  2. Code/Snippet library
  3. Vera StaticJSON Help - Showing a button’s status/selection (in/out) in the UI ?
Scene number?
Embarrassing mind blank
Hi I’ve been investing a lot of time recently trying to digitise everything I can, and my current adventure is with all my paper documents. My tool of choice is Paperless-ngx, which so far is an amazing open source solution, and highly recommended if you’re interest in such a thing… Such a move to Paperless would not be complete without some form of integration into Vera / openLuup, and thankfully it has a nice Rest API (https://paperless-ngx.readthedocs.io/en/latest/api.html) I can use. So far I’ve been able to make use the GET requests, to provide document counts etc., but it’s the mutipart/form data piece where I’m struggling.. The Curl command to upload a document, is as follows curl -H "Authorization: Basic Y2hyaXM62tgbsgjunotmeY2hyaXNob3N0aW5n" -F "title=Companies House File 10" -F "correspondent=12" -F "document=@/mnt/nas/10.pdf" http://192.168.102.134:8777/api/documents/post_document/ But, I’d like to know how to do this with Lua code, more just to help me in my Lua learning curve, and what I thought would be reasonably straight forward thing to do, has turned out to be quite the opposite Sending a multipart form data submission via http.request, is not as straight forward as I hoped. If anyone has any time to help, I’d appreciate some guidance on what I’m missing with the following, as based on the feedback, it looks like it not seeing the file (which I think I’ve confirmed by trying to sending both the curl and Lua commands to httbin.org ) … local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local lfs = require("lfs") local username = "username" local password = "password" local httpendpoint = 'http://httpbin.org/post' local filepath = "/mnt/nas/10.pdf" local file = io.open(filepath, "rb") local contents = file:read( "*a" ) -- https://stackoverflow.com/questions/3508338/what-is-the-boundary-in-multipart-form-data local boundary = "-----BoundaryePkpFF7tjBAqx29L" local send = "--"..boundary.. "\r\nContent-Disposition: form-data; title='Companies House File'\r\n" .."----"..boundary.. "\r\nContent-Disposition: form-data; document="..filepath.. "\r\nContent-type: application/pdf".."\r\n" ..contents.."\r\n" .."------"..boundary.."--\r\n" -- Execute request (returns response body, response code, response header) local resp = {} local body, code, headers, status = http.request { url = httpendpoint, method = 'POST', headers = { ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)), ["Content-Length"] = lfs.attributes(filepath, 'size'), ['Content-Type'] = "multipart/form-data; boundary="..boundary, }, -- source = ltn12.source.file( io.open(filepath,"rb") ), source = ltn12.source.file( io.open(send) ), sink = ltn12.sink.table(resp) } print(body, code, headers, status) print(table.concat(resp)) if headers then for k,v in pairs(headers) do print(k,v) end end
Luup : Fitbit API
Hi I’m trying out the Fitbit api, not only to extract some activity data for a potential plugin, but also to learn more about OAuth 2.0. More details can be found here.. https://dev.fitbit.com/build/reference/web-api/developer-guide/getting-started/ In addition to having a fitbit account, to get going with any integration, you need to register your app, via here.. https://dev.fitbit.com/apps With an app registered, I’ve called mine “VERA” , I’ve written chunks of Lua code to support the various steps, (completed manually) my goal now is to try and put them all together into functions to be called in sequence on my Vera and/or OpenLuup. Where I’m getting stuck is with the authorisation code step, which Fitbit provides appended to the domain name I registered with them when registered my app .. Here’s an example of a redirect URL that Fitbit will redirect the user too, with their associated authorisation code, which I need in the process later on to obtain the required access token. (More specific details are here - https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/ ) https://myapp.com/callback?code=d62d6f5bdc13df79d9a5f#_=_ And it’s the d62d6f5bdc13df79d9a5f part of that new page/URL which I need.. How best do i capture/process the URL call Fitbit issues? I assume this is where a luup.register_handler would come in, and I could register my Vera handle (using https ?, as that’s required by Fitbit) as the redirect domain/url e.g. https://veraip:3480/data_request?id=lr_fitbit& So Fitbit would redirect to.. https://veraip:3480/data_request?id=lr_fitbit&/?code=d62d6f5bdc13df79d9a5f#_=_ But that doesn’t seem to work.. Any suggestions on how to do this would be appreciated.. function FitbitRequestHandler(lul_request, lul_parameters, lul_outputformat) for k,v in pairs(lul_parameters) do luup.log ('fitbit_Handler: parameters are: '..tostring(k)..'