  3. Vera/openLuup plugins
  4. SiteSensor: get data from Wunderground suddenly stopped
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
B
B
Broadlink setup
Virtual Sensor Polling
B
Z
12 Posts 3 Posters 2.5k Views 3 Watching
    Maipensato
    I use the excellent SiteSensor plugin of @toggledbits for some years to get the data from my PWS on Wunderground.
    This has worked flawlessly but recently it suddenly stopped working.
    I see this in my Vera:
    When I copy/paste the URL code to be queried in my browser this still works.
    This is the URL:
    https://api.weather.com/v2/pws/observations/current?stationId=ILIMBURG130&format=json&units=m&numericPrecision=decimal&apiKey=xxxxxxxxxxxxxxxxxxxxxxxxx
    Patrick (or someone else on this forum) can you help me solve this ?
    Many thanks in advance!
      Ah, I remember this message...
      IIRC, "Can't Detect Device" is Vera-speak for "you have an error in some Lua code somewhere, perhaps a scene?"
      I might be wrong, because it's been a while. Did you make some recent changes somewhere?
        SiteSensor sensors will mark the device failed if the query doesn't succeed.
        I'm betting that weather.com has upped their requirements for SSL/TLS, and now the aged-out Lua https library can't negotiate key exchange or encryption with the server. This is going to happen more and more often as the Vera firmware ages (and they don't update it). This is the reason that the MyQ plugin and others have failed as well. The problem is worse for Vera 3 and Lite models, which have even older libraries.
        SiteSensor and most of my other plugins that use HTTPS connections have the ability to use curl as an alternative to the Lua library. In SiteSensor in particular, this is enabled by setting the UseCurl state variable to 1. As it turns out, the curl command in the OpenWRT Vera uses as its OS base is built with a slightly more modern encryption package than the Lua library, so curl may work for a while.
        But, it's only putting off the inevitable. This is your sign to get off Vera. Tick tock...
          Maipensato
          wrote on last edited by Maipensato
          @toggledbits Many thanks for your quick reply! Putting UseCurl on 1 made it working again!
          So for now I'm saved.
          Now I really have to start looking for another smarthome setup. I now have quite an extensive setup with 3 Vera controllers (Secure and Plus) with a lot of Reactor Sensors and Site Sensors etc. and also a Fibaro HC2 controller.
          And I use the Home Remote app that works with both Vera and Fibaro.
          I put a lot of hours in it to set this all up and adapt it to my wishes and I must say it works (almost) rocksolid past 2 years.
          Have to spend quite some time first to look at all the alternatives coming months. For sure I will find useful information here on this forum (e.g. Home Assistant in combination with your MSR)
            Yes, definitely the time to quit Vera. As if it knew this itself, my last VeraLite failed a few weeks ago, so this signalled the end of any Zwave devices for me, having moved on to Zigbee and Shelly devices.
            This may well not be an option for you, so the forum here (and others) should indeed be of some help.
            Good luck! Let us know what you do.
              Maipensato
              @toggledbits My PWS uploads data to Wunderground via a Meteobridge device. I just found out I can retrieve live data of my weatherstation via a http request to Meteobridge. So this is a way to to get my weatherdata in Vera via SiteSensor plugin. Without being dependent on external cloudservers like Wunderground.
              The only issue is the output is not available in json, only in xml format or plain text. I see that you can select the response type Generic (text) but then you have to define a "response pattern to match" in the next field.
              I went though the SiteSensor thread on the Vera forum and found lots of examples for json output but none for generic text output.
              The output of the Meteobridge URL looks like:
              20221204112238 th0 3.4 84 0.9 1
              20221204112301 wind0 112 1.3 1.3 1.5 0
              20221204112241 thb0 9.4 59 1.8 1017.0 1017.0 0 0
              where first is time stamp, then device id and then all the data.
              th0 = temp/hum sensor 3.4 is temp (Celsius) 84 is hum% 0.9 is dewpoint and 1 = lowbat
              Can you help me in how to get for example temp and hum values; what should I put in the field "enter pattern to match"
                Is this on Vera or openLuup? I have an XML reader module that’s built in to openLuup. It would also work if loaded into Vera. Creates a DOM which can be navigated in Lua.
