  2. Code/Snippet library
  3. Help with luup.chdev.sync
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Luup : Error Handling
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
14 Posts 4 Posters 4.5k Views 4 Watching
      oh boy, I had an epiphany! I was calling append only on new devices, instead of every device! If omitted, the existing devices are removed!
        Yes, indeed. It's a curious construct, but we have learned to live with it.
        My particular frustration is that some of the other parameters, which are standard in the call to create new devices, are not available here. I think that the whole chdev module is only there to avoid Vera's standard reload for every new device created.
        • parkercP Offline
          parkercP Offline
          parkerc
          I have a similar luup.chdev.sync issue, where the sync removes the previously created child, when it should be creating a new child device..
          Example in the logs.
          09	12/23/21 22:26:45.239	Child_Devices::ProcessChildDevice created device 1159 id JohnDevice under 1152 topmost parent 1152 <0x71eb6520>
          09	12/23/21 22:26:45.240	Child_Devices::Synchronize removing 1158 from parent 1152 <0x71eb6520>
          My code has a handler that receives a json file, which it processes, and if it doesn’t find an existing entry to update, it will call this code to create a child device ..
          local childDeviceIndex = {}
          child_devices = luup.chdev.start(ParentDevice)
          		-- Tells Luup to start enumerating children for this device based on it's dev_id
          		debug("RoomMe parent lul_device  = " ..ParentDevice)
          		luup.chdev.append(ParentDevice,child_devices, j.id, j.userName.."'s Device", "urn:schemas-nodecentral-net:device:RoomMe:1", "D_RoomMeDevice1.xml", "", "urn:nodecentral-net:serviceId:RoomMeDevice1,Icon=".. iconCalc .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,uiLabel=TBC\nurn:nodecentral-net:serviceId:RoomMeDevice1,userId=".. j.userId .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,id=".. j.id .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,userName="..j.userName.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,roomName="..j.roomName.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,eventType="..j.type.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,eventTime="..j.eventTime.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,sensorId="..j.sensorId.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,eventName="..j.event.name.."", false)
          		debug("New RoomMe device created id = " .. j.id .. " for ".. j.userName)
          		luup.chdev.sync(ParentDevice, child_devices)
          			if (v.device_num_parent == ParentDevice) then -- populate child device table
          				childDeviceIndex[v.id]=k
          What am I missing in the above that causes it to not append, but replace ?
            @parkerc …
            @therealdb said in Help with luup.chdev.sync:
            …does this not describe your situation?
            parkercP 1 Reply Last reply
              @parkerc …
              parkercP Offline
              parkercP Offline
              parkerc
              @akbooer said in Help with luup.chdev.sync:
              @parkerc …
              Hi, I did read that, but i wasn’t sure if it was related or not, as I didn’t quite understand it..
              All my previous use of creating child devices, was done during the initial set up, as i had everything discovered/defined upfront.
              This time around it’s different, as devices need to be created on the fly, whenever something calls the handler..
              Re-reading the thread again..
              Do I have to retrieve all the attributes/variable of any pre-existing child device that’s associated with that same parent, and recreate them too as part of the ‘append’ process for a new child device that needs to be added?
              • parkercP parkerc
                @parkerc …
                @parkerc said in Help with luup.chdev.sync:
                Yes, you’ll need to append every child decide that must be present. So, both existing and new ones.
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  Thanks @therealdb
                  That was what I was afraid of 😞
                  What is the best way to do that?
                  How are you retrieving all the variables of any pre-existing child devices and then recreating them ?
                  Do I just loop through everything that has the parent device ID associated and recreate ?
                  -- Create new one first then through existing ?
                             << luup.chdev_append - CODE HERE >>
                  If I append all existing ones first, before creating the new one, I assume that will duplicate them and increment the device numbers before registering the new one?
                  If so, that suggests, I need to append the new one first, and then append the existing ones ? But again won’t that increment the device numbers 🤯
                  There must be an order to which you do this?
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    OK, looking at how others have done it, I can see the following in @toggledbits Switchboard plugin, so this gives me something to work with….
                    --[[ Prep for adding new children via the luup.chdev mechanism. The existingChildren
                    	 table (array) should contain device IDs of existing children that will be
                    	 preserved. Any existing child not listed will be dropped. If the table is nil,
                    	 all existing children in luup.devices will be preserved.
                    local function prepForNewChildren( )
                    	D("prepForNewChildren()")
                    	local existingChildren = {}
                    	for k,v in pairs( luup.devices ) do
                    		if v.device_num_parent == pluginDevice then
                    			local d = {}
                    			d.devnum = k
                    			d.device = v
                    			d.device_file = luup.attr_get( "device_file", k ) or ""
                    			d.device_json = luup.attr_get( "device_json", k ) or "D_BinarySwitch1.json"
                    			d.behavior = getVar( "Behavior", "Binary", k, MYSID )
                    			if d.device_file ~= "" then
                    				table.insert( existingChildren, d )
                    	local ptr = luup.chdev.start( pluginDevice )
                    	for _,d in ipairs( existingChildren ) do
                    		local v = d.device
                    		D("prepForNewChildren() appending existing child %1 (%2/%3)", v.description, d.devnum, v.id)
                    		luup.chdev.append( pluginDevice, ptr, v.id, v.description, "",
                    			d.device_file, "", "", false )
                    	return ptr, existingChildren
                    And then the add child code is here..
