  3. 3D Printers - What to get in your opinion?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
8 Posts 5 Posters 2.3k Views 5 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    A digression from the joy's of building automation.
    I have some modifications to make to some (many) plastic frames and thought that an insert sleeve would be the best way to proceed.
    I'm making an educated guess and assume that some if not many readers will have access to a 3D Printer and can advise me of the pitfalls.
    Ideally, a commercial product would have been the way to go but there is none available so it looks like it's 3D Print or abandon the project.
    It's a simple requirement to print a insert sleeve that can hold a device in a frame. Basically, the sleeve is a 44.5mm * 48.9mm*20.0mm box wall thickness 0.5mm with 4 * 13.5 * 16.0mm location pads.
    A couple of questions:
    • What printers do you use? What would be considered a good one remembering we have all been bitten by Vera at least once and I don't want to go through a similar process.
    • Is it possible to over print on an existing plastic object?
    • How fine can the print be, for instance I need to pad the sleeve out 5mm at most but require a 0.5mm wall thickness for the box to position the location pads. Can 0.5mm be achieved?
    *Software? what's good and what to avoid?
    TIA
    Mike
    aka Zedrally
      Looks like no love for the 3D printers huh? I know a lot of people around me in the US who got into it but... I didn't.
      Most of them got relatively cheap entry level ones and I don't think you can print over an existing object. The whole purpose is to design the piece in CAD and then get a printed object matching it.
      Price pretty much dictates the resolution. I think it is part of the specs. At work, some more expensive ones can get way below 0.5mm.
        Black CatB Offline
        Black Cat
        I'm surprised there is no love either, guess the time that Vera takes to maintain doesn't allow for other activities.........:)
        aka Zedrally
          Elsewhere, I’m on an astronomy forum, which is absolutely stuffed with 3D printer aficionados. I take it that this arises from the need to make bespoke mechanical parts, which are otherwise astronomically expensive.
          Not so much of a need, perhaps, in the HA world?
            There seems to be plenty of love in the other place.
              Matteburk
              I have a Prusa MK3s . I can recimmend it because it just works everytime!
              Its very easy to use and has its oen slicer Prusaslicer.
              I use Fusion 360 to drar stuff, it has direct connection tonprusaslicer so no fileconvert needed.
              / Mattias
                Hmm you guys actually made me consider it since I have a quite a bit more spare time now that I ditched the vera.
                This is a helpful article comparing resin vs filament:
                Oct 8, 2021  /  Accessories
                Resin or filament 3D printing: Which is best for you?
                What do all those acronyms mean?
                You basically need to decide what type of printing you want between large and small pieces and the level of details/accuracy needed.
                I happened to be considering these two models or at least these two brands.
                  Seriously considering the SUNLU S8 one at the moment as a low cost entry unit...
                  https://www.sunlu.com/products/sunlu-s8-3d-diy-printer-310x310x400mm-printing-size-works-with-different-filament-2year-warranty
                    154.3k