                If you send an example of the XML output, then I could show how to extract your information.
                  Maipensato
                  This is on Vera.
                  xml output:
                  <logger>
                  <TH date="20221204143607" id="th0" temp="3.7" hum="84" dew="1.2" lowbat="1"/>
                  <WIND date="20221204143606" id="wind0" dir="22" gust="1.7" wind="1.7" chill="1.5" lowbat="0"/>
                  <THB date="20221204143541" id="thb0" temp="9.3" hum="59" dew="1.7" press="1016.0" seapress="1016.0" fc="0" lowbat="0"/>
                  </logger>
                    You don't need an XML parser for that. Simple pattern matching will do.
                    This code snippet extracts all the data into a Lua table...
                    local xml = [[
                    <logger>
                    </logger>
                    local data = {}
                    for stype, l in xml: gmatch '<(%a+)%s+(.-)/>' do
                      local items = {}
                      for a,b in l: gmatch '(%a+)="([^"]+)"' do
                        items[a] = tonumber(b) or b
                      data[stype] = items
                    print(pretty(data))
                    ...giving this output:
                      TH = {
                        date = 20221204143607,
                        dew = 1.2,
                        hum = 84,
                        id = "th0",
                        lowbat = 1,
                        temp = 3.7
                      THB = {
                        date = 20221204143541,
                        dew = 1.7,
                        fc = 0,
                        hum = 59,
                        id = "thb0",
                        lowbat = 0,
                        press = 1016,
                        seapress = 1016,
                        temp = 9.3
                      WIND = {
                        chill = 1.5,
                        date = 20221204143606,
                        dir = 22,
                        gust = 1.7,
                        id = "wind0",
                        lowbat = 0,
                        wind = 1.7
                    M 1 Reply Last reply
                      local xml = [[
                      <logger>
                      </logger>
                      local data = {}
                        local items = {}
                        data[stype] = items
                      print(pretty(data))
                        TH = {
                          dew = 1.2,
                          hum = 84,
                          id = "th0",
                          lowbat = 1,
                          temp = 3.7
                        THB = {
                          dew = 1.7,
                          fc = 0,
                          hum = 59,
                          id = "thb0",
                          lowbat = 0,
                          press = 1016,
                          seapress = 1016,
                          temp = 9.3
                        WIND = {
                          chill = 1.5,
                          dir = 22,
                          gust = 1.7,
                          id = "wind0",
                          lowbat = 0,
                          wind = 1.7
                      Maipensato
                      @akbooer many thanks !
                      Good to know this is possible.
                      I doubt wether I can use this within SiteSensor.
                      But I think I can use this within the Reactor plugin with some adaptions in the Lua code. It would have to send the invididual sensor data to the virtual weathersensors like every 30 or 60 seconds.
                      Or use it within MSR when I would decide to migrate partially of completely from Vera to HA or Hubitat.
                      @toggledbits can I use this kind of script within SiteSensor ? Hope you can help me in the right direction.
                        You can't use this within SiteSensor.
                        In the Reactor for Vera plugin, it's no problem to use Lua to make the request and pull out the data as @akbooer has shown.
                        In Multi-Hub Reactor (aka MSR) the expression language, rather than Lua, can perform the task. This would be a good use of the VirtualEntityController to create and manage the entities and their attributes.
                          Maipensato
                          @toggledbits Okay clear, thanks for your quick reply!
                          What about SiteSensor and select response type Generic (text). How can I define a "response pattern to match" in the next field.
                          It's good to know it's possible within Reactor Sensor but it would be easier (I hope...) to solve it within SiteSensor.
                            961
                            2.0k
                            3.7k
                            3.3k
