  3. Smart door lock
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
Smart door lock
7 Posts 6 Posters 2.0k Views 4 Watching
  • D Offline
    D Offline
    dezzy
    Hi! I want to install a smart lock on my front door, but I don't know which one to choose. There are many different models available on the market. Do you have a reliable model to recommend?
      Availability varies by country and your intended controller. Can you give us a little more detail about your environment?
      • D Offline
        D Offline
        dezzy
        Thank you for your answer! I currently live in Poland. What I expect from a smart lock is that I can control it remotely, using an iOS app. I don't want to replace the entire door, so it would be best if it could be installed on the existing lock.
        • Black CatB Offline
          Black CatB Offline
          Black Cat
          It might be easier to consider replacing the Door Strike with a electric one controlled by a suitable relay. This way you don't need to interfere with the existing door and door lock.
          aka Zedrally
          • C Offline
            C Offline
            christian_fabre
            I live in France.
            Personally, I have had a "The Keys" connected lock for 2 or 3 years with a WiFi Bridge, which I will surely change soon.
            It has an API, a smartphone application.
            I am interested in this lock currently:
            NUKI SMART LOCK 3.0 PRO (BLACK), BLUETOOTH/WI-FI CONNECTED LOCK
            • H Offline
              H Offline
              helloworld
              I live in Poland and use tedee (also a Polish company). It's pretty and I haven't had any problems with it yet. It can be mounted on an adapter and you don't have to replace the lock: https://tedee.com/product/adapter/
              • P Offline
                P Offline
                prplrhd
                I'm still using quite a few Schlage BE469 units in several homes. There is a very specific process to follow during set up and you need to be sure you have the right secure Zwave devices or direct path to your controller. But once set up they work flawlessly and have been very reliable on Vera.
                  146.0k
