  3. Vera/openLuup plugins
  4. Amcrest/Dahua Camera Plugin streaming and PTZ for openLuup/ALTUI
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
40 Posts 3 Posters 12.1k Views 3 Watching
    Nope port should not be needed. What version of ALTUI and openLuup are you running?
    I am fairly certain now that the plugin I published works since it is working for me. Have to look at other things...
      RHCPNG
      AltUI v2.50.2549. Openluup v20.5.22. It's annoying that the logging does not give anything useful.
        Could you provide a screenshot of your attribute screen as well as a list of all your variables? I really have no idea why it isn't working for you. I even just added a camera to my openLuup setup and had no problem so something else is different. Are you seeing the camera control screen? Can you send commands to the camera like pan and tilt? What browser are you using? Can you try a different browser?
          RHCPNG
          #24
          Ok, youre right, the plugin seems to work. I have tested with an other Amcrest model and that one does work. So the problem lies in the older models I have, that's a pity. I will have to do it through zoneminder then.
          The PTZ does not seem to work however for my model.
          I'm getting this error:
          Unknown control type:js_button. See Debug
            I'd be happy to improve the plugin to support more cameras if I can.
            If the url is correct and the video is not working it is likely because the codec is not supported by the browser. If you tell me what camera it is, I will take a look.
            The error you are seeing about the button is not normal. I will take a look as well. This command is in javascript and is done by ALTUI. I don't believe it is in the plugin code but will check.
              RHCPNG
              #26
              I don't get it. When I put the full URL directly in the browser window, like this, I get a stream (outside AltUI).
              http://admin:<password>@192.168.1.17/cgi-bin/mjpg/video.cgi?channel=1&subtype=1
              So that would mean it isn't the codec, right?
              The model is: Amcrest IP3M-943B
                #27
                Not sure why they would not work. It uses the same H264 and mjpg codec but your url uses mjpg. I have a bunch of IP3M-956/954 and they all work fine too.
                Good catch on the js_button. I never noticed it but it seems to be inherited from deprecated code. I will fix that. Only some buttons were affected.
                I took advantage to fix a few thing around pan tilt/scanning. Released version 0.4.
                This plugin was very raw when I took it over... I am finding so many things which were not quite right.
                  RHCPNG
                  There are some annoying issues with my model. I can't even manage my camera's through Chrome or Firefox, only through IE.
                  Will try your new version soon.
                    RHCPNG
                    #29
                    I have tested the new version with my working model, but the buttons still do nothing. The error is gone and I don't see anything strange in the log.
                    2020-11-26 08:56:33.263   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=377375215&Timeout=60&MinimumDelay=1500&_=1606377363201 HTTP/1.1 tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:33.642   luup.variable_set:: 10665.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 19.60 now: 19.50 #hooks:0
                    2020-11-26 08:56:33.946   openLuup.server:: request completed (20648 bytes, 2 chunks, 682 ms) tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:34.059   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=377375217&Timeout=60&MinimumDelay=1500&_=1606377363202 HTTP/1.1 tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:34.991   luup.variable_set:: 10664.urn:micasaverde-com:serviceId:HaDevice1.BatteryDate was: 1606377364 now: 1606377394 #hooks:0
                    2020-11-26 08:56:35.195   openLuup.server:: request completed (28287 bytes, 2 chunks, 1135 ms) tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:35.307   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=377375219&Timeout=60&MinimumDelay=1500&_=1606377363203 HTTP/1.1 tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:37.593   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=297&serviceId=urn:micasaverde-com:serviceId:PanTiltZoom1&action=MoveLeft HTTP/1.1 tcp{client}: 0x55f5f5fd7d88
                    2020-11-26 08:56:37.593   luup.call_action:: 297.urn:micasaverde-com:serviceId:PanTiltZoom1.MoveLeft
                    2020-11-26 08:56:37.593   openLuup.server:: request completed (60 bytes, 1 chunks, 0 ms) tcp{client}: 0x55f5f5fd7d88
                    2020-11-26 08:56:37.630   openLuup.client:: WGET error status: -1, request: http://admin:DWvBqx6yT7SkMogw@192.168.1.18/cgi-bin/ptz.cgi?action=start&channel=0&code=Left&arg1=0&arg2=1&arg3=0
                    2020-11-26 08:56:37.934   openLuup.server:: request completed (19020 bytes, 2 chunks, 2626 ms) tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:38.091   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=377375220&Timeout=60&MinimumDelay=1500&_=1606377363204 HTTP/1.1 tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:38.733   openLuup.client:: WGET error status: -1, request: http://admin:DWvBqx6yT7SkMogw@192.168.1.18/cgi-bin/ptz.cgi?action=stop&channel=0&code=Up&arg1=0&arg2=0&arg3=0
                    2020-11-26 08:56:39.741   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=297&serviceId=urn:micasaverde-com:serviceId:PanTiltZoom1&action=MoveRight HTTP/1.1 tcp{client}: 0x55f5f5fd7d88
                    2020-11-26 08:56:39.741   luup.call_action:: 297.urn:micasaverde-com:serviceId:PanTiltZoom1.MoveRight
                    2020-11-26 08:56:39.742   openLuup.server:: request completed (61 bytes, 1 chunks, 1 ms) tcp{client}: 0x55f5f5fd7d88
                    2020-11-26 08:56:39.775   openLuup.client:: WGET error status: -1, request: http://admin:DWvBqx6yT7SkMogw@192.168.1.18/cgi-bin/ptz.cgi?action=start&channel=0&code=Right&arg1=0&arg2=1&arg3=0
