  2. Code/Snippet library
  3. Lua : Downloading a file over https
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Luup : Error Handling
Help with luup.chdev.sync
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
10 Posts 3 Posters 4.3k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    print(code)
    f:write(body)
    f:close()
    print(code)
    f:write(body)
    f:close()
      Are you sure?
      Using this version of your code:
      local reply,code, headers, status = http.request("http://pbs.twimg.com/media/CCROQ8vUEAEgFke.jpg")
      print (pretty {length = #reply, code = code, headers = headers, status = status})
      local reply,code, headers, status = https.request("https://u.cubeupload.com/jbcooper/16146313918060.jpg")
      gives me this output, showing that lots of bytes have been received...
       ––– 51 lines ––– 6.4 ms –––
        code = 200,
        headers = {
          ["accept-ranges"] = "bytes",
          ["access-control-allow-origin"] = "*",
          ["access-control-expose-headers"] = "Content-Length",
          age = "43902",
          ["cache-control"] = "max-age=604800, must-revalidate",
          connection = "close",
          ["content-length"] = "129373",
          ["content-type"] = "image/jpeg",
          date = "Tue, 20 Sep 2022 10:44:48 GMT",
          ["last-modified"] = "Fri, 10 Apr 2015 23:57:23 GMT",
          server = "ECS (lhb/63B8)",
          ["server-timing"] = "x-cache;desc= HIT,x-tw-cdn;desc=VZ,edge;dur=8",
          ["strict-transport-security"] = "max-age=631138519",
          ["surrogate-key"] = "media media/bucket/1 media/586679904554455041",
          ["timing-allow-origin"] = "https://twitter.com, https://mobile.twitter.com",
          ["x-cache"] = "HIT",
          ["x-connection-hash"] = "90f51e90a99324db0f571d118a350f3b3c8b49e130d1ebea21aeafd14f3cafe6",
          ["x-content-type-options"] = "nosniff",
          ["x-response-time"] = "353",
          ["x-tw-cdn"] = "VZ, VZ"
        length = 129373,
        status = "HTTP/1.1 200 OK"
        code = 200,
        headers = {
          ["alt-svc"] = 'h3=":443"; ma=86400, h3-29=":443"; ma=86400',
          ["cache-control"] = "private, max-age=14400",
          ["cf-cache-status"] = "MISS",
          ["cf-ray"] = "74d9f7cbac867729-LHR",
          ["last-modified"] = "Tue, 20 Sep 2022 10:44:48 GMT",
          nel = '{"success_fraction":0,"report_to":"cf-nel","max_age":604800}',
          ["report-to"] = '{"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=Phpy9q3l6o0X7pS%2BXX%2Bf6hJZhALJSPRGCXLZai7Sk%2BwfQ%2F2AGHCxizvvqGtmEb9%2FpFAW0TTS1i1O%2FOHlYIVkqH7bwwJsy%2F1CFyc5qTbvBjjnzDjvDNpdhXex%2Bjb5xBBi3gtQ"}],"group":"cf-nel","max_age":604800}',
          server = "cloudflare",
          ["strict-transport-security"] = "max-age=63072000; includeSubdomains",
          ["transfer-encoding"] = "chunked",
          ["x-frame-options"] = "DENY"
        length = 108321,
        Perhaps this is a question of platform.... if the HTTPS request is done on an older Vera (Lite, 3), its firmware doesn't support TLS 1.2 and the server and client may not be able to negotiate the encryption. This is also starting to manifest on Vera Plus, Edge, and Secure systems running 7.32 to servers requiring TLS 1.3. This is one reason so many plugins to remote APIs are dying off. Interestingly, the curl on 7.32 is built with a more modern encryption library than Vera's Lua ssl library, so using curl (e.g. with popen()) is often the (temporary) antidote.
        @akbooer, did you test on openLuup? If that's the case, your OS and Lua packages are almost certainly more modern and capable than that of current (and past) Vera firmware.