='..tostring(v)) end if next(lul_parameters) == nil then luup.log("lul_parameters Table is empty") end local html = "</html><head>" .. "</head>" .. "<body>" .. "PRINTING" .. "\n" .. " lul_request: " .. tostring(lul_request) .. "\n" .. " lul_parameters: " .. tostring(lul_parameters) .. "\n" .. " lul_outputformat: " .. tostring(lul_outputformat) .. "\n" .. "</body></html>" return html, "text/html" end luup.register_handler("FitbitRequestHandler", "fitbit") Thanks is advance…
Luup : Error Handling
Help with luup.chdev.sync
Add-on - Aviosys IPPower 9258
Hi Picking up from another thread this is to focus on the creation of the 4 key elements of a new Plugin for my Aviosys IPPower 9258, which are quite old, and I don’t believe are made anymore, but they seem to have a simple http api interface to cut my teeth on with a plugin. First the device file, which is to support the creation/set up of the device, and here I explain what it is, tell Vera what the implementation file and .json file is, and also leverage the pre-existing Switch and HA capabilities.. Device File - D_IPPower.xml <?xml version="1.0"?> <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <device> <deviceType>urn:nodecentral-net:device:IPPower:1</deviceType> <staticJson>D_IPPower1.json</staticJson> <manufacturer>Aviosys</manufacturer> <modelDescription>IPPowerSwitch</modelDescription> <modelName>IPPower9258</modelName> <handleChildren>1</handleChildren> <implementationList> <implementationFile>I_IPPower1.xml</implementationFile> </implementationList> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <SCPDURL>S_SwitchPower1.xml</SCPDURL> </service> <service> <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType> <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId> <SCPDURL>S_HaDevice1.xml</SCPDURL> </service> </serviceList> </device> </root> Next it is the Implementation file, which thanks to the feedback on this forum, will focus on a specific Lua file, where all the code will be, the only thing I need to add here are the Actions (what do I want it to be able to do etc.) Implementation file - I_IPPower.xml <?xml version="1.0"?> <!-- I_IPPower.xml; Vera/openLuup "IPPower 9258" Plug-in V1.1 Nov 2021 --> <implementation> <settings> <protocol>crlf</protocol> </settings> <files>L_IPPower1.lua</files> <startup>IPPowerStartup</startup> <actionList> <action> <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId> <name>SetTarget</name> <job> local url = "http://" .. ipAddress .. "/set.cmd?user=admin+pass=12345678+cmd=setpower+" .. luup.devices[lul_device].id .. "=" .. lul_settings.newTargetValue luup.log("Sending command " .. url) local status, data = luup.inet.wget(url) if (data) then debug("Data received = " .. data) else log("No Data received !! ") end local value = string.match(data, luup.devices[lul_device].id.."=(%d)") if (value) then luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", value, lul_device) else log("Value returned is empty") end </job> </action> </actionList> </implementation> The other two files D_IPPower.json, and L_IPPower.lua are still being worked on so i will add later … If anyone notices any improvement
Hi all I’ve been trying to use the Hue api and some of my Lua knowledge to create an energy calculator based on the brightness and wattage of specific models of hue bulb registered on the hub I’ve pretty much got there, the only stumbling block I have is how I total up all the individual bulb wattages. Can anyone help ? It’s likely an easy thing for someone more experienced to see, but as I only dip in and dip out now and then, the correct code/syntax does not always come to mind. Note : as I’ve tried various routes, I’ve commented some things out, but you should be able to get the idea of what I’m trying to do.. Create device json from Hue Hub Decode JSON and extract key values to a table Calculate approx watts based on bulb model and/or watts function Total up watts of all bulbs that are switch on. Code below... local hueBridgeIP = '192.168.1.29' local hueBridgeAPI = "80uCoXjnn2LNLhxEJ9PW6nmt-G5KWQ2uP3oONAvcm0j" function getHueLight() local http = require('socket.http') local ltn12 = require('ltn12') local json = require('dkjson') t = {} local url = string.format("http://%s/api/%s/lights", hueBridgeIP, hueBridgeAPI) b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'} huestring = tostring(table.concat(t)) local hue, pos, err = json.decode(huestring, 1, nil) huelights = {} for k, v in pairs(hue) do local modelno = string.gsub(hue[k]['modelid'], "%s+", "") table.insert(huelights, {k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']}) print(k, hue[k]['state']['on'], hue[k]['name'], hue[k]['state']['bri'], modelno, hue[k]['state']['reachable']) end end local fourpointeightwattTable = { [ 1 ] = 0.6 , [ 2 ] = 0.7 , [ 3 ] = 0.8 , [ 4 ] = 0.9 , [ 5 ] = 1.2 , [ 6 ] = 1.4 , [ 7 ] = 1.7 , [ 8 ] = 2.0 , [ 9 ] = 2.3 , [ 10 ] = 2.6 , [ 11 ] = 2.9 , [ 12 ] = 3.1 , [ 13 ] = 3.5 , [ 14 ] = 4.0 , } local sevenwattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.4 , [ 7 ] = 2.7 , [ 8 ] = 3.0 , [ 9 ] = 3.5 , [ 10 ] = 3.9 , [ 11 ] = 4.5 , [ 12 ] = 5.1 , [ 13 ] = 5.5 , [ 14 ] = 6.4 , } local ninewattTable = { [ 1 ] = 1.6 , [ 2 ] = 1.7 , [ 3 ] = 1.8 , [ 4 ] = 1.9 , [ 5 ] = 2.2 , [ 6 ] = 2.5 , [ 7 ] = 2.9 , [ 8 ] = 3.5 , [ 9 ] = 3.8 , [ 10 ] = 4.6 , [ 11 ] = 5.5 , [ 12 ] = 6.5 , [ 13 ] = 7.7 , [ 14 ] = 8.5 , } function fourpointeightgetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.2 elseif index >= 15 then return 4.8 else return fourpointeightwattTable[index] end end function sevengetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 7.0 else return sevenwattTable[index] end end function ninegetWattage(hue) local index = math.floor(hue / 16.5) if index <= 0 then return 0.4 elseif index >= 15 then return 9.0 else return ninewattTable[index] end end local total = 0 local Value = 0 local huewatts = {} for k,v in pairs(huelights) do if v[2] == true and v[5] == "RS125" and v[6] == true then local watts = fourpointeightgetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("four point eight watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[5] == "LWA004" and v[6] == true then local watts = sevengetWattage(v[4]) local Value = tonumber(watts) local total = total + watts print("seven watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) elseif v[2] == true and v[6] == true then local watts = ninegetWattage(v[4]) local Value = tonumber(watts) local total = total + Value print("nine watts") print(v[5], v[4], v[2], v[3], watts) table.insert(huewatts, {v[5], v[4], v[2], v[3], watts}) --print(watts) --print(total) end end print(total) print(huewatts) -- confirm if table it there (TBC)
UDP Datagrams
Luup : Foscam API
Help with luup.call_delay()
12 Posts 2 Posters 3.8k Views 2 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi
    I’m putting the finishing touches to a HDMI Matrix plugin, and while I have it working well - I can’t find anything on the Vera/MIOS wikis that tells me how I can show if a UI button is pressed or not (to reflect a input choice that is selected)
    Here’s a screenshot of the child outputs I’ve created for the Matrix switcher. (The plugin creates a parent device and then 4 children to show the Matrix Outputs - parent is not shown - and the idea is that’s you select the input number for the respective output)
    Here is an extract of the button element in the associated JSON file used for the child devices..
    					"ControlGroup": "1",
    					"ControlType": "button",
    					"top": "0",
    					"left": "0",
    					"Label": {
    						"lang_tag": "Input1",
    						"text": "Input1"
    					"Display": {
    						"Top": 60,
    						"Left": 50,
    						"Width": 75,
    						"Height": 20
    					"Command": {
    						"Service": "urn:nodecentral-net:serviceId:SYMatrix1",
    						"Action": "SYCall",
    						"Parameters": [
    								"Name": "action",
    								"Value": "I1"
    The associated command calls the parent implementation file SYCall - (The value “I1” relates to a element of the URL that needs to be called to select that associated input)
    	<action>
    		<serviceId>urn:nodecentral-net:serviceId:SYMatrix1</serviceId>
    		<name>SYCall</name>
    		<run>
    			SYMatrix.SYCall(lul_device, lul_settings.action, lul_settings)
    		</run>
    	</action>
    And then the Lua file (L_****) has holds the SYCall function
    function SYCall (deviceNo, action, settings)
      Look at the D_MotionSensor1.json standard static JSON file. It's a good example using just two buttons (Armed, Disarmed) in multi-state configuration (like radio buttons, only one pressed at a time), but four would work the same way.
      • parkercP Offline
        parkercP Offline
        parkerc
        Thanks @toggledbits
        Is it the "ControlCode": option ?
