  2. Code/Snippet library
  3. Luup : Error Handling
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Help with luup.chdev.sync
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
12 Posts 4 Posters 4.5k Views 4 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    				return false
    				return true
    	</functions>
      Assuming you’re talking about startup errors, the appropriate way is to use luup.set_failure() and then exit the startup code with a suitable message.
      http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_set_failure
      In openLuup, the console Startup page displays the message.
      • parkercP Offline
        parkercP Offline
        parkerc
        Thanks @akbooer , I’ll look into that Luup.set_failure() option.
        When you “say exit the startup code with a suitable message” - do you mean use Luup.task ?
        I’ve got that in the current script but I’ve never seen it appear in the UI.? What I would like is for the parent device to say/show that the IP Address is missing etc. ?
          Your startup function (IPPowerStartup) can (probably should) return three values: a boolean success/failure flag for the startup, a text string error message (or nil if none), and a string containing the name of the plugin.
            Your function is just a check and should only return the status as suggested above. This code should be done somewhere else - it's not part of a check:
            The function should be declared local. Scope is important.
            Also the if statement doesn't need an else section because the if the if statement returns false the function is finished. By definition the rest must be true.
            And are you using log or debug. It's good to be consistent, it makes things more readable.
            On a different note - I like to learn from others. So on my PC, I have many different plugins, each in their own folder. I use Notepad++ (considered essential equipment here) as it allows me to search all the *.lua files for items of interest. So a search on luup.task shows me many examples, including one that has been used incorrectly.
            parkercP 1 Reply Last reply
            • A a-lurker
              parkercP Offline
              parkercP Offline
              parkerc
              @a-lurker said in Luup : Error Handling:.
              I’m exactly the same , I have folders of the stuff, but I’m always amazed at the variation out there. Regarding your question about using log and debug, I have both set up, see below.
              local DEBUG_MODE = true
              local function log(text, level)
                 luup.log("IPPower 9528: " .. text, (level or 1))
              local function debug(text)
                 if (DEBUG_MODE == true) then
              log("debug: " .. text, 50)
              OK, so back to my plugin, when it comes to the startup function, it sounds like that should be pretty basic, then ?
              @toggledbits - I had looked at some of your start up function too.
              For LuaView
                      function startLuaView(dev)
                          luup.log("LuaView 1.7 starting.")
                          local isOpenLuup = luup.openLuup ~= nil
                          luup.variable_set( "urn:toggledbits-com:serviceId:LuaView1", "isOpenLuup", isOpenLuup and "1" or "0", dev )
                          if luup.attr_get( "device_json", dev ) ~= "D_LuaView1.json" then
                              luup.log("LuaView resetting static JSON file, Luup reload necessary...")
                              luup.attr_set( "device_json", "D_LuaView1.json", dev )
                              luup.reload()
                          if luup.variable_get( "urn:toggledbits-com:serviceId:LuaView1", "AceOptions", dev ) == nil then
                              luup.variable_set( "urn:toggledbits-com:serviceId:LuaView1", "AceOptions", "", dev )
                          luup.register_handler("LuaViewRequestHandler", "LuaView")
                          return true, "OK", "LuaView"
              And SiteSensor
                                function startupSiteSensor(dev)
              			luup.log("SiteSensor Plugin START-UP!")
              			SiteSensor = require("L_SiteSensor1")
              			siteSensorRunQuery = SiteSensor.runQuery
              			siteSensorRequestHandler = SiteSensor.requestHandler
              			luup.register_handler("siteSensorRequestHandler", "SiteSensor")
              			return SiteSensor.init(dev)
              Both were different approaches..
              Form mine, is this better then ?
              return true, "OK", "IPPower 9258"
              If that’s Ok for the startup part, where should i store all the other functions/activities , such as check if IP is there, and create all the child devices ?
