  2. Code/Snippet library
  3. Lua : http(s) request, works on some URLs, but not all ? But all work via the browser..
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Luup : Error Handling
Help with luup.chdev.sync
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
14 Posts 2 Posters 7.4k Views 2 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    • parkercP Offline
      parkercP Offline
      parkerc
      Arhhh there must be ‘redirects’ occuring…
      And looking up http.request, it has a feature for that, which I’ve never used before, has anyone reading this ?
      http.request{
        url = string,
        [sink = LTN12 sink,]
        [method = string,]
        [headers = header-table,]
        [source = LTN12 source],
        [step = LTN12 pump step,]
        [proxy = string,]
        [redirect = boolean,]
        [create = function]
      • parkercP Offline
        parkercP Offline
        parkerc
        Checking the URL via Wheregoes.com, it suggests there are no redirects occuring, so that is perhaps not it..
        Date Traced: 2021-11-21 11:23:32 GMT
        User Agent: Wheregoes.com Redirect Checker/1.0
        #CodeRequested URL
        200https://ics.|fixtur.|es/v2/ipswich-town.|ics
        Redirects: 0
        1200https://ics.fixtur.es/v2/ipswich-town.ics
        Trace Complete - 3 - text/calendar; charset=utf-8
          If you're doing this in Vera firmware...
          You may be dealing with the server demanding a level of encryption that the libraries cannot provide. This has been an increasingly common issue for many plugins, and Google was leading the charge in dropping weaker ciphers. In some of my own plugins, I've had to offer curl as an alternative mechanism, because the built-in curl uses different libraries and can be a workaround if the Lua libraries aren't cutting it.
          It's also the case that the CA chain is now out of date on all Vera firmware, and as old CA certificates are now expiring, and Vera/EZlo has not yet produced firmware with upgraded CA stores, you could be running into a certificate validation failure due to the outdated or expired data. The -k on curl is a possible cure for this. In the Lua SSL library, you can set verify to none in your request table.
          The issues have affected, in addition to my plugins (SiteSensor, Reactor for Vera, etc.) the Honeywell and MyQ plugins, and I think GCal3 has already had one round of retrofit as a result of Google's earlier changes. It's going to get worse, not better, unless they update the firmware (or we do...)
          parkercP 1 Reply Last reply
            parkercP Offline
            parkercP Offline
            parkerc
            @toggledbits said in Lua : http(s) request, works on some URLs, but not all ? But all work via the browser..:
            I am indeed..
            Thanks good to know., and ironically Google is the url that is working 🙂
            Ok, that verify and none option sounds an interesting approach. Does this look like a potential solution ?
            lua https.request with certificate
            I'm trying to make a request on lua with certificate. Recently I've gotten a COMODO SSL. I've tried many tutorials on the internet, but to no avail. I found this blog's proposal very interesting...
            I’m really intrigued by your last point, how can we update the firmware ?
            • parkercP parkerc
              I am indeed..
              @parkerc said in Lua : http(s) request, works on some URLs, but not all ? But all work via the browser..:
              More complicated than you need, probably. Setting verify to none works in most cases, at the expense of not detected a MITM attack (the likelihood of that is extremely low in my judgement, but don't substitute my judgement here for yours).
              I have a build environment working for the version of the OS they are using, and I can build updated packages, sometimes. In a few cases, though, that entire world is just so old that building packages from current source into the old environment just doesn't work. But I have built an updated openssl and LuaSec and had some success with them. Really, Ezlo needs to step up and make it work, but I have a strong feeling they won't, and if it comes to that, I will circle back in that direction.
                parkercP Offline
                parkercP Offline
                parkerc
                Sadly the verify = none option didn’t work, although it did at least returned a response code/status this time, when all previous attempts were blank..
                require("socket")
                local ssl = require("ssl")
                -- TLS/SSL client parameters (omitted)
                local params = {
                  mode = "client",
                  protocol = "tlsv1",
                  verify = "none",
                  options = "all",
                local conn = socket.tcp()
                conn:connect("https://ics.fixtur.es", 443)
                -- TLS/SSL initialization
                conn = ssl.wrap(conn, params)
                conn:dohandshake()
                conn:send("GET / HTTP/1.1\n\n")
                local line, err = conn:receive()
                print(err or line)
                conn:close()
                It returned : HTTP/1.1 400 Bad Request
                I think you’re right, all their focus is on the new ezlo firmware, unless they refocus, or they open Vera up to the community to enhance, then I guess what we have from them is the best it gets 😞
                That said I’m now very intrigued by your ‘build’, I looked into openwrt and potential (re)build options and new packages, but that ended up being pretty damn complex route for me, especially considering all the things that have to be factored in, such as the kernel and processor (mips) etc.
                Based one where I am now, I think my only option is to explore the more complex Lua coding route, and present a certificate myself with the following code.
                But what cert / cipher details should I use ?
                module("https", package.seeall)
                local socket = require "socket"
                local ssl = require "ssl"
                local ltn12 = require "ltn12"
                local try = socket.try
                local protect = socket.protect
                local DEFAULT_PROTOCOL = "sslv23"
                local DEFAULT_CAFILE = "/etc/ssl/certs/ca-certificates.crt"
                local DEFAULT_VERIFY = "peer"
                local DEFAULT_OPTIONS = "all"
                local DEFAULT_CIPHERS = "ADH-AES256-SHA:ADH-AES128-SHA:HIGH:MEDIUM"
                local DEFAULT_HTTPS_PORT = 443
                local https_mt = {
                    -- Create proxy functions for each call through the metatable
                    __index = function(tbl, key)
                        local f = function(prxy, ...)