        ''ControlCode''' - a string containing the control code of this control (it is recommended to be unique for each device type)
        I don’t seem to have that in mine, and looking it up i can see it used elsewhere, but as for an explanation all I could find was the above, how is it used ?
          Hmmm... in /etc/cmh-lu? It's a standard static JSON file. In any case, the key is:
              "Display": {
                  "Service": "urn:example-com:serviceId:MyServiceName1",
                  "Variable": "MyStateVariable",
                  "Value": "Button1Value"
          These three keys in the Display section tie the button state to the state variable and value named. In your case, presumably each button is going to have it's own value (1, 2, 3, 4...?). The UI code will track that state variable and highlight (show in active state) any button that matches.
          If you do this in a multi_state_button control type, which has a special structure, its contained buttons will act like radio buttons (sort of). If you just implement them separately as regular button control type, you can have multiple pressed at the same time (presumably, then, each button will be looking at a different state variable for its magic value). The Switchboard virtual scene controller uses these to create, on the fly, a static JSON file for the button configuration set by the user.
          To save you some time, here's the relevant section of the D_MotionSensor1.json file:
          					"ControlType": "multi_state_button",
          					"top": "0",
          					"left": "1",
          					"states": [
          							"Label": {
          								"lang_tag": "ui7_cmd_arm",
          								"text": "Armed"
          							"Display": {
          								"Service": "urn:micasaverde-com:serviceId:SecuritySensor1",
          								"Variable": "Armed",
          								"Value": "1"
          							"Command": {
          								"Action": "SetArmed",
          								"Parameters": [
          										"Name": "newArmedValue",
          										"Value": "1"
          							"ControlCode": "arm"
          							"Label": {
          								"lang_tag": "ui7_cmd_bypass",
          								"text": "Disarmed"
          							"Display": {
          								"Value": "0"
          							"Command": {
          								"Parameters": [
          										"Value": "0"
          							"ControlCode": "bypass"
          See the control type is multi_state_button, so this is a radio-style configuration. If you look at the Display section for each of the elements of the states array, you will see they are both looking at urn:...:SecuritySensor1/Armed for the value 0 or 1. The first button, labeled "Armed", will be highlighted/active when the Armed state variable is 1, and the "Disarmed" button will be highlighted when it's 0. The Command section for each tells it arm when the "Armed" button is pressed, and disarm when the "Disarmed" button is pressed.
          For a four-button configuration, you would just make additional copies of the objects in the states array and tune up the text and values for all according to your implementation.
          And remember, jsonlint.com is your friend. 🙂
          • parkercP Offline
            parkercP Offline
            parkerc
            Thanks @toggledbits
            I’ll explore the `multi_state_button’ option..
            Looking back at the normal button guidance on the wiki (key extracts below ..
            ... The button will appear selected (depressed) or unselected based on the value of a variable, ?permitting sets of buttons to act as radio buttons.
            Display
            …. The specified variable's value controls whether the button appears selected (if the variable matches Value) or not selected (if the variable doesn't match).
            Does that mean I could assign 4 new variables against each device called e.g. “pressed1” , “pressed2 ”, “pressed3" etc. with each one using optional values 1 & 0 or true vs false ?
            ..and then use the Display section in the JSON for that variable to detirmine if the button should be pressed in or not ?
            "Display": {
            		"Variable": "pressed1",
            		"Value": "1 ",
            		"Top": 60,
            		"Left": 150,
            		"Width": 75,
            		"Height": 20
            • parkercP Offline
              parkercP Offline
              parkerc
              Perhaps not the most attractive route, but that ‘Pressed1’ , ‘Pressed2’ etc. variable option worked .. 🎉🤪
              • parkercP parkerc
                Thanks @toggledbits
                Display
                "Display": {
                		"Value": "1 ",
                		"Top": 60,
                		"Left": 150,
                		"Width": 75,
                		"Height": 20
                @parkerc said in Vera StaticJSON Help - Showing a button’s status/selection (in/out) in the UI ?:
                No, you can (probably should) have a single "CurrentInput" that can be 1, 2, 3, or 4.
                parkercP 1 Reply Last reply
                  parkercP Offline
                  parkercP Offline
                  parkerc
                  @toggledbits said in Vera StaticJSON Help - Showing a button’s status/selection (in/out) in the UI ?:
                  Hummm, how would a single variable works on the UI when I need to show the individual status of 4 different input buttons. If it helps I already store a single variable showing what’s selected “input1”, “input2 etc..
