  3. Migrating Zwave & ZigBee stuff to MQTT - guidance needed.
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
73 Posts 4 Posters 43.9k Views 4 Watching
  • A a-lurker
    @akbooer
    I'm still delving into this, so my current knowledge is a little on the short side and the following is a little generalized. However:
    It seems that battery operated devices have nothing that can be controlled and their status cannot be read on demand ie no set or get possible (as indicated by an "access" sub property - see below). Presumably because they are asleep most of the time. So a battery powered Aqara motion detector publishes this only when it's triggered by motion:
    "zigbee2mqtt/0x01234567890abcde" and supplying a flat json payload containing all the properties - see previous post above.
    "zigbee2mqtt" begins all the topics. It can be set to something else but not sure why you would; unless you had multiple instances of zigbee2mqtt running.
    0x01234567890abcde is the "ieee_address" of the device and it can be associated with a "friendly_name" of your own choice, such as "bedroom1/left_corner/motion"
    So you could have topics such as:
    "zigbee2mqttInstance2/bedroom1/left_corner/motion" instead of "zigbee2mqtt/0x01234567890abcde"
    The bridge defines all the devices and the devices' topics:
    "zigbee2mqtt/bridge/devices" with a payload, which is an array of json objects - one for each device. ieee_address and friendly_name are top level properties of each device in the array. See previous post above.
    The "zigbee2mqtt/bridge/devices" topic is published when you first connect to the zigbee2mqtt server. ie you can't do a GET on it - not sure why that is. It's republished if a device joins or leaves. You can force a republish by doing: "zigbee2mqtt/bridge/request/restart" but that's a bit radical, as it does a full server restart.
    Each property in the device's status report is also further described by the bridge. So a status property such as temperature has sub properties eg "access", which indicates if the property can be set or get. ie battery operated devices can't be set or get. That is to say each device has an array of property description objects.
    So to set up: you would load up the array of devices from "zigbee2mqtt/bridge/devices". Then wizz through them looking for ones of interest under "definition.exposes[array]". Trying to identify what the device type is, appears to be a bit tricky. Looks like you have check the device for the presence of various property combinations or omissions.
    Aqara motion detector: has "occupancy". Also has device_temperature & illuminance, which in this case is not much use, as you only get the values when motion triggers the unit.
    Hue light bulb: has "light"
    Hue light switch: has "action"
    Gets tricky with say composite devices. But it would be good to allow some of them eg:
    Ikuü Dual outlet: has "switch" with "state_left" & "state_right" but no "brightness"
    Tuya five gang light switch: has: "switch" with "state_l1" to "state_l5" (but no "moving_*" properties see below).
    Lots of the devices also have temperature sensors and some have energy consumption sensors.
    But then you have this that helps confound identification of a device:
    Dual curtain/blind controller: It has "moving_left" & "moving_right" but it also has "state_left" & "state_right" like the Ikuü Dual outlet above!
    Controlling things - eg a light bulb. There are two ways:
    • send a block of json as the payload
    • or pure text as the payload, with words such as ON or OFF or TOGGLE
    From the following link that talks about these two SET & GET:
    In case you don't want to use JSON, publishing to zigbee2mqtt/[FRIENDLY_NAME]/set/state with payload ON is the same as publishing to zigbee2mqtt/[FRIENDLY_NAME]/set payload {"state": "ON"}"
    MQTT Topics and Messages | Zigbee2MQTT
    Hope this is of some help.
    @akbooer
    So far, I haven't looked at the ZWave bridge operation.
    • A a-lurker
      @akbooer
      @therealdb
      Log of switch operation:
      luup.call_action:: 209.urn:upnp-org:serviceId:SwitchPower1.SetTarget
      luup_log:209: VirtualDevices[3.0-beta7@209](actionPower@94):actionPower(209,"1")
      luup_log:209: VirtualDevices[3.0-beta7@209](actionPowerInternal@47):actionPowerInternal(209,true,true)
      luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:SwitchPower1","Target","1",209) old value "0"
      luup.variable_set:: 209.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0
      luup_log:209: VirtualDevices[3.0-beta7@209](sendDeviceCommand@308):sendDeviceCommand("SetPowerURL","on",209)
      These are all empty:
      MQTT_BrightnessValue
      MQTT_PowerStatusOff
      MQTT_PowerStatusOn
      These are all set to: "http://"
      SetPowerOffURL
      SetPowerURL
      SetToggleURL
      SetUpdateMetersURL
      A therealdbT 2 Replies Last reply
      • A a-lurker
        @therealdb
        MQTT_PowerStatusOff
        MQTT_PowerStatusOn
        SetPowerOffURL
        SetPowerURL
        SetToggleURL
        SetUpdateMetersURL
        @akbooer
        Zigbee supported devices page shows three column headings:
        • Vendor
        • Exposes
        • Search
        The "Exposes" pull down list is very useful as you can filter devices by what properties they expose. Useful for working on how to identify the device type. The filter allows multiple properties to be selected - allowing devices to be narrowed down further.
