  3. Help please with Node-Red "Lost connection to server"
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
3 Posts 1 Posters 3.3k Views 1 Watching
    Node-Red on my Linux Debian box seems to be having issues now. It keeps saying repeatedly "Lost connection to server, reconnecting..." in the web browser.
    I recently updated nodejs for MSR, I wonder if that might be related:
    "Bump recommended nodejs version to 16.13.0; versions 14 and 15 will continue to be supported through March 31, 2022"
    Nodejs version = v16.13.1
    I have tried updating Node-Red that is now version v2.1.4
    I also updated npm to version v8.2.0
    I am not sure how or where to look at the log file for node red?
    This is the contents of the nodered.service file in this directory:
    /etc/systemd/system/multi-user.target.wants
    # systemd service file to start Node-RED
    [Unit]
    Description=Node-RED graphical event wiring tool
    Wants=network.target
    Documentation=http://nodered.org/docs/hardware/raspberrypi.html
    [Service]
    Type=simple
    # Run as normal pi user - change to the user name you wish to run Node-RED as
    User=stuart
    Group=stuart
    WorkingDirectory=/home/stuart
    Environment="NODE_OPTIONS=--max_old_space_size=1024"
    # uncomment and edit next line if you need an http proxy
    #Environment="HTTP_PROXY=my.httpproxy.server.address"
    # uncomment the next line for a more verbose log output
    #Environment="NODE_RED_OPTIONS=-v"
    # uncomment next line if you need to wait for time sync before starting
    #ExecStartPre=/bin/bash -c '/bin/journalctl -b -u systemd-timesyncd | /bin/grep -q "systemd-timesyncd.* Synchronized to time server"'
    ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS
    #ExecStart=/usr/bin/env node $NODE_OPTIONS red.js $NODE_RED_OPTIONS
    # Use SIGINT to stop
    KillSignal=SIGINT
    # Auto restart on crash
    Restart=on-failure
    RestartSec=20
    # Tag things in the log
    SyslogIdentifier=Node-RED
    #StandardOutput=syslog
    [Install]
    WantedBy=multi-user.target
      sudo journalctl -f -u nodered -o cat
      #4 Dec 15:52:58 - [error] [tuya-smart-device:Star Light] Error: Error from socket: connect EHOSTUNREACH 192.168.0.119:6668
      4 Dec 15:52:58 - [red] Uncaught Exception:
      4 Dec 15:52:58 - [error] Error: connect EHOSTUNREACH 192.168.0.119:6668
          at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1161:16)
      nodered.service: Main process exited, code=exited, status=1/FAILURE
      nodered.service: Failed with result 'exit-code'.
      nodered.service: Service RestartSec=20s expired, scheduling restart.
      nodered.service: Scheduled restart job, restart counter is at 37.
      Stopped Node-RED graphical event wiring tool.
      Started Node-RED graphical event wiring tool.
      4 Dec 15:53:20 - [info]
      Welcome to Node-RED
      4 Dec 15:53:20 - [info] Node-RED version: v2.1.4
      4 Dec 15:53:20 - [info] Node.js  version: v16.13.1
      4 Dec 15:53:20 - [info] Linux 4.19.0-18-amd64 x64 LE
      4 Dec 15:53:21 - [info] Loading palette nodes
      4 Dec 15:53:28 - [info] Settings file  : /home/stuart/.node-red/settings.js
      4 Dec 15:53:28 - [info] Context store  : 'default' [module=memory]
      4 Dec 15:53:28 - [info] User directory : /home/stuart/.node-red
      4 Dec 15:53:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
      4 Dec 15:53:28 - [warn] Flows file name not set. Generating name using hostname.
      4 Dec 15:53:28 - [info] Flows file     : /home/stuart/.node-red/flows_HP-Thin01.json
      4 Dec 15:53:28 - [info] Server now running at http://127.0.0.1:1880/
      Your flow credentials file is encrypted using a system-generated key.
      If the system-generated key is lost for any reason, your credentials
      file will not be recoverable, you will have to delete it and re-enter
      your credentials.
      You should set your own key using the 'credentialSecret' option in
      your settings file. Node-RED will then re-encrypt your credentials
      file using your chosen key the next time you deploy a change.
      4 Dec 15:53:28 - [info] Starting flows
      4 Dec 15:53:29 - [info] [tuya-smart-device:Star Light] Recieved the config {"id":"b2799abf.81c1a8","type":"tuya-smart-device","z":"7bd8e249.bbb27c","deviceName":"Star Light","deviceId":"bf62864a9977909c10zuey","deviceKey":"7904f95d6d266841","deviceIp":"192.168.0.119","retryTimeout":"1000","findTimeout":"1000","tuyaVersion":"3.1","eventMode":"event-both","x":880,"y":180,"wires":[["f6422200.35ec7"]]}
      4 Dec 15:53:29 - [info] [tuya-smart-device:Star Light] Event subscription : shouldSubscribeData=>true , shouldSubscribeRefreshData=>true
      4 Dec 15:53:29 - [info] [tuya-smart-device:Star Light] Connecting to Tuya with params {"id":"bf62864a9977909c10zuey","key":"7904f95d6d266841","ip":"192.168.0.119","issueGetOnConnect":false,"nullPayloadOnJSONError":false,"version":"3.1"} , findTimeout :  1000 , retryTimeout:  1000
      4 Dec 15:53:29 - [info] [tuya-smart-device:Star Light] Recieved the config {"id":"d9079dc4.b93c3","type":"tuya-smart-device","z":"7bd8e249.bbb27c","deviceName":"Star Light","deviceId":"bf62864a9977909c10zuey","deviceKey":"7904f95d6d266841","deviceIp":"192.168.0.119","retryTimeout":"1000","findTimeout":"1000","tuyaVersion":"3.1","eventMode":"event-both","x":320,"y":420,"wires":[["2b35a684.a57a9a","8ed8ece1.387ca"]]}
      4 Dec 15:53:29 - [info] Started flows
      4 Dec 15:53:30 - [info] [tuya-smart-device:Star Light] initiating the find command
      4 Dec 15:53:33 - [error] [tuya-smart-device:Star Light] Error: Error from socket: connect EHOSTUNREACH 192.168.0.119:6668
      4 Dec 15:53:33 - [red] Uncaught Exception:
      4 Dec 15:53:33 - [error] Error: connect EHOSTUNREACH 192.168.0.119:6668
      192.168.0.119 is a Tuya WIFI lamp that I had powered off.
      I can't seem to update any of these nodes, it doesn't seem to do anything when I try.
        I've now powered that Tuya light back ON again so it is reachable on the WLAN and now I am able to update the nodes OK and then I rebooted the Linux box. Now the "Lost connection to server, reconnecting..." message has stopped appearing. So seems related to this Tuya node / light.
        I then powered OFF the Tuya light again and fingers crossed the "Lost connection to server, reconnecting..." message still hasn't come back, so I think managing to update the Tuya node may have fixed it. I will keep an eye on it.
          157.7k
