  3. Bluetooth Control - Vera / Openluup
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
3 Posts 3 Posters 1.1k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Is anyone aware of any way in which Bluetooth devices can be connected and controlled via a home automation controller, such as Vera / openluup (even NodeRed, HASS) etc ?
    I recall Bluetooth was an original ‘feature’ on the Veraplus but that soon died a death, and was never heard of again.
    What, if anything are people doing with Bluetooth ?
      I’m using Bluetooth on my home intel NUC to integrate switch bot and mi flora (plus, tracking devices). I’m using some libraries to push their status to mqtt and then to virtual devices on my Vera.
      Next plan is to integrate car presence with it. My experiments with WiFi devices failed, because I’m covering too much and it’s picking the cars even if they’re distant (and there’s no way to easily get the signal). Well, first world problems, I guess 🤣
      • parkercP parkerc
        ArcherS
        I have a few really nice Xiaomi temperature and humidity sensors reporting over BLE to a Tasmota ESP32, as described in this thread. The ESP is then connected to my OpenLuup with Mqtt.
          157.6k