        • A a-lurker
          @akbooer
          • Vendor
          • Exposes
          • Search
          @akbooer
          Should be able to run this code to get some idea how the type of the zigbee devices could potentially be identified:
          local zigbee2mqtt_bridge_devices = [[
          	"definition": null,
          	"endpoints": {
          		"1": {
          			"bindings": [],
          			"clusters": {
          				"input": ["genBasic", "genIdentify", "genOnOff", "genTime", "genOta", "26", "lightingColorCtrl"],
          				"output": ["genBasic", "genIdentify", "genGroups", "genScenes", "genOnOff", "genLevelCtrl", "genPollCtrl", "lightingColorCtrl", "msIlluminanceMeasurement", "msTemperatureMeasurement", "msRelativeHumidity", "msOccupancySensing", "ssIasZone", "haMeterIdentification", "haApplianceStatistics", "haElectricalMeasurement", "seMetering", "touchlink", "manuSpecificUbisysDimmerSetup", "manuSpecificSamsungAccelerometer"]
          			"configured_reportings": [],
          			"scenes": []
          		"242": {
          			"bindings": [],
          			"clusters": {
          				"input": [],
          				"output": ["greenPower"]
          			"scenes": []
          	"friendly_name": "Coordinator",
          	"ieee_address": "0xredacted",
          	"interview_completed": true,
          	"interviewing": false,
          	"network_address": 0,
          	"supported": false,
          	"type": "Coordinator"
          	"date_code": "Dec7 2021",
          	"definition": {
          		"description": "Aqara P1 human body movement and illuminance sensor",
          		"exposes": [{
          			"access": 1,
          			"description": "Indicates whether the device detected occupancy",
          			"name": "occupancy",
          			"property": "occupancy",
          			"type": "binary",
          			"value_off": false,
          			"value_on": true
          			"access": 1,
          			"description": "Measured illuminance in lux",
          			"name": "illuminance_lux",
          			"property": "illuminance",
          			"type": "numeric",
          			"unit": "lx"
          			"access": 1,
          			"name": "illuminance",
          			"type": "numeric",
          			"unit": "lx"
          			"access": 7,
          			"description": ". Press pairing button right before changing this otherwise it will fail.",
          			"name": "motion_sensitivity",
          			"property": "motion_sensitivity",
          			"type": "enum",
          			"values": ["low", "medium", "high"]
          			"access": 7,
          			"description": "Time interval for detecting actions. Press pairing button right before changing this otherwise it will fail.",
          			"name": "detection_interval",
          			"property": "detection_interval",
          			"type": "numeric",
          			"unit": "s",
          			"value_max": 65535,
          			"value_min": 2
          			"access": 7,
          			"description": "When this option is enabled then blue LED will blink once when motion is detected. Press pairing button right before changing this otherwise it will fail.",
          			"name": "trigger_indicator",
          			"property": "trigger_indicator",
          			"type": "binary",
          			"value_off": false,
          			"value_on": true
          			"access": 1,
          			"description": "Temperature of the device",
          			"name": "device_temperature",
          			"property": "device_temperature",
          			"type": "numeric",
          			"unit": "°C"
          			"access": 1,
          			"description": "Remaining battery in %",
          			"name": "battery",
          			"property": "battery",
          			"type": "numeric",
          			"unit": "%",
          			"value_max": 100,
          			"value_min": 0
          			"access": 1,
          			"description": "Voltage of the battery in millivolts",
          			"name": "voltage",
          			"property": "voltage",
          			"type": "numeric",
          			"unit": "mV"
          			"access": 1,
          			"description": "Link quality (signal strength)",
          			"name": "linkquality",
          			"property": "linkquality",
          			"type": "numeric",
          			"unit": "lqi",
          			"value_max": 255,
          			"value_min": 0
          		"model": "RTCGQ14LM",
          		"options": [{
          			"access": 2,
          			"description": "Time in seconds after which occupancy is cleared after detecting it (default is \"detection_interval\" + 2 seconds). The value must be equal to or greater than \"detection_interval\", and it can also be a fraction.",