                  I’ve got the following on the go at the moment, which leverages that 4 separate status variable approach above , and so far it seems to be working, but I’m always keen to know if there is a better way to do things..
                  Retrieves the input value, and updates all 4 buttons statuses (via their associated Pressed? variable…
                  function updateOutputUI(port, childDev)
                  	log("Start UI Button update for " ..childDev)
                  	luup.variable_set("urn:nodecentral-net:serviceId:SYMatrix1", "Pressed"..port, "1", childDev)
                      tbl = {1, 2, 3, 4}
                      table.remove(tbl, port)
                      for _, num in ipairs(tbl) do
                  		luup.variable_set("urn:nodecentral-net:serviceId:SYMatrix1", "Pressed"..num, "0", childDev)
                          --print("Pressed"..num)
                  Current UI view..
                    There's no requirement that each button have a separate variable, as long as each button's value is different. As I said, you can just have a single CurrentInput variable that contains the number 1, 2, 3, or 4. It looks like you already have that, in fact... Input?
                    Are you assuming that the Value in the Display section is limited to 0 and 1? Because that's not the case. It can be any string.
                      parkercP Offline
                      parkercP Offline
                      parkerc
                      Yes exactly , i had indeed assumed for a button to show it’s status it would have to relate to a variable that was either 1 or 0 or true or false.. 🤪
                      Using just the one variable would certainly clean my code up, especially the chdev.append part i was playing with...
                      luup.chdev.append(lul_device,child_devices, "O" .. v, " Output " .. v, "urn:nodecentral-net:device:SYMatrix:1", "D_SYMatrixOutlet1.xml", "", "urn:nodecentral-net:serviceId:SYMatrix1,Pressed1=1\nurn:nodecentral-net:serviceId:SYMatrix1,Pressed2=0\nurn:nodecentral-net:serviceId:SYMatrix1,Pressed3=0\nurn:nodecentral-net:serviceId:SYMatrix1,Pressed4=0", false)
                      Thanks again @toggledbits - I’ll need to get my head around how to factor in a single variable status..
                        Hmm... I don't think this is hard at all. If my assumption is correct that your existing Input variable will have the value 1, 2, 3, or 4 based on the input chosen, then use that variable in the Display section of each button, same service ID and variable name for every one of them. But for the Value key, use 1, 2, 3, 4 for the buttons, respectively. If your Input works as I think it might, the rest is just that easy. A button is highlighted when the variable's value matches the Value value. Simple, useful, less than magical.
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Yes, i think you’re right, i love how coding this sort of thing make me have to think differently 🙂
                          I’ve also started to add a multi_state_button too, but classic vera UI, I just can’t get it positioned where I want it too go..
                          I really want the on/off toggle button to be in line with the “Output 1” wording, and the right chevron “>”
                          Worse case I revert to a standard button, current .json is pasted below., if anyone can find out how to lift it up a level/row..
                           	"default_icon": "../../../icons/tv_100.png",
                          	"state_icons":[],
                          	"x": "2",
                          	"y": "3",
                          	"inScene": "1",
                          	"ToggleButton": 1,
                          	"Tabs": [
                          			"Label": {
                          				"lang_tag": "tabname_control",
                          				"text": "Control"
                          			"Position": "0",
                          			"TabType": "flash",
                          			"top_navigation_tab": 1,
                          			"ControlGroup": [
                          					"id": "1",
                          					"scenegroup": "1",
                          					"isSingle": "1"
                          					"id": "2",
                          					"scenegroup": "1",
                          					"isSingle": "1"
                          			"SceneGroup": [
                          					"id": "1",
                          					"top": "2",
                          					"left": "0",
                          					"x": "2",
                          					"y": "1"
                          			"Control": [
                          					"top": "0",
                          					"left": "0",
                          					"Label": {
                          						"text": "Input1"
                          					"Display": {
                          						"Variable": "Pressed1",
                          						"Value": "1",
                          						"Top": 60,
                          						"Left": 50,
                          						"Width": 75,
                          						"Height": 20
                          					"Command": {
                          						"Action": "SYCall",
                          						"Parameters": [
                          								"Name": "action",
                          								"Value": "I1"
                          					"top": "0",
                          					"left": "1",
                          					"Label": {
                          						"lang_tag": "Input2",
                          						"text": "Input2"
                          					"Display": {
                          						"Variable": "Pressed2",
                          						"Value": "1",
                          						"Top": 60,
                          						"Left": 150,
                          						"Width": 75,
                          						"Height": 20
                          					"Command": {
                          						"Action": "SYCall",
                          						"Parameters": [
                          								"Name": "action",
                          								"Value": "I2"
                          					"ControlGroup": "2",
                          					"top": "0",