              • checkIPPowerSetUp(lul_device)
              • createChildIPPowerOutlets(lul_device)
              • parkercP Offline
                parkercP Offline
                parkerc
                If it helps here is the Implementation file…
                <?xml version="1.0" encoding="ISO-8859-1"?>
                <implementation >
                  <settings>
                        <protocol>raw</protocol>
                  </settings>
                	<functions>
                		local POLLING_INTERVAL = 30
                		local OUTLET_START = 61 -- API returns the first socket as P61
                		local OUTLET_END = 68 -- depending on your device, it can be a 4 or 8 port, so 64 or 68
                		local DEBUG_MODE = true -- turn on debugging
                		local PV = "1.1" -- plugin version number
                		local ipAddress
                		local childDeviceIndex = {}
                        	luup.log("IPPower: " .. text, (level or 1))
                		function IPPowerPoller() -- Call IPPower to return state of each outlet
                			local user = "admin"
                			local pass = "12345678"
                			debug("Polling IPPower Device")
                			local url = "http://" .. ipAddress .. "/set.cmd?user=".. user .. "+pass=" .. pass .. "+cmd=getpower"
                			luup.call_timer("IPPowerPoller", 1, POLLING_INTERVAL, "", "")
                			debug("Calling status  " .. url)
                			if (data) then
                				debug("Response received " .. data)
                				-- Example response is "P61=0,P62=1,P63=0,P64=0,P65=1,P66=0,P67=0,P68=0"
                			else
                				log("Empty response returned")
                			for v = OUTLET_START,OUTLET_END do
                				local value = string.match(data, "P"..v.."=(%d)")
                				if (value) then
                					luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, childDeviceIndex["P"..v])
                				else
                					log("Empty value returned")
                		function createChildIPPowerOutlets(lul_device)
                    		child_devices = luup.chdev.start(lul_device)
                			-- Tells Luup to start enumerating children for this device based on it's dev_id
                				luup.chdev.append(lul_device,child_devices, "P" .. v, "Switch" .. v, "urn:schemas-micasaverde-com:device:GenericIO:1", "D_IPPower1.xml", "", "", false)
                				debug("Child device created with id = P" .. v, " and description = Switch" .. v)
                   			luup.chdev.sync(lul_device, child_devices)
                	        	if (v.device_num_parent == lul_device) then -- populate child device table
                					childDeviceIndex[v.id]=k
                				return false
                				return true
                	</functions>
                	<actionList>
                		<action>
                			<job>
                				if (data) then
                					debug("Received response " .. data)
                				else
                					log("Received empty response")
                				if (value) then
                				else
                					log("Value is empty")
                			</job>
                			</action>
                		</actionList>
                </implementation>
                • parkercP parkerc
                  For LuaView
                                  luup.reload()
                  And SiteSensor
                  @parkerc LuaView is an odd case, because it requires no significant Lua implementation so I just left it all in the XML. SiteSensor and most others are better examples of my style. I prefer having as much of the implementation in a Lua module as possible, because I find XML horrid to use for wrapping code. But, that does require understanding of and attention to scope.
                    I avoid putting Lua code into the implementation file as absolutely much as possible because of the code wrapping fiasco it entails. I try to keep the majority of it in a single separate file. So:
                    This code is not required unless you are using serial streams of some description. Replace it with the code further below. It loads up the Lua code in the file.
                      <settings>
                      </settings>
                    with
                    <files>L_IPPowerPoller1.lua</files>
                    The leading 'L_' and the tailing '1' are convention and are probably defined in some standard somewhere.
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      Thanks @a-lurker and @toggledbits
                      @a-lurker - looking back I might have got the Raw reference from your Broadlink plugin implementation file..
                      <implementation>
                          <specVersion>
                              <major>1</major>
                              <minor>0</minor>
                          </specVersion>
                          <files>L_BroadLink_Mk2_1.lua</files>
                          <settings>
                          </settings>
                          <startup>luaStartUp</startup>
                      With this set up, i like the idea of calling a lua file, but quick question on the above where is the luastartUp function that’s being called ?
                      It also looks like I may have two route to load the module/lua file, either specifically using <files>L_IPPowerPoller1.lua</files> or within the defined initialise or startup function
                      function IPPowerstartup(dev)
                          luup.log("IPPower Plugin START-UP!")
                          IPPower = require("L_IPPower1")
                      Ok, found another Implementation example from Rene, which calls a lua module/file and i can see the start up function is in that file now..
                      	I_TeslaCar1.xml; Vera/openLuup "TeslaCar" Plug-in
                      	Written by Rene Boer
                      	V1.15 13 August 2020
                      <implementation>
                      	<settings>
                      	</settings>
                      	<files>L_TeslaCar1.lua</files>
                      	<startup>TeslaCarModule_Initialize</startup>
                      	<actionList>
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        As this thread has moved beyond Error Handling, I’ve start a focussed new thread to show my journey with this plugin - > https://smarthome.community/topic/779/add-on-aviosys-ippower-9258
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Never thought I’d utter these words; but I’ve been a bit prolific of late building plugins !! (9 in the last month or so )
                          ok, so they may not be the most elegant in design, but they all seem to work, which is the main thing 🙂
                          Working on number 10, I’ve returned to the error handling topic, as I’m curious about the pros/cons of luup.set_failure() vs luup.device_message()
                          luup.set_failure seems so impersonal and rigid (creating multi-variables) compared the device_messages - what is the value of set_failure over say a ‘job error’ red device message ?
                          What are peoples thoughts ?
                            163.6k