          			"name": "occupancy_timeout",
          			"property": "occupancy_timeout",
          			"type": "numeric",
          			"unit": "s",
          			"value_min": 0,
          			"value_step": 0.1
          			"access": 2,
          			"description": "Sends a message the last time occupancy (occupancy: true) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.",
          			"item_type": "number",
          			"name": "no_occupancy_since",
          			"property": "no_occupancy_since",
          			"type": "list"
          			"access": 2,
          			"description": "Calibrates the illuminance value (percentual offset), takes into effect on next report of device.",
          			"name": "illuminance_calibration",
          			"property": "illuminance_calibration",
          			"type": "numeric"
          			"access": 2,
          			"description": "Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.",
          			"name": "device_temperature_calibration",
          			"property": "device_temperature_calibration",
          			"type": "numeric"
          		"supports_ota": true,
          		"vendor": "Xiaomi"
          	"endpoints": {
          		"1": {
          			"bindings": [],
          			"clusters": {
          				"input": ["genBasic", "genPowerCfg", "genIdentify", "aqaraOpple"],
          				"output": ["genIdentify", "genOta", "aqaraOpple"]
          			"scenes": []
          	"friendly_name": "hello/testing",
          	"ieee_address": "0x01234567890abcde",
          	"manufacturer": "LUMI",
          	"model_id": "lumi.motion.ac02",
          	"network_address": 32549,
          	"power_source": "Battery",
          	"software_build_id": "0.0.0_0005",
          	"supported": true,
          	"type": "EndDevice"
          local json = require ('dkjson')
          local ZBdevices = json.decode(zigbee2mqtt_bridge_devices)
          print('Number of devices = '..#ZBdevices..'\n')
          for idx=1, #ZBdevices do
              print ('friendly_name is '..ZBdevices[idx].friendly_name)
              print ('ieee_address is '..ZBdevices[idx].ieee_address..'\n')
              -- if not the coordinator
              if ZBdevices[idx].definition then
                  print('Properties follow:')
                  local foundMotion = false
                  for idx2=1, #ZBdevices[idx].definition.exposes do
                      devProperty = ZBdevices[idx].definition.exposes[idx2].property
                      print (devProperty)
                      if devProperty == 'occupancy' then
                          foundMotion = true
                  if foundMotion then print("\nDevice is a motion sensor") end
          return true
          • A a-lurker
            @therealdb
            MQTT_PowerStatusOff
            MQTT_PowerStatusOn
            SetPowerOffURL
            SetPowerURL
            SetToggleURL
            SetUpdateMetersURL
            SetPowerOffURL
            SetPowerURL
            SetToggleURL
            SetUpdateMetersURL
            Set them to skip and try again.
              SetPowerOffURL
              SetPowerURL
              SetToggleURL
              SetUpdateMetersURL
              @therealdb
              OK it works with them all set to skip although the documentation says blank, skip or http:// is OK😁 . Might be useful to initialize them to skip.
              • A a-lurker
                @akbooer
                Certainly is! I'll pull something together and post it in the testing branch. Might need a bit of to and fro to get going properly.
                  #24
                  @a-lurker
                  There is a new version (v22.11.27) in the testing branch.
                  If you connect to the openLuup MQTT server, then it should detect the "bridge/devices" message and create some generic devices with some partial info about them in some variables. Just a basic test to show that the fundamentals work.
                  When the message is first detected, openLuup will create a Zigbee2MQTT bridge, a room called Zigbee and the child devices in that room. Here's what I get with the sample code you provided above (excellent starting info, by the way!) ...
                  • A a-lurker
                    @therealdb
                    @therealdb
                    Yep, time to update docs and the lib. Thanks for letting me know.
                      I've slightly refined the individual device variables.