                    2020-11-26 08:56:40.280   openLuup.server:: request completed (19020 bytes, 2 chunks, 2188 ms) tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:40.424   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=377375221&Timeout=60&MinimumDelay=1500&_=1606377363205 HTTP/1.1 tcp{client}: 0x55f5f5b61a78
                    2020-11-26 08:56:40.857   openLuup.client:: WGET error status: -1, request: http://admin:DWvBqx6yT7SkMogw@192.168.1.18/cgi-bin/ptz.cgi?action=stop&channel=0&code=Up&arg1=0&arg2=0&arg3=0
                    2020-11-26 08:56:41.476   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=297&serviceId=urn:micasaverde-com:serviceId:PanTiltZoom1&action=MoveUp HTTP/1.1 tcp{client}: 0x55f5f5fd7d88
                    2020-11-26 08:56:41.476   luup.call_action:: 297.urn:micasaverde-com:serviceId:PanTiltZoom1.MoveUp
                    2020-11-26 08:56:41.477   openLuup.server:: request completed (58 bytes, 1 chunks, 0 ms) tcp{client}: 0x55f5f5fd7d88
                    2020-11-26 08:56:41.497   openLuup.client:: WGET error status: -1, request: http://admin:DWvBqx6yT7SkMogw@192.168.1.18/cgi-bin/ptz.cgi?action=start&channel=0&code=Up&arg1=0&arg2=1&arg3=0
                    2020-11-26 08:56:41.600   openLuup.server:: request completed (19020 bytes, 2 chunks, 1176 ms) tcp{client}: 0x55f5f5b61a78
                    The working model is the Amcrest IP4M-1051
                      I am not getting any of the WGET errors in my logs. I am not sure what this status -1 means besides the fact that the camera is rejecting the call. I am also a bit surprised that your credentials in the url are only partially encoded. (the username is doesn't appear to be). Something doesn't seem right.
                      Honestly I have not gotten to the bottom of the stream. One of my cameras which I just added has all the pan and tilt buttons work so it is communicated properly but the video does not show. I tested on firefox and none of the cameras show any images.
                      Will try to dig deeper into this as I think it is more java code from ALTUI than it is a plugin/openLuup problem.
                        Alright so I made some progress with this. Sorry I am not very good in JS so it took me a while to understand how ALTUI handles this.
                        I have updated the plugin which should enable getting images from the camera if your browser has the ability to disable cross origin restrictions (i.e Safari "develop" menu). I have tested this on firefox as well but unlike safari, firefox somehow sends an URL without the credentials... which means that you won't be able to see your camera feed. I submitted a pull request to @amg0 to implement credentials in ALTUI.
                          RHCPNG
                          Nice job figuring this out. Would this mean the feed of my older models would possibly work too? I'm getting a login screen sometimes when using the complete URL (with username and password) directly in my browser. That shouldn't happen, I would think.
                            Yes the older models would work too and yes you do need to get you browser to log in.
                            The reason is this:
                            All the plugin commands go from openLuup to the cameras. This should work without any problems.
                            The video stream however is a call from your client web-browser to the camera. This requires a separate login on top of the credentials which have already been established between openLuup and the cameras. The behavior obviously then varies a lot from browser to browser. For example Safari remembers the credentials so you only need to log in once and the call from ALTUI done by safari automatically adds the credentials. I discovered that firefox doesn't do that and requires the credentials to be added back in the url.
                              RHCPNG
                              O ok, thanks for the explanation. That's nasty. I use Chrome and that works similar as Firefox then. But what is the difference with the newer models then?
                                This was the very core of the design of ALTUI. The vera was very underpowered already so ALTUI moved the UI processing to the client browser using javascript instead of relying on the webserver on the vera (lightttpd). As the vera is properly incapable of processing high resolution camera streams, ALTUI moved that processing to the browser (and rightfully so) and therefore all the authentication must be done by the client browser.
                                By the way @amg0 has taken in my pull request so you can expect the next version of ALTUI to support this. I personally didn't notice any problem because I was using Safari.
                                  RHCPNG
                                  Hi @rafale77 ,
                                  Am I correct that in the latest release of AltUI your addition was rolled out? Should it be working now?
                                    Yes, they should all work. It has for me. Check it out and see if you need any more help.
                                      RHCPNG
                                      It's still not working for me. I don't get any image, also not from the newer model. And I don't get anything significant in the log files.
                                        Sorry to hear. this is rather puzzling honestly as I have had no issues with mine. Getting the image is a simple API call to the camera. The only challenge was authentication of the credentials which required MD5/digest encoding and this has been fixed in openLuup.
                                        The rest is about ALTUI working with your browser to display to image. Not sure where it is breaking for you. I have old and newer models and the aecrest API has not changed so it should make no difference.
                                          RHCPNG
                                          Bummer. I will dig into it some more later. No priority at the moment.
                                            140.2k
