  3. "kinda smart" switch to put behind a normal light switch
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
18 Posts 6 Posters 4.5k Views 5 Watching
  • H Offline
    H Offline
    huhnmann
    Hello!
    I want to trigger an event (like switching on a smart Zigbee power plug) when a regular light switch (that switches regular non-smart LED light bulbs) is flipped. Is there something I can put behind a light switch to achieve this? Or something to splice in between the switch and the light bulbs? A good option would also be Hue compatible.
    Thank you!
      I have both Zwave and Wifi device attached to normal buttons, switching lights or without power, and then turning on/off other devices via scenes/scripting. In one case, I'm using a Shelly i3 to turn on 3 different Hue Lights. You'll definitely need something like Openluup or Home Assistant to script this, but it's doable.
      Black CatB 1 Reply Last reply
        +1 for the Shelly i3 for this application!
          Black CatB Offline
          Black CatB Offline
          Black Cat
          @therealdb said in "kinda smart" switch to put behind a normal light switch:
          snip
          Why?
          You can just use Reactor or MSR to achieve this result. +1 for the Shellies....
          aka Zedrally
          • Black CatB Black Cat
            snip
            Why?
            @black-cat because afaik hue lights are not directly supported by msr, and they were mentioned. I’m not sure if the op has any other hub, but the point is to be sure you can turn on/off the light via http calls.
            • H Offline
              H Offline
              huhnmann
              Thank you guys, the i3 looks like it could do the job!
              I have hubs from Bosch, Hue, and Tado.
              • ElcidE Offline
                ElcidE Offline
                Elcid
                The i3 is a bit wasteful if only a single switch. If it is a single switch why not go with a shelly 1 then you make the light smart and can also send http request or subscribe to device mqtt stat topic.
                • H Offline
                  H Offline
                  huhnmann
                  That light switch has to work exactly as before. So the i3 seems to be the best option here, indeed. That is, if exactly this:
                  Imgur
                  imgur.com
                  imgur.com
                  Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                  is possible.
                  As for the Shelly 1, I may have a different use. Is it possible to give power to a "door buzzer"*) for a predefined amount of time (like 5s)?
                  😉 Sorry, I don't know the word for it in any language. It makes "bzzzzzz" and you can open the door.
                  therealdbT ElcidE 2 Replies Last reply
                  • H huhnmann
                    Imgur
                    imgur.com
                    imgur.com
                    is possible.
                    @huhnmann yes, I’m using this to open a gate. This is often referred to as latching or pulsing. Shelly 1 has an option to turn off a relay after a given amount of time.
                    H 1 Reply Last reply
                      H Offline
                      H Offline
                      huhnmann
                      @therealdb Perfect, thank you!
                      • H huhnmann
                        Imgur
                        imgur.com
                        imgur.com
                        is possible.
                        ElcidE Offline
                        ElcidE Offline
                        Elcid
                        @huhnmann said in "kinda smart" switch to put behind a normal light switch:
                        fitting a shelly 1 , the light should function as before but also have smart capabilities, so you get the best of both worlds
                        • ElcidE Elcid
                          H Offline
                          H Offline
                          huhnmann
                          @elcid No, because the switch's off and on positions would change, every time its smart capabilities are used. Or is the Shelly 1 capable of physically flipping the switch's position?
                          ElcidE 1 Reply Last reply
                            This is why I use push switches, rather than toggle switches… can’t bear to see a toggle in the ‘wrong’ position for the light status. That’s OCD for you! Same is true for two or three way arrangements.
                            I use the MK Grid switch hardware (in the UK) which allows you to swap out individual switches in a multi-switch wall plate.
                            • H Offline
                              H Offline
                              huhnmann
                              wrote on last edited by huhnmann
                              No, that's normal, not OCD. 🙂 I could easily change the switch, but I need it to work exactly as it does now with exactly that switch. But you're right, of course, that this would make things easier.
                              • H huhnmann has marked this topic as solved on
                                ElcidE Offline
                                ElcidE Offline
                                Elcid
                                @akbooer said in "kinda smart" switch to put behind a normal light switch:
                                I use Click Mode, good quality. These are not grid design but still all switches can be interchanged, the have mulitple inserts and colours. And the bonus of being cheaper than MK. and take less space in the box.
                                • H huhnmann
                                  ElcidE Offline
                                  ElcidE Offline
                                  Elcid
                                  wrote on last edited by Elcid
                                  @huhnmann You could still use the shelly 1 in the same way as a i3. You can disiconnect the relay from the switch. You then end up with what you required, and you are still left with future options if you change you requirements.
                                  p.s. It is OCD no matter how much you deny it.
                                  H G 2 Replies Last reply
                                  • ElcidE Elcid
                                    H Offline
                                    H Offline
                                    huhnmann
                                    @elcid said in "kinda smart" switch to put behind a normal light switch:
                                    Maybe, but in this case, it's called "old people compatibility".
                                    But I'll have another look at the Shelly 1, thank you!
                                    • ElcidE Elcid
                                      @elcid CDO. It's like OCD but the letters are in the right order....
                                      *Hubitat C-7 2.5.1.142
                                      Core 2026.7.4
                                      MSR: latest-26193-8dd8f854
                                        128.0k
                                      • Logon screen timeout