                      Should be easy to select at least some device types from this...
                        #27
                        @akbooer
                        All works as advertised!! Excellent work. I still don't see the last image of the variables - still see the table pointers; as per your early image. Probably the latest code hadn't been committed to GitHub, judging by your commit times & post times.
                        I installed the openLuup testing branch and restarted. All worked as normal. Then I restarted the zigbee2mqtt server forcing it to output the "bridge/devices" message and everything got going in openLuup - great.
                        This is going to provide a lot possibilities. Currently 2507 possibilities! Downside is I may have to go and buy a few more devices.
                        Here's the start up log with a few edits and minus the date time. Might be useful to have say "none" or "****" for UserName & Password in the log. The "My Lua ver 0.50 debug:" is some of my test code:
                        Thank you very much for your efforts.
                        openLuup.io.server:: MQTT:1883 connection from XXX.XX.XX.XX tcp{client}: 0x47e20b0
                        openLuup.mqtt:: CONNECT tcp{client}: 0x47e20b0
                        openLuup.mqtt:: ClientId: mqttjs_19f169d2
                        openLuup.mqtt:: WillTopic: zigbee2mqtt/bridge/state
                        openLuup.mqtt:: WillMessage: {"state":"offline"}
                        openLuup.mqtt:: UserName: ****
                        openLuup.mqtt:: Password: ****
                        openLuup.mqtt:: PUBLISH tcp{client}: 0x47e20b0
                        luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt/bridge/state
                        openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x47e20b0
                        openLuup.mqtt:: Packet Id: 0x2972
                        openLuup.mqtt:: Topic: zigbee2mqtt/#
                        openLuup.mqtt:: mqttjs_19f169d2 SUBSCRIBE to zigbee2mqtt/# tcp{client}: 0x47e20b0
                        luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt/bridge/info
                        luup.zigbee2mqtt:0: New Zigbee detected: 0x84b4dbfffecc0c6f
                        openLuup.luup:: creating room [36] Zigbee
                        luup.create_device:: [20001] D_GenericZigbeeDevice.xml /  / D_GenericZigbeeDevice.json   (GenericZigbeeDevice)
                        luup.zigbee2mqtt:0: New Zigbee detected: 0x01234567890abcde
                        luup.create_device:: [20002] D_GenericZigbeeDevice.xml /  / D_GenericZigbeeDevice.json   (GenericZigbeeDevice)
                        luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt/bridge/groups
                        luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt/bridge/extensions
                        luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt/bridge/logging
                        luup_log:0: My Lua ver 0.50 debug: topic = zigbee2mqtt/0x01234567890abcde
                        luup_log:0: My Lua ver 0.50 debug: device_temperature = 18
                        luup_log:0: My Lua ver 0.50 debug: illuminance = 316
                        luup_log:0: My Lua ver 0.50 debug: occupancy = false
                          Great! Yes, haven’t committed the latest.
                          So that’s enough to get you going, then?
                          What else is needed? Obviously device type Identification and variable updates…
                            #29
                            Device detection would be good. Hoping to see but asking a lot:
                            • Occupancy sensor as per the device already shown in zigbee2mqtt/bridge payload.
                            • RGB & white adjustable light bulb in this link. It's pretty typical. RGB would be optional. ie some bulbs being white only tunable.
                            • Something like this Chinese dual outlet.. This would produce two virtual switches.
                            • Hue switch/buttons. and similarly something like this single button. or this one.
                            The above should allow a Hue hub replacement in most cases? Noting the Hue switch is pretty tricky to replicate. Seems like it's effectively a scene controller.
                            The Occupancy sensor also has illuminance and temperature but certainly at this stage; just need the device's primary function.
                            I note in the documents some of the properties are in round brackets eg:
                            light (state, brightness, color_temp, color_xy), effect, power_on_behavior, linkquality
                            I don't know but I suspect that those properties in round braces are sub properties of the property of 'light" and that would be reflected in the MQTT device definition json as such. I need to add in a few more devices to my zigbee network to be definitive.
                            I had a look at the ZWave JS UI . Probably not overly different form Zigbee.
                            • A a-lurker
                              @akbooer
                              This would seem to be a somewhat ambiguous convention, since MQTT topics are also subdivided with the '/' symbol. Especially since these can then be suffixed...
