  3. Vera Secure usage without mios
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
  • D Offline
    D Offline
    destination
    Hi to all, I have a bricked vera secure that is replaced with new one. Old vera secure serial numbers are deleted from vera servers so I cannot use it. Vera secure's are orginally Sercomm's NA502 model devices. Recently I install openwrt to the old vera secure unit without problem. Is there any way to use it any automation system with internal z-wave. I install domoticz but I cannot setup internal z-wave unit, it only accept usb zwave radios. Is there any ideas?
      you could evaluate ser2net and forward the zwave chip somewhere else:
      Oct 25, 2017
      Using a Vera Edge as a network-attached zwave device (skipping the vera software)
      I have a few Vera’s lying around and I wanted to migrate one to home assistant, and instead of going the tedious way of adding again all my zwave devices to a zwave stick, I decided to try and make a zwave-to-tcp device out of the controller, and connect home assistant to it. Data path: zwave...
      • D Offline
        D Offline
        destination
        Thank you.
        • D destination
          @destination A bit late now, but you haven't heard about decoupling? No need for Vera/Ezlo servers...
          D 1 Reply Last reply
            D Offline
            D Offline
            destination
            @tunnus said in Vera Secure usage without mios:
            I haven't heard about decoupling, Thank you, i will search about it.