                    function jobAddChild( ctype, cname, count, pdev )
                    	assert(luup.devices[pdev].device_type == MYTYPE)
                    	assert(dfMap[ctype])
                    	local df = dfMap[ctype]
                    	count = math.min( 16, math.max( 1, tonumber(count) or 1 ) )
                    	L("Adding %1 children %2 (type %2)", count, df.name, ctype)
                    	gatewayStatus( "Creating child. Please hard-refresh your browser!" )
                    	local ptr,children = prepForNewChildren()
                    	local id = 0
                    	for _,d in ipairs( children ) do
                    		local did = tonumber(d.device.id) or 0
                    		if did > id then id = did end
                    	for _=1,count do
                    		id = id + 1
                    		local vv = { MYSID .. ",Behavior=" .. ctype }
                    		table.insert( vv, ",device_json=" .. df.device_json )
                    		table.insert( vv, ",category_num=" .. df.category or 3 )
                    		table.insert( vv, ",manufacturer=" .. DEV_MFG )
                    		table.insert( vv, ",model=Switchboard Virtual " .. df.name )
                    		if df.subcategory then
                    			table.insert( vv, ",subcategory_num=" .. df.subcategory )
                    		local nn = cname == nil and ( "Virtual " .. df.name .. " " .. id ) or
                    			( tostring(cname) .. ( count > 1 and tostring(id) or "" ) )
                    		luup.chdev.append( pdev, ptr, id, nn, "",
                    			df.device_file,
                    			table.concat( vv, "\n" ),
                    			false )
                    	luup.chdev.sync( pdev, ptr )
                    	return 4,0
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      Ok, think I’ve got it working now.. FYI for anyone who comes across this.. (thanks to @toggledbits code as the guide.)
                      First off , seems obvious, but prepare for any new devices, but creating a table of what’s there already..
                      local function prepForNewChildren(ParentDevice)
                      	-- Create table of existing child devices associated with the parent device
                      		if v.device_num_parent == ParentDevice then
                      			local d = {}
                      			d.devnum = k
                      			d.device = v
                      			d.device_json = luup.attr_get( "device_json", k ) or ""
                      	-- Start enumerating children based on the parent's device_id
                      	local ptr = luup.chdev.start( ParentDevice )
                      		local v = d.device
                      Then utilise your create child code/function, that calls the what children are already there function first 🙂
                      local function createNewRoomMeChildDevice(j, ParentDevice)
                      	-- j is the decoded json provided by the handlers which has the new child device info
                      	debug("Creating child device for lul_device  = " ..ParentDevice)
                      	-- prepare for the addition of new child devices
                      	local ptr,children = prepForNewChildren(ParentDevice)
                      	-- Create and append new child device to the existing parent device
                      	luup.chdev.append(ParentDevice,ptr, j.id, j.userName.."'s Device", "urn:schemas-nodecentral-net:device:RoomMe:1", "D_RoomMeDevice1.xml", "", "urn:nodecentral-net:serviceId:RoomMeDevice1,Icon=".. iconCalc .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,uiLabel=TBC\nurn:nodecentral-net:serviceId:RoomMeDevice1,userId=".. j.userId .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,id=".. j.id .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,userName="..j.userName.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,roomName="..j.roomName.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,eventType="..j.type.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,eventTime="..j.eventTime.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,sensorId="..j.sensorId.."\nurn:nodecentral-net:serviceId:RoomMeDevice1,eventName="..j.event.name.."", false)
                      	-- Sync all child devices
                      	luup.chdev.sync(ParentDevice, ptr)
                        In your case, you likely have no need of a separate object to hold the child data in the pre-scan, you can just use existingChildren as an array of device numbers (from k in the first/pre-scan loop) and then use it to index into luup.devices in the chdev.appends later.
                        You probably don't even need the pre-scan at all in most cases, you can just iterate over luup.devices inside the open chdev and add the existing devices directly, without creating existingChildren and a second loop.
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Hi @toggledbits
                          Do you mean something like this..
                          local function createChildDevices(ParentDevice, decodedJSON)
                          	-- build table of any existing child devices
                          			local d = {}
                          			d.devnum = k
                          			d.device = v
                          	-- Start enumerating children based on the parent device_id
                          			local v = d.device
                          	luup.chdev.append(ParentDevice,ptr, decodedJSON.id, decodedJSON.userName.."’s Device", "urn:schemas-nodecentral-net:device:RoomMe:1", "D_RoomMeDevice1.xml", "", "urn:nodecentral-net:serviceId:RoomMeDevice1,Icon=".. iconCalc .."\nurn:nodecentral-net:serviceId:RoomMeDevice1,uiLabel=TBC\nurn:nodecentral-net:serviceId:RoomMeDevice1,DeviceName="..decodedJSON.device.name.."", false)
                            That's what I mean you don't need to do... is that what you meant?
                            • parkercP Offline
                              parkercP Offline
                              parkerc
                              No, sorry - that was my altered version 🙂
                              • I had changed it from using two separate functions to just the one. I tried to do as you said, but I couldn’t see what else I could remove without breaking it ?
                                163.3k