                              • zigbee2mqtt/FRIENDLY_NAME/availability
                              • zigbee2mqtt/FRIENDLY_NAME/set
                              • zigbee2mqtt/FRIENDLY_NAME/get
                              ...and so on.
                              I suppose we have to go with it.
                                #31
                                @a-lurker
                                New testing version v22.11.28 with the updated variable listing and also (perhaps) device identification for:
                                • lights (displayed as switch)
                                • switches (displayed as scene controller)
                                • occupancy (displayed as motion sensor)
                                • generic
                                The identified devices should have some of their standard serviceIds and variables.
                                Can I get a more complete bridge/devices JSON to try?
                                  @a-lurker
                                  • generic
                                  #32
                                  @akbooer
                                  This is all coming along nicely - thanks.
                                  I've set up a Hue color/tuneable white light bulb as it's probably the most complicated of the lights. This is what it replies with when you do a "zigbee2mqtt/0xaa55aa55aa55aa55/set" with payload {"state": "TOGGLE"}
                                    "color_mode": "xy",
                                    "linkquality": 255,
                                    "state": "ON"
                                  Not sure if the "color_mode" is actually changeable. ie whether it's always XY color (CIE 1931 color space) or whether it can be RGB style. I note the Ikea bulbs just seem to be XY space.
                                  If I change a color in the zigbee2MQTT web page it sends (not sure about all the back slashes):
                                  'zigbee2mqtt/0xaa55aa55aa55aa55',
                                  payload '{\"color\":{\"x\":0.4339,\"y\":0.5008},\"color_mode\":\"xy\",\"linkquality\":255,\"state\":\"ON\"}'"}
                                  this is the reply from the bulb.
                                    "color": {
                                      "x": 0.6942,
                                      "y": 0.2963
                                    "color_mode": "xy",
                                    "linkquality": 255,
                                    "state": "ON"
                                  Here's "zigbee2mqtt/bridge/devices" for the light bulb only. You see there is a further lower level "features" below "exposes" ie "description,exposes,features". I've just cut & pasted the light bulb json description part below. It's just concatenated with the coordinator and the occupancy sensor, that you have already been using. I hope this is not getting unduly complex.
                                  The coordinator and the occupancy sensor are listed here in the json and this is the light bulb:
                                      "date_code": "20210331",
                                      "definition": {
                                        "description": "Hue white and color ambiance E26/E27/E14",
                                        "exposes": [
                                            "features": [
                                                "access": 7,
                                                "description": "On/off state of this light",
                                                "name": "state",
                                                "property": "state",
                                                "type": "binary",
                                                "value_off": "OFF",
                                                "value_on": "ON",
                                                "value_toggle": "TOGGLE"
                                                "access": 7,
                                                "description": "Brightness of this light",
                                                "name": "brightness",
                                                "property": "brightness",
                                                "type": "numeric",
                                                "value_max": 254,
                                                "value_min": 0
                                                "access": 7,
                                                "description": "Color temperature of this light",
                                                "name": "color_temp",
                                                "presets": [
                                                    "description": "Coolest temperature supported",
                                                    "name": "coolest",
                                                    "value": 153
                                                    "description": "Cool temperature (250 mireds / 4000 Kelvin)",
                                                    "name": "cool",
                                                    "value": 250
                                                    "description": "Neutral temperature (370 mireds / 2700 Kelvin)",
                                                    "name": "neutral",
                                                    "value": 370
                                                    "description": "Warm temperature (454 mireds / 2200 Kelvin)",
                                                    "name": "warm",
                                                    "value": 454
                                                    "description": "Warmest temperature supported",
                                                    "name": "warmest",
                                                    "value": 500
                                                "property": "color_temp",
                                                "type": "numeric",
                                                "unit": "mired",
                                                "value_max": 500,
                                                "value_min": 153
                                                "access": 7,
                                                "description": "Color temperature after cold power on of this light",
                                                "name": "color_temp_startup",
                                                "presets": [
                                                    "name": "coolest",
                                                    "value": 153
                                                    "name": "cool",
                                                    "value": 250
                                                    "name": "neutral",
                                                    "value": 370
                                                    "name": "warm",
                                                    "value": 454
                                                    "name": "warmest",
                                                    "value": 500
                                                    "description": "Restore previous color_temp on cold power on",
