thermostat...
                                    @rafale77
                                    Heheh. Not sure why it would be considered a heater but.... 😉
                                    Not much of an improvement... (I reloaded Luup)
                                      hmm - hmmm you have the device files reversed the json file needs to be in the json field... also make sure that these files do exist in your openluup installation. They should come from the vera.
                                      I read the manual for your thermostat and it is indeed a heat only thermostat which for vera is a heater control device... The difference is that it only has one setpoint instead of 2 and terminologies are all around heating.
                                        See it was only a matter of time before I did something stupid 😉
                                        Thanks for all this. Sure when I originally mentioned this it was a feature of AltUI.
                                        Looks much better now. thanks!
                                          As a supplementary question, now I have a Heat / Off switch.
                                          Can I make this actually switch my boiler control on? This would neatly solve an issue I've been considering with TRVs.
                                          Currently altering it from 'Off' to 'Heat' does nothing and does not appear to alter the value of the ModeTarget variable which is reflected in the logs.
                                          I also need to chase something down I suspect in HA Bridge as I've managed to re-create another CurrentSetpoint
                                            137.5k
