  3. Z-Wave.me forum.
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
Z-Wave.me forum.
7 Posts 3 Posters 2.4k Views 3 Watching
  • J Offline
    J Offline
    JMK
    Is there anyone out there that has contact with the admin(s) at the Z-wave.me forum? I registered about three weeks or so ago and did not get a authorization email and I have tried contacting the admin several times with no response. I have a question about my RaZberry I need to post.
    Regards.
      actually @PoltoS is also on this forum. I can also ping him to see what he says. You could also post your question here.
        sender
        I mailed Sergei. Had the same issue!
        • J Offline
          J Offline
          JMK
          Now July 30, still cannot get on the Z-wave.me forum. I have a problem with signatures during "sudo apt update". Is Z-wave.me a one-man-band?
            sender
            Think it's a russian company and they have increased border control 🙂
            • J Offline
              J Offline
              JMK
              Does anyone here know how to fix the following output from "sudo apt update" on a Raspberry Pi running Buster...
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.z-wave.me/z-way/raspbian buster InRelease: The following signatures were invalid: EXPKEYSIG E5958C31C0AFD761 Z-Wave.Me info@z-wave.me
              W: Failed to fetch https://repo.z-wave.me/z-way/raspbian/dists/buster/InRelease The following signatures were invalid: EXPKEYSIG E5958C31C0AFD761 Z-Wave.Me info@z-wave.me
              W: Some index files failed to download. They have been ignored, or old ones used instead.
                Just remove the repo from your apt list.
                How to apt-delete-repository?
                I would like to run the reverse of this command to remove the non-compatible repository in Debian 8.1 sudo add-apt-repository -y ppa:nemh/systemback where the command add-apt-repository is in the
                I recommend not using apt to install z-way anyway. It is never quite up to date.
                  165.5k