                          					"left": "1",
                          					"Label": {
                          						"lang_tag": "Input3",
                          						"text": "Input3"
                          					"Display": {
                          						"Variable": "Pressed3",
                          						"Value": "1",
                          						"Top": 60,
                          						"Left": 250,
                          						"Width": 75,
                          						"Height": 20
                          					"Command": {
                          						"Action": "SYCall",
                          						"Parameters": [
                          								"Name": "action",
                          								"Value": "I3"
                          					"top": "0",
                          					"left": "1",
                          					"Label": {
                          						"lang_tag": "Input4",
                          						"text": "Input4"
                          					"Display": {
                          						"Variable": "Pressed4",
                          						"Value": "1",
                          						"Top": 60,
                          						"Left": 350,
                          						"Width": 75,
                          						"Height": 20
                          					"Command": {
                          						"Action": "SYCall",
                          						"Parameters": [
                          								"Name": "action",
                          								"Value": "I4"
                          					"top": "0",
                          					"left": "1",
                          					"Display": {
                          					"Top": 0,
                          					"Left": 450
                          					"states":[
                          							"Label": {
                          								"lang_tag": "ui7_cmd_on",
                          								"text": "On"
                          							"Display": {
                          								"Service": "urn:upnp-org:serviceId:SwitchPower1",
                          								"Variable": "Status",
                          								"Value": "1"
                          							"Command": {
                          								"Action": "SetTarget",
                          								"Parameters": [
                          										"Name": "newTargetValue",
                          										"Value": "1"
                          							"ControlCode": "power_on"
                          							"Label": {
                          								"lang_tag": "ui7_cmd_off",
                          								"text": "Off"
                          							"Display": {
                          								"Value": "0"
                          							"Command": {
                          								"Parameters": [
                          										"Value": "0"
                          							"ControlCode": "power_off"
                          			"Label": {
                          				"lang_tag": "settings",
                          				"text": "Settings"
                          			"Position": "1",
                          			"TabType": "javascript",
                          			"ScriptName": "shared.js",
                          			"Function": "simple_device"
                          			"Label": {
                          				"lang_tag": "advanced",
                          				"text": "Advanced"
                          			"Position": "2",
                          			"Function": "advanced_device"
                          			"Label": {
                          				"lang_tag": "notifications",
                          				"text": "Notifications"
                          			"Position": "3",
                          			"Function": "device_notifications"
                          	"sceneList": {
                          		"group_1": {
                          			"cmd_1": {
                          				"label": "ON",
                          				"serviceId": "urn:upnp-org:serviceId:SwitchPower1",
                          				"action": "SetTarget",
                          				"arguments": {
                          					"newTargetValue": "1"
                          				"display": {
                          					"service": "urn:upnp-org:serviceId:SwitchPower1",
                          					"variable": "Status",
                          					"value": "1"
                          			"cmd_2": {
                          				"label": "OFF",
                          				"arguments": {
                          					"newTargetValue": "0"
                          				"display": {
                          					"value": "0"
                          	"eventList2": [
                          			"id": 1,
                          			"label": {
                          				"lang_tag": "ui7_a_device_is_turned_on_off",
                          				"text": "A device is turned on or off"
                          			"argumentList": [
                          					"id": 1,
                          					"dataType": "boolean",
                          					"defaultValue": "1",
                          					"allowedValueList": [
                          							"Off": "0",
                          							"HumanFriendlyText": {
                          								"lang_tag": "ui7_hft_device_turned_off",
                          								"text": "Whenever the _DEVICE_NAME_ is turned off"
                          							"On": "1",
                          								"lang_tag": "ui7_hft_device_turned_on",
                          								"text": "Whenever the _DEVICE_NAME_ is turned on"
                          					"name": "Status",
                          					"comparisson": "=",
                          					"prefix": {
                          						"lang_tag": "ui7_which_mode",
                          						"text": "Which mode"
                          					"suffix": {}
                          	"DeviceType": "urn:nodecentral-net:device:SYMatrix:1",
                          	"device_type": "urn:nodecentral-net:device:SYMatrix:1"
                          I managed to get it looking roughly right on the Control Tab, see below.. but this positioning is not reflected on the main UI (see image above)
