  4. Variables for fun and profit
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
19 Posts 3 Posters 4.3k Views 3 Watching
    @crille Really appreciated
    No I don't need to set the heating time, there's a rule that compares current time to the calculated time for heating on. Given that
    time(0) returns epoch, that seemed a sensible way of doing it
    Unfortunately truncating the epoch in ms simply knocks the milliseconds off so instead of getting Saturday, 1 January 2022 00:00:00.000 you get Saturday, 1 January 2022 00:00:00
    It should be
    Thursday, 21 July 2022 03:15:00
    or
    Thursday, 21 July 2022 03:15:00.000
    Even using strftime returns Jan 1
    Very very odd. Really appreciate your continued efforts though!
    I'm a little lost and don't know what you actually want to achieve and what arguments you are giving time().
    We might get different results as time() operates in the timezone set for the runtime.
    I'll leave you with my tests and take a fresh look in the morning as it's getting late here. (sorry for Swedish in the screenshot as strftime() is locale-aware.)
      Ahh this appears to work, thanks so much!
      I need to do some more testing, specifically around the testing of AlarmTimeSub1 vs current time but I very much appreciate your patience guiding this muppet!
      <edit> So yes AlarmTimeSub1 evaluates perfectly. Now I need to compare that to actual time (if the actual time is later than AlarmTimeSub1, then I want the evaluation to be 'true')
      time() >= AlarmSubTime1
      Returns false.
        OK fixed it. Thanks, too early to be trying this stuff 🙂
        strftime("%T", time()) >= AlarmSubTime1
        Evaluates as true so that's great 🙂
          FYI, @Crille has provided a correct example for computing an offset time to get an epoch (numeric) time to use for comparisons. The string comparison performed by strftime("%T", time()) >= AlarmSubTime1 is really poor programming style and should not be used; numeric comparisons are better here. Unfortunately, the responses don't give adequate detail as to what "wrong" answer is produced by @Crille 's solution, so I can't comment other than the critique.
            Thanks. I have no programming style so happy to be educated 🙂
            <types long reply to explain the 'issue'>
            <while typing resolves the issue>
            <deletes explanation>
            is time() >= HeatTime better style?
            <edit>
            I guess I'm still curious as to why
            time([AlarmTime]) in MSR and time(AlarmTime) in reactor return a different stamp (apart from the ms vs s part that is)
            Thanks again for all you do
              <edit>
              @catmanv2 said in Variables for fun and profit:
              Yes.
              You haven't given any examples of this. I don't believe it to be true (except, as noted, for millisecond precision in Multi-Hub Reactor). My guess is you are not actually asking about the return values, but about why the functions take different arguments. The reason is that the expression language in Multi-Hub Reactor is entirely new, and while there is some overlap between them, I would argue that the newer form is vastly superior and corrects many errors (read: decisions I made that I later regretted) in the Lua-based form. Another reason is that Multi-Hub Reactor is not Lua-based, so I did not feel the need to be Lua-compatible, whereas Reactor for Vera, being a Lua plugin for a Lua system, is meant to capitalize on existing user experience with Lua on that now-defunct (Vera) platform.
              Also, if AlarmTime contains the string 12:34:56, the using time([AlarmTime]) in either Multi-Hub or Vera Reactor would be passing incorrect arguments to the function. If you want to pass a string, you do so without [] surrounding. If you include the [], you are creating an array containing a string, which is nonsensical (to the function -- it sees an error). The documentation (for Multi-Hub) states that the function takes an optional single string argument, or up to six optional numeric arguments (representing in order given (year, month, day, hour, minute, second), or an optional dateparts-form object. The [] you see in the documentation is from an old-but-still-widely-used BNF form to indicate an optional argument, it is not meant to be literally included in your expression. So the following would be valid calls to time:
              1. time() with no arguments (because all arguments are optional)
              2. time( "2022-07-22T08:53:23+02:00" ) -- an ISO 8601 date string with TZ
              3. time( 2022, 7, 22 ) -- produces midnight on 2022-Jul-22 in the host time zone (three optional arguments not given -- hour, minute, second)
              4. time( 2022, 7, 22, 8, 10, 0 ) -- produces 8:10am on 22-Jul-2022 in the host time zone
              5. and the dateparts() form has already been given in examples above by @Crille
              Note that the string passed must be in ISO 8601 form, so a simple "12:34:56" time alone would not be parsable and produce an invalid result.
                Yes.
                @toggledbits OK I'll try to give an example (I'm sure / hopeful you can explain)
                In my Reactor (and I'm pretty sure you set this up for me a couple of years back!) I have:
                getstate( 46, "urn:upnp-org:serviceId:VClock1", "AlarmTime" )
                Underneath is stated: Last result: "06:00:00"
                Then we have
                time(AlarmTime) - 3600
                Underneath: Last result: 1658462400
                In MSR we have:
                getEntity( "vera>Alarm Clock" ).attributes.x_vera_svc_upnp_org_VClock1.AlarmTime
                Underneath: Last value: (string) "06:00:00"
                If we then do
                time(AlarmTime) - 3600000 the result printed is
                Last value: (null) null
                time([AlarmTime]) - 3600000
                Returns: Last value: (number) 1640995200000
                Please note I changed the HeatTime in reactor to HeatTimeMSR in MSR just to demonstrate the 'difference' in output.
                Clearly I'm missing something fundamental and obvious!
                Cheers
                  Then we have
                  In MSR we have:
                  If we then do
                  Cheers
                  If we then do
                  This is expected because AlarmTime contains only 06:00:00, which is not an ISO 8601-compatible string.
                  Also expected, as I said above, because the [] surrounding AlarmTime convert it to an array, which is a form of object, so time() is thinking its a dateparts()-compatible object and using what's available from it (which in fact is nothing at all, i.e. the "it's nonsensical" reference in that comment) to compute the time.
                    So fundamentally Reactor's time and MSR's time are just different and behave differently?
                    <edit>
                    Or getstate and getEntity are returning something different from each other, I guess.
                    Thanks for the clarity there, and the patience 🙂
                      Many of the functions behave differently, and this is intentional. The functions of Multi-Hub Reactor are (in my view) an improved evolution of any same-named functions in Reactor for Vera. Reading the documentation is key to success.
                      I'm working right now (back at my desk, yay!) at expanding the parsing capabilities of time() to make your particular use case a bit easier.
                        @toggledbits that's super. Thanks again for all your help!
                          164.1k