                            local c = prxy.c
                            return c[key](c, ...)
                        tbl[key] = f    -- Save new proxy function in cache for speed
                        return f
                local function new_create(params)
                    return function()
                        local t = { c = try(socket.tcp()) }
                        function t:connect(host, port)
                            try(self.c:connect(host, port))
                            self.c = try(ssl.wrap(self.c, params))
                            try(self.c:dohandshake())
                            return 1
                        return setmetatable(t, https_mt)
                local function request_generic(args)
                    local sslparams = {
                        mode = "client",
                        protocol = args.protocol or DEFAULT_PROTOCOL,
                        cafile = args.cafile or DEFAULT_CAFILE,
                        verify = args.verify or DEFAULT_VERIFY,
                        options = args.options or DEFAULT_OPTIONS,
                        ciphers = args.ciphers or DEFAULT_CIPHERS
                    local req = {
                      url = args.url,
                      port = args.port or DEFAULT_HTTPS_PORT,
                      sink = args.sink,
                      method = args.method,
                      headers = args.headers,
                      source = args.source,
                      step = args.step,
                      proxy = args.proxy,       -- Buggy?
                      redirect = args.redirect,
                      create = new_create(sslparams)
                    return http.request(req)
                local function request_simple(url, body)
                    local tbl = { }
                    local req = {
                        url = url,
                        sink = ltn12.sink.table(tbl)
                    if body then
                        req.method = "POST"
                        req.source = ltn12.source.string(body)
                        req.headers = {
                            ["Content-length"] = #body,
                            ["Content-type"] = "application/x-www-form-urlencoded"
                    local _, status, headers = request_generic(req)
                    return table.concat(tbl), status, headers
                function request(req_or_url, body)
                    if type(req_or_url) == "string" then
                        return request_simple(req_or_url, body)
                    else
                        return request_generic(req_or_url)
                • parkercP parkerc
                  require("socket")
                  local params = {
                    mode = "client",
                    protocol = "tlsv1",
                    verify = "none",
                    options = "all",
                  conn:dohandshake()
                  print(err or line)
                  conn:close()
                  local https_mt = {
                              local c = prxy.c
                          return f
                      return function()
                              return 1
                      local sslparams = {
                          mode = "client",
                      local req = {
                        url = args.url,
                        sink = args.sink,
                        step = args.step,
                      local tbl = { }
                      local req = {
                          url = url,
                      if body then
                          req.method = "POST"
                          req.headers = {
                      else
                  If you are getting this far, the certificate and cipher issues are behind you, and it is now complaining about the content of the request. Since you are doing the request raw to a socket rather than using the http (or https) module, your request isn't complete; it's missing required headers. I'd start by using the http(s) module to make the request from this point.
                  I'm not sure that gains you anything. It may not improve the situation, either. The correct real fix here is to get the Vera's CA store up to date.
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Thanks @toggledbits , you actually beat me to it, I thought the 400 error was sign, so I tried this variation of http.request I had on file, and it worked !!
                    The ltn12.sink.table seemed to do the trick - by any chance do you know why ?
                    local http = require("ssl.https")
                    r = {} -- init empty table
                    local res, code, headers, status = http.request{
                    url="https://ics.fixtur.es/v2/ipswich-town.ics",
                    sink = ltn12.sink.table( r )
                    print("status=".. tostring(status))
                    print("response= ".. table.concat( r, "" ) )
                      You're making a request to a different URL (different paths in the URL, specifically -- the previous request you showed had no path at all), which I'm sure had more (everything) to do with the difference in response than the ltn12.sink.table, which is nothing the client passes to the server, it's all just client-side handling for the response.
                        parkercP Offline
                        parkercP Offline
                        parkerc
                        Sorry @toggledbits, , I’m not sure what you mean, putting the Google one to one side , both http.requests were made to the same url ""https://ics.fixtur.es/v2/ipswich-town.ics"" ?
                        • parkercP parkerc
                          @parkerc In this post the code that you posted shows:
                          conn:dohandshake()
                          print(err or line)
                          conn:close()
                          That's an HTTP get on the root (/) path (not /v2/ipswich.town.ics), and without full headers. Either is enough to cause a 400 from an API endpoint.
                          Your later post:
                          That's using the full HTTP(S) module, so would be expected to have correct headers supplied by the library, and uses the longer path not used in the previous request/post. It was there you made the comment about ltn12.sink.table, which given that the request in the earlier post was both missing required headers and probably not for a valid path, and that the server is unaware of ltn12 or any handling on the client side of the response, seemed unrelated to the issue to me.
                            conn:dohandshake()
                            print(err or line)
                            conn:close()
                            Your later post:
                            parkercP Offline
                            parkercP Offline
                            parkerc
                            conn:dohandshake()
                            print(err or line)
                            conn:close()
                            My apologies ; you’re totally right, I forgot I tried the root address at one point too, it was one of the addresses I looked at to see if there were any redirects going on at that address..
                            Thanks again @toggledbits , all this has been yet another learning journey for me 🙂 Admittedly it would be really nice if (one day) Vera could have an all encompassing http/web module, one that you could simply chuck any http and https request at (POST/GET), and it would know what to do and just work …
                            • parkercP parkerc
                              conn:dohandshake()
                              print(err or line)
                              conn:close()
                              Sadly, I don't think anything new will be coming to Vera from here forward...
                                155.7k
