  3. Vera/openLuup plugins
  4. Amcrest/Dahua Camera Plugin streaming and PTZ for openLuup/ALTUI
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
40 Posts 3 Posters 13.2k Views 3 Watching
    GitHub - rafale77/Amcrest-Dahua-Openluup: Plugin for Amcrest/Dahua Cameras on openLuup
    Plugin for Amcrest/Dahua Cameras on openLuup. Contribute to rafale77/Amcrest-Dahua-Openluup development by creating an account on GitHub.
      RHCPNG
      Hi @rafale77,
      This is great! I have some Amcrest camera’s. Why isn’t this in the AltUI store? Any pointers on how to set this up?
        Good question. I never thought about putting it up there because nobody asked. I certainly could post it there.
        The setup is very straightforward. Just put in the IP of the camera (it's a device attribute) and the credentials (these are variables) and it should work after a luup reload:
        I am using it to control preset positions PTZ so it changes position depending on time of the day.
          RHCPNG
          Great! I should put the files on openluup and then create a device, right?
            Correct! Just the same way as the vera.
            R 1 Reply Last reply
              RHCPNG
              @rafale77 How do I install the plugin? I have created the device, but I don't have any variable "DirectStreamingURL" and where do I put in the username and password?
                Bear with me a couple of days... I think I have learned enough lua now to be able to do a much better job and will rewrite it is such a way that will be easier to install.
                  RHCPNG
                  Ok, that's cool. No hurry!
                    Ohh my gosh, shame on me... It turns out the version posted on github is not even the latest version I am running. I will be reposting in a few minutes.
                    Edit: And now it should be much better. I also published the plugin on the AltAppStore.
                      RHCPNG
                      @rafale77 Thanks for that! I have installed the plugin from the AltAppStore, but I'm getting the same result. No URL variable.
                      And also the files on github seem to be the same (looking at the date).
                        You should only need to update 2 files (the I_ and the L_ files) which are 3 days old on GitHub? The url and username/password variables should all be autocreated upon luup reload.
                          RHCPNG
                          I can't get it to work, the variables don't show up. I have even removed all files from openluup and started over, but same result every time. Any ideas?
                            Ok, I think I have now a pretty good idea of what happened. It would be helpful if you could look at your logs to find out what the error is though.
                            The issue seems to be that my installation of openLuup is not quite "vanilla" as I have made a few minor modifications to it and am also running it on LuaJIT along with some additional libraries instead of the standard Lua5.1 interpreter. I will make a minor edit to try to fix it.
                            Please try it and report back with what error you see in the logs if any.
                            You can look into the openLuup section of the forum to see what changes I made to my openLuup installation. I basically decreased the CPU load by >75%
                            https://smarthome.community/topic/151/rapidjson-instead-of-cjson-and-dkjson
                            https://smarthome.community/topic/179/luajit
                            Only change is to the L_Amcrest.lua file so you can just replace that file in your installation and reload.
                            akbooerA R 2 Replies Last reply
                              @rafale77 said in Amcrest/Dahua Camera Plugin streaming and PTZ for openLuup/ALTUI:
                              ...although, it has to be said, from a pretty small starting level anyway?
                                @akbooer
                                Yes, indeed:
                                My setup with all the plugins and bridges was hovering around 6-8% CPU load with spikes to 14-18% when I opened an ALTUI page.
                                Now I hover between 1.5-2.5% with spikes to 4-4.5% with ALTUI opened.
                                  RHCPNG
                                  @rafale77 Thanks, I will test it tomorrow.
                                    Released version 0.3 in the App store.
                                    I realized much simplification was possible with the newer versions of openLuup and that digest actually works with luajit.
                                      RHCPNG
                                      Ok, we are a step further. All variables are there now. Firstly, there is a small error in the DirectStreamingURL though. The brackets should not be there.
                                      I have removed them, but still no image.
                                      This is the only thing I get in the log:
                                      2020-11-22 09:56:05.011   luup.variable_set:: 93.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                                      2020-11-22 09:56:05.011   openLuup.scheduler:: [93] Lobo device startup completed: status=true, msg=Ready, name=Lobo
                                      2020-11-22 09:56:05.011   openLuup.scheduler:: [297] Amcrest Dahua device startup
                                      2020-11-22 09:56:05.011   luup.set_failure:: status = false
                                      2020-11-22 09:56:05.011   luup.variable_set:: 297.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: false now: false #hooks:0
                                      2020-11-22 09:56:05.011   luup.variable_set:: 297.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1606035145 now: 1606035365 #hooks:0
                                      2020-11-22 09:56:05.011   luup.variable_set:: 297.urn:micasaverde-com:serviceId:HaDevice1.Commands was: camera_full_screen,camera_left,camera_right,camera_up,camera_down,camera_preset,camera_zoom_in,camera_zoom_out now: camera_full_screen,camera_left,camera_right,camera_up,camera_down,camera_preset,camera_zoom_in,camera_zoom_out #hooks:0
                                      2020-11-22 09:56:05.011   openLuup.scheduler:: [297] Amcrest Dahua device startup completed: status=, msg=, name=
                                      2020-11-22 09:56:05.012   luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.14,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.14,[{
                                        "default":"device.serviceId.name",
                                        "key":"mirror",
                                        "label":"Mirror",
                                        "type":"text"
                                      2020-11-22 09:56:05.012   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.14":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.14","callback... #hooks:0
                                      2020-11-22 09:56:05.012   luup_log:3: ALTUI: UPNPregisterPlugin(3,urn:schemas-toggledbits-com:device:SiteSensor:1,J_SiteSensor1_ALTUI.js,SiteSensor_ALTUI.DeviceDraw,,,,SiteSensor_ALTUI.Favorite)
                                      2020-11-22 09:56:05.016   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.PluginConfig was: {"urn:schemas-micasaverde-com:device:PowerMeter:1":{"DeviceDrawFunc":"ALTUI_PluginDisplays.drawPowerMeter","ScriptF... now: {"urn:schemas-micasaverde-com:device:PowerMeter:1":{"ScriptFile":"J_ALTUI_plugins.js","DeviceDrawFunc":"ALTUI_Plugi... #hooks:0
                                      2020-11-22 09:56:05.017   luup_log:3: ALTUI: UPNPregisterPlugin(3,u
                                      BTW I have tried the complete URL in the browser and that works.
                                        Good news is that the plugin code is executing.
                                        Stating the obvious but, did you check that the ip address and the credentials are setup?
                                        It is working fine here (with the brackets). The display of the stream/snapshot is actually done by ALTUI. depending on the browser you use, it may buffer a bit strangely.
                                          RHCPNG
                                          I've put the ip-address in the attributes and the username and password in the variables yes. Maybe add the port? It doesn't need it when I put the URL directly in the browser, so probably not.
                                            152.5k