                                                    "name": "previous",
                                                    "value": 65535
                                                "property": "color_temp_startup",
                                                "type": "numeric",
                                                "unit": "mired",
                                                "value_max": 500,
                                                "value_min": 153
                                                "description": "Color of this light in the CIE 1931 color space (x/y)",
                                                "features": [
                                                    "access": 7,
                                                    "name": "x",
                                                    "property": "x",
                                                    "type": "numeric"
                                                    "access": 7,
                                                    "name": "y",
                                                    "property": "y",
                                                    "type": "numeric"
                                                "name": "color_xy",
                                                "property": "color",
                                                "type": "composite"
                                                "description": "Color of this light expressed as hue/saturation",
                                                "features": [
                                                    "access": 7,
                                                    "name": "hue",
                                                    "property": "hue",
                                                    "type": "numeric"
                                                    "access": 7,
                                                    "name": "saturation",
                                                    "property": "saturation",
                                                    "type": "numeric"
                                                "name": "color_hs",
                                                "type": "composite"
                                            "type": "light"
                                            "access": 2,
                                            "description": "Triggers an effect on the light (e.g. make light blink for a few seconds)",
                                            "name": "effect",
                                            "property": "effect",
                                            "type": "enum",
                                            "values": [
                                              "blink",
                                              "breathe",
                                              "okay",
                                              "channel_change",
                                              "finish_effect",
                                              "stop_effect"
                                            "access": 1,
                                            "type": "numeric",
                                            "unit": "lqi",
                                            "value_max": 255,
                                            "value_min": 0
                                        "model": "9290012573A",
                                        "options": [
                                            "access": 2,
                                            "description": "Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).",
                                            "name": "transition",
                                            "property": "transition",
                                            "type": "numeric",
                                            "value_min": 0
                                            "access": 2,
                                            "description": "When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).",
                                            "name": "color_sync",
                                            "property": "color_sync",
                                            "type": "binary",
                                            "value_off": false,
                                            "value_on": true
                                        "vendor": "Philips"
                                      "endpoints": {
                                        "11": {
                                          "bindings": [],
                                          "clusters": {
                                            "input": [
                                              "genBasic",
                                              "genIdentify",
                                              "genGroups",
                                              "genScenes",
                                              "genOnOff",
                                              "genLevelCtrl",
                                              "touchlink",
                                              "manuSpecificPhilips2",
                                            "output": [
                                              "genOta"
                                          "scenes": []
                                        "242": {
                                          "bindings": [],
                                          "clusters": {
                                            "input": [
                                              "greenPower"
                                            "output": [
                                              "greenPower"
                                          "scenes": []
                                      "friendly_name": "0xaa55aa55aa55aa55",
                                      "ieee_address": "0xaa55aa55aa55aa55",
                                      "manufacturer": "Signify Netherlands B.V.",
                                      "model_id": "LCT010",
                                      "network_address": 34172,
                                      "power_source": "Mains (single phase)",
                                      "software_build_id": "1.88.1",
                                      "supported": true,
                                      "type": "Router"
                                  zigbee2mqtt has individual device set up/review pages. You can see here that all the colors can be set up for example. The tooltip shows underlying stuff. In this case for color_hs.
                                    @a-lurker
                                    New testing version v22.11.29 should identify (some) lights, and it's plausible that the on/off control will work (the dimmer doesn't, and the internal state doesn't yet get updated.) Would be interested in the log when trying this.
                                      @a-lurker
                                      #34
                                      @akbooer
                                      Making great progress. The light is recognized and can be turned on & off. Also if I change the color with the zigbee2mqtt web page and then turn the light off and on in AltUI the color is retained.
