  4. [SOLVED] Hubitat / log data from new hub information device after deleting original?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
4 Posts 2 Posters 756 Views 2 Watching
    Alan_F
    MSR latest-22310, Raspberry Pi 4 / Docker
    While troubleshooting another issue, I deleted and recreated the hub information device on one of my Hubitat hubs. Reactor had been logging the old device information to InfluxDB, but it doesn't appear to have detected the new device. I made sure to enable the new device in Maker API, I've restarted reactor and done a 'docker-compose down' / 'docker-compose up - d'. Still no new data going to influxdb.
    My recollection is that the Hubitat hub device is baken into MSR and is auto-detected, and that it isn't manually configured anywhere. I checked the docs and searched the forum without success.
    Any advice on how I can get MSR to start logging the info from the new device?
      It's auto-detected for HubitatController's use, but not for InfluxDB export. You probably need to change the canonical ID of the device to the new ID it has been assigned in your configuration for InfluxPlugin.
        Alan_F
        @toggledbits Is that in the reactor.yaml file? I don't have the old one configured there. It just automatically worked. Influx section of my reactor.yaml is below with most of the commented lines removed.
        plugins:
          - id: influx
            # See the docs under Standard Plugins for configuration details.
            implementation: InfluxFeed
            enabled: true
              # influx_url - URL to access InfluxDB server (default: http://localhost:8086)
              influx_url: http://192.168.0.X:8085
              # influx_org - Organization ID (required)
              influx_org: "org1"
              # influx_bucket - Bucket name to which points are written (required)
              influx_bucket: "msrdata"
              # ----- For InfluxDB 1.8+ ONLY -----
              # influx_database - Database name for data storage (required)
              influx_database: "reactor"
              # influx_username - Username for database access (required)
              influx_username: "reactor"
              # influx_password - Password for database access (required)
              influx_password: "mypassword"
              select_capabilities:
                light_sensor: true
                temperature_sensor:
                    value:
                      type:number
                    units:
                      type: string
                x_hubitat_extra_attributes:
                    cpu5Min:
                      type: number
                    cpuPct:
                      type: number
                    freeMemory:
                      type: number
                    dbSize:
                      type: number
                wx:
                    - temperature
                    - humidity
                    - cloud_cover
        So I think it should be picking it up from the 'x_hubitat_extra_attributes'. The new hub information device also has those attributes when I examine it in Entities.
        Edit: Found it --- the Grafana chart was filtered on 'WHERE name = Hub Information'
        when i removed that, the data (which was never really missing) appeared on the chart.
        Before:
        After:
        and digging a little further: I changed the capitalization on the device name when I recreated it:
          I would not leave an empty WHERE clause there... limit it to the entity you want to look at. If you don't, and you happen to modify your configuration down the road to include other extra attributes for any entity, they will be picked up by this query and seriously mess up this graph.
            3.6k
            3.2k
            694
          • Self test
