  3. UniFi Energy Report - How can I retrieve the value via http ?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 2 Posters 1.5k Views 2 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    I have a piece of code that returns the Watts used by all the PoE devices on my home network. I’m trying to set it up on Vera so that can retrieve that value in a similar way I would retrieve a Vera variable via a http request.
    The function works returns the total value when run via LuaTest, but when I try to retrieve it via luup.register_ handler, for some reason it returns the entire UniFi json file ??
    Please could some help me with what’s wrong, my goal is to be able to retrieve the value , like an api so I can use it elsewhere ..
    luup.register_handler("UnifiControllerPoE","UnifiWatts")
    function UnifiControllerPoE()
    	local unifi_username = "unifi"
    	local unifi_password = "unifi"
    	local unifi_controller_ip = "192.168.1.207"
    	local unifi_controller_port = "8443"
    	local cookie = "/tmp/unifi_cookie_lua" -- Temp cookie file
    	local tempfilename = "/tmp/UnifiController.tmp" -- Temp JSON output file
    	local device = 'api/s/default/stat/device'
    	local f = io.popen("stat -c %Y " .. tempfilename)
    	local last_modified = f:read()
    		--if (os.difftime (os.time(), last_modified) > 30) then
    			-- URL for logging in, query and logging out
    			url_login = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure -H \'Content-Type: application/json\' -X POST -d \'{"password":"' .. unifi_password .. '","username":"' .. unifi_username .. '"}\' https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/api/login'
    			url_open = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure -s -o '..tempfilename..' --data "json={}" https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/' ..device
    			url_logout = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/logout'
    			-- Execute url
    			-- Execute url
    			read_login = os.execute(url_login)
    			read_open = os.execute(url_open)
    			read_logout = os.execute(url_logout)
    		--end
    	local line
    	local file = io.open(tempfilename, "r")
    		if file then
    			line = file:read("*a")
    			file:close()
    	return line
    --print(UnifiController())
    local readings = {}
    local total = 0
    local json = require "dkjson"
    local u = json.decode( UnifiControllerPoE() )
    --print('\n')
    for key,value in ipairs( u.data ) do
    	for n, p in ipairs( value.port_table ) do
    		--print('\t'.. tostring(p.port_idx), p.poe_enable, tonumber(p.poe_power))
    		-- print(p.port_idx)
    		table.insert( readings, { value.name, tonumber(p.poe_power)}) -- populate readings table
    	for _, reading in ipairs(readings) do
    		local Variable = reading[1]
    		local Value = reading[2] or 0
    		total = total + Value
    			if Value ~= 0 then
    			--print(Variable.. " - ".. Value, total)
    print("Total watts = " ..total)
    local html = "<html><head>" ..
                         "</head>" ..
                         "<body>" ..
                         "<b>" ..
                         tostring(total) .. '</b>' ..
                         "</body></html>"
    	return html, "text/html"
    • parkercP Offline
      parkercP Offline
      parkerc
      Hi all,
      Is this even possible to do ?
      If so, does anyone have any ideas / suggestions on how to do it ? Many thanks
      • parkercP parkerc
        			-- Execute url
        			-- Execute url
        		--end
        	local line
        		if file then
        			file:close()
        	return line
        local readings = {}
        local total = 0
        --print('\n')
        			if Value ~= 0 then
                             "</head>" ..
                             "<body>" ..
                             "<b>" ..
                             "</body></html>"
        @parkerc you should move your end at line 33 to be the last, otherwise the function will not include the rest of your code.
        • parkercP Offline
          parkercP Offline
          parkerc
          Thanks so much @therealdb - Such a silly mistake, for some reason I was thinking it would run the whole piece of code, when i should have realised it will only run the function part, as that’s all that’s being called! Doh !
          • parkercP Offline
            parkercP Offline
            parkerc
            Ok, perhaps I spoke too soon as that’s created other errors - but at least I know where to focus my attention for now..
            • parkercP Offline
              parkercP Offline
              parkerc
              Sorted ! - thanks again @therealdb , I had to break it up over two functions in the end - but it works a treat ! 🙂
              luup.register_handler("rununfiwattagereport","unifi")
              	local unifi_username = "vera"
              	local unifi_password = "vera"
              	local unifi_controller_ip = "192.168.102.207"
              			-- Execute url
              			-- Execute url
              	local line
              		if file then
              			file:close()
              	return line
              function rununfiwattagereport()
              local readings = {}
              local total = 0
              --print('\n')
              			if Value ~= 0 then
                                   "</head>" ..
                                   "<body>" ..
                                   "<b>" ..
                                   "</body></html>"
                159.9k