          Yes, this was under openLuup. My only remaining Vera is still running UI5, so I’m pretty sure that it would fail there. As the OP indicated, this wasn’t uniquely about Vera, so I hadn’t thought it worth trying.
          • parkercP Offline
            parkercP Offline
            parkerc
            Sorry, yes this is being done on my VeraPlus, with latest ‘production’ firmware 7.31..
            When I run this, i get nothing back not even an error for the https call.
            Print output
            { status="HTTP/1.1 200 OK", length=129373, headers={ x-content-type-options="nosniff", x-cache="MISS", server-timing="x-cache;desc=MISS, x-tw-cdn;desc=FT", x-served-by="cache-lhr6621-LHR, cache-tw-ZZZ1", content-length="129373", strict-transport-security="max-age=631138519", access-control-allow-origin="*", x-tw-cdn="FT", access-control-expose-headers="Content-Length", content-type="image/jpeg", timing-allow-origin="https://twitter.com, https://mobile.twitter.com", accept-ranges="bytes", connection="close", date="Tue, 20 Sep 2022 13:31:56 GMT", cache-control="max-age=604800, must-revalidate", last-modified="Fri, 10 Apr 2015 23:57:23 GMT" }, code=200 }
            • parkercP Offline
              parkercP Offline
              parkerc
              Is the lack of TLS 1.2 with Vera addressed with something like this, not sure how this works, but I assume there is a default if something is not specified ?
              local _, code = https.request{
                    url = url,
                    protocol = "tlsv1_2",
                   ResetData()
                   Log(" sent data status: " .. code)
              return code
                Maybe. There are ciphers and hashes within TLS 1.2 range, some of which are supported by 7.31 firmware, and some of which are not. Some less secure ones have been deprecated and many servers now exclude them.
                Try formulating your request with curl on the (Vera) command line. If you can get that to work, then (a) the Lua ssl library is the culprit, and (b) you can use curl (with popen() or by reading a temporary output file) for your request.
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  Thanks all..
                  Looks like curl is the way to go in situations like this..
                  Quick question in regards to being able to do this all in Lua on a VeraPlus, I came across the following bit of code (not sure of the origin, but i can see it specifies a certificate file, is this an option ?
                  require("socket")
                  local ssl = require("ssl")
                  local url = "test"
                  local params = {
                    mode = "client",
                    cafile = "/path/to/downloaded/cacert.pem", --<-- added cafile parameters
                    verify = "peer", --<-- changed "none" to "peer"
                    options = "all",
                  local conn = socket.tcp()
                  conn:connect(url, 443)
                  -- TLS/SSL initialization
                  conn = ssl.wrap(conn, params)
                  conn:dohandshake()
                  conn:send("GET / HTTP/1.1\n\n")
                  local line, err = conn:receive()
                  print(err or line)
                  conn:close()
                    Maybe, maybe not. Why don't you just try it? You're not playing with launch codes here. If it fails, you get disappointed, but that's about all. I would not use "peer", that's more strict and you have no client side certificate to negotiate with, I'd go back to "none". It's possible the root CA's are a problem, but more likely, it's one of several problems, and there's no workaround for the others (except curl, and that's only temporary, since it isn't being updated either).
                    The cafile, by the way, does not specify a certificate for the client (Vera), it specifies a number of root CAs, the ones at the top of the chain that issue known-good certificates below them. They are used to validate the server's certificate (i.e. make sure it's signed by a trusted entity -- one of those root CAs), they are not used as a client cert for the Vera.
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      Ok, not had much luck with the variations I tried, 😞
                      One thing I did notice was that the luasec version on VeraPlus is v0.4 and the openssl version is v1.0.2
                      # openssl version
                      OpenSSL 1.0.2l  25 May 2017
                      Checking the luasec guidance here, https://github.com/brunoos/luasec/wiki/LuaSec-1.0.x , that VeraPlus openSSL version supports luasec v 1.0.x ?
                      Without being able to install/use Luarocks, any idea how to upgrade from luasec 0.4 to 1.0.x?
                        159.5k