                                      Here is one observed issue: I have in my own code with a subscription to the occupancy sensor and using that to set a switch in VirtualHTTP. Has been working and has now stopped working. You see the code here - line 415.. Looks like something in openLuup has stopped that functioning? See error in log below:
                                      luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true
                                      luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } })
                                      openLuup.context_switch::  ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)
                                      openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)
                                      openLuup.scheduler:: [211] Zigbee2MQTT device startup
                                      luup.set_failure:: status = 0
                                      luup.variable_set:: 211.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                                      luup.variable_set:: 211.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                                      openLuup.scheduler:: [211] Zigbee2MQTT device startup completed: status=true, msg=OK, name=Zigbee2MQTTBridge
                                      Start up of openLuup and then connecting to zigbee2mqtt server follows:
                                      openLuup.mqtt:: CONNECT tcp{client}: 0x2d4a968
                                      openLuup.mqtt:: ClientId: mqttjs_2080d9ee
                                      openLuup.mqtt:: CONNECT tcp{client}: 0x25141a0
                                      openLuup.mqtt:: ClientId: mqtt-explorer-27e89756
                                      openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x25141a0
                                      openLuup.mqtt:: Packet Id: 0xa5b3
                                      openLuup.mqtt:: Topic: #
                                      openLuup.mqtt:: mqtt-explorer-27e89756 SUBSCRIBE to # tcp{client}: 0x25141a0
                                      openLuup.mqtt:: Packet Id: 0xa5b4
                                      openLuup.mqtt:: Topic: $SYS/#
                                      openLuup.mqtt:: mqtt-explorer-27e89756 SUBSCRIBE to $SYS/# tcp{client}: 0x25141a0
                                      openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x2d4a968
                                      openLuup.mqtt:: Packet Id: 0x6437
                                      openLuup.mqtt:: mqttjs_2080d9ee SUBSCRIBE to zigbee2mqtt/# tcp{client}: 0x2d4a968
                                      openLuup.mqtt:: PUBLISH tcp{client}: 0x2d4a968
                                      luup.zigbee2mqtt:0: Topic ignored : bridge/logging
                                      luup.zigbee2mqtt:0: Topic ignored : bridge/state
                                      openLuup.server:: request completed (871430 bytes, 55 chunks, 630 ms) tcp{client}: 0x29113e0
                                      openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=768995292&_=1669768933474 HTTP/1.1 tcp{client}: 0x29113e0
                                      openLuup.server:: request completed (1679360 bytes, 105 chunks, 1182 ms) tcp{client}: 0x29113e0
                                      Restart of zigbee2mqtt server to force devices to be announced by the zigbee2mqtt server. You see the zigbee devices being detected and set up by openLuup.
                                      openLuup.mqtt:: CONNECT tcp{client}: 0x2ac56b0
                                      openLuup.mqtt:: ClientId: mqttjs_689eab85
                                      openLuup.mqtt:: PUBLISH tcp{client}: 0x2ac56b0
                                      openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x2ac56b0
                                      openLuup.mqtt:: Packet Id: 0x8099
                                      openLuup.mqtt:: mqttjs_689eab85 SUBSCRIBE to zigbee2mqtt/# tcp{client}: 0x2ac56b0
                                      luup.zigbee2mqtt:0: Topic ignored : bridge/info
                                      luup.zigbee2mqtt:0: New Zigbee detected: 0xRedacted1
                                      luup.zigbee2mqtt:0: New Zigbee detected: 0xRedacted2
                                      luup.create_device:: [20002] D_MotionSensor1.xml /  / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                                      luup.zigbee2mqtt:0: New Zigbee detected: 0xRedacted3
                                      luup.create_device:: [20003] D_DimmableLight1.xml /  / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
                                      openLuup.server:: request completed (16218 bytes, 2 chunks, 4645 ms) tcp{client}: 0x2456b18
                                      luup.zigbee2mqtt:0: Topic ignored : bridge/groups
                                      luup.zigbee2mqtt:0: Topic ignored : bridge/extensions
                                      Here is the light being turned on & off noting that it actually does go on & off but I'm unclear about all the "Topic ignored". eg "0x_redacted_light_bulb/set/state"
                                      openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=20003&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1 HTTP/1.1 tcp{client}: 0x28ba940
                                      luup.call_action:: 20003.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                                      luup.call_action:: action will be handled by parent: 211
