  2. Code/Snippet library
  3. Get your Alexa replies to the device you've asked them to with VeraAlexa plug-in
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Luup : Error Handling
Help with luup.chdev.sync
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
14 Posts 4 Posters 3.8k Views 4 Watching
      "RunCommand",
      "Say",
    Very cool indeed 🙂
      Ooooh thanks, @therealdb. I'd been thinking about this!
        Another idea: Getting an Ha bridge to run a scene which would run this function.
        You can then reduce the number of habridge calls and go into any room and say alexa, turn light on and it would turn on the light of the exact room you are in. 🙂
        Thinking about it, you may still need to keep the per room light commands in case you need to turn off a device in another room than the one you are in but it is one step in the right direction.
          If you put your alexa into the same group of the lights, you can already do that. No need to create a special scene.
          I'm using it to ask questions with no needs to create a skill. Something like "what's the pool's temperature!", "has the dryer finished?", etc.
            Really? How do you name the lights then? Do you have a bunch of devices called "light"
              @rafale77 said in Get your Alexa replies to the device you've asked them to with VeraAlexa plug-in:
              Just place them in the same room and it's automatically done. Be sure to place the echo device in the same room. It should be work with TVs as well, thus I just have one connected to Alexa atm.
              I won't post screenshots since my app is in Italian, but it's under groups.
              Then be sure to place the echo as well.
              EDIT: my wife accidentally turned on every light in the rooms last night, because I grouped my son's room with ours, because it's so useful to just say 'turn off light/lights' from the bed and be sure the entire floor is darken 🙂
                I have a 'Turn the house off' Reactor 🙂
                I love the idea of the lights, though. Either way. I need to trip some of the lastalexa stuff but they are mostly things that are useful when we go out.....
                  Hint for those of us with no clue?
                  Cheers
                    Quick operational question about VeraAlexa...
                    I've got a nice Rule in MSR monitoring the 'LastResponse' variable, watching for mention of a "cookie". It then sends me an email, reminding me to visit alexa.amazon.com in order for the cookie to be created again.
                    My question is: Must I also then go into my 'Alexa' device on Vera and manually change the 'Configured' value from 1 back to 0? I have been doing that, even adding a browser refresh after, but notice such a step is not mentioned in the "no cookie" message. So I'm probably overthinking things.
                    Thanks for any clarification!
                      I do not believe so. Certainly I never have
                      • LibraSunL LibraSun
                        @librasun no need to have it reconfigured. It’s only necessary to download a new script.
                          In fact my cookie expired today so definitely not required 🙂
                            I always know the day the cookie expires, even before MSR sends me the warning, because a very specific nighttime Rule (to turn off the screen of my Echo Spot) will fail to run, so the Echo Spot doesn't go "boop" at bedtime. 🙂
                              @librasun said in Get your Alexa replies to the device you've asked them to with VeraAlexa plug-in:
                              Either my 'Shutting down the power / Sonic deadline is up' (1) won't be said, or the morning temperature report tends to tell me.
                              (1) Virtual coconut(s) for anyone that can get the movie links 😉
                                157.7k