                                      luup.zigbee2mqtt:0: Topic ignored : 0x_redacted_light_bulb/set/state
                                      openLuup.server:: request completed (35 bytes, 1 chunks, 16 ms) tcp{client}: 0x28ba940
                                      luup.watch_callback:: 12.urn:a-lurker-com:serviceId:Paradox_IP150_wps1.Zone_018 called [3]variableWatchCallback() function: 0x156a978
                                      openLuup.mqtt:: PUBLISH tcp{client}: 0x2b88a08
                                      luup.variable_set:: 10021.urn:micasaverde-com:serviceId:ZWaveNetwork1.LastPollSuccess was: 1669791951 now: 1669792831 #hooks:0
                                      openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=769116357&Timeout=60&MinimumDelay=1500&_=1669769862259 HTTP/1.1 tcp{client}: 0x1f620a0
                                      openLuup.server:: request completed (7375 bytes, 1 chunks, 120 ms) tcp{client}: 0x1f620a0
                                      openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=769116361&Timeout=60&MinimumDelay=1500&_=1669769862260 HTTP/1.1 tcp{client}: 0x1f620a0
                                      openLuup.server:: request completed (35 bytes, 1 chunks, 4 ms) tcp{client}: 0x28ba940
                                      openLuup.server:: request completed (6642 bytes, 1 chunks, 3272 ms) tcp{client}: 0x1f620a0
                                      openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=769116362&Timeout=60&MinimumDelay=1500&_=1669769862261 HTTP/1.1 tcp{client}: 0x1f620a0
                                      openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=20003&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0 HTTP/1.1 tcp{client}: 0x28ba940
                                      openLuup.server:: request completed (6870 bytes, 1 chunks, 4973 ms) tcp{client}: 0x1f620a0
                                      Here is the light being turned on & off being reported by zigbee2mqtt in the linux terminal.
                                      Zigbee2MQTT:info  2022-11-30 18:20:30: MQTT publish: topic 'zigbee2mqtt/0x_redacted_light_bulb', payload '{"brightness":42,"color":{"x":0.5267,"y":0.4133},"color_mode":"color_temp","color_temp":500,"linkquality":224,"state":"ON"}'
                                      Zigbee2MQTT:info  2022-11-30 18:20:35: MQTT publish: topic 'zigbee2mqtt/0x_redacted_light_bulb', payload '{"brightness":42,"color":{"x":0.5267,"y":0.4133},"color_mode":"color_temp","color_temp":500,"linkquality":232,"state":"ON"}'
                                      Zigbee2MQTT:info  2022-11-30 18:20:40: MQTT publish: topic 'zigbee2mqtt/0x_redacted_light_bulb', payload '{"brightness":42,"color":{"x":0.5267,"y":0.4133},"color_mode":"color_temp","color_temp":500,"linkquality":224,"state":"OFF"}'
                                      Zigbee2MQTT:info  2022-11-30 18:26:51: MQTT publish: topic 'zigbee2mqtt/0x_redacted_occupancy_sensor', payload '{"battery":100,"detection_interval":30,"device_temperature":19,"illuminance":77,"linkquality":132,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"voltage":3189}'
                                      • A a-lurker
                                        @akbooer
                                        This is clearly a nil topic value in the call. Where that is supposed to come from, I don't know.
                                        The ignored topics are the reason that the openLuup device state is not changing – I simply haven't coded the monitoring side of things yet. The next step.
                                        I'm unclear because of your log edits whether the devices are using their ieee_address or their friendly_name as MQTT topics. AFAIK, it's legal to use either? I need to make some extra arrangements if so.
                                        Which devices are currently not being correctly identified?
                                          "The ignored topics are the reason that the openLuup device state is not changing – I simply haven't coded the monitoring side of things yet" - makes sense. Yes next step.
                                          "your log edits": - sorry about this. Being a bit paranoid. All the ieee_address(s) and their associated friendly_name(s) are equal to each other. I haven't changed them. They are still the hex "mac" addresses of the devices.
                                          "AFAIK, it's legal to use either? " It would certainly appear so. The use of the friendly_name(s) would certainly be needed to do topic filtering. ie plus & hash. But I've made no attempt so far to change the friendly_name(s). Trying to keep the change in all the variables to a minimum.
                                          "This is clearly a nil topic value in the call" - this is my separate code. I subscribe to the occupancy sensor and the openLuup handler routine is coded to set a virtual switch. Seems the topic is getting screwed up in the handler but may be red herring, so please don't take too much notice. However as far as I can see @thereadldb has not made any recent code changes.
                                          "Which devices are currently not being correctly identified?" - errhh none! Working very well so far.
                                          If I need to provide more info please let me know.
                                          akbooerA 2 Replies Last reply
                                            163.3k
