  3. Migrating Zwave & ZigBee stuff to MQTT - guidance needed.
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
73 Posts 4 Posters 43.9k Views 4 Watching
    @a-lurker
    New testing version v22.11.28 with the updated variable listing and also (perhaps) device identification for:
    • lights (displayed as switch)
    • switches (displayed as scene controller)
    • occupancy (displayed as motion sensor)
    • generic
    The identified devices should have some of their standard serviceIds and variables.
    Can I get a more complete bridge/devices JSON to try?
    #32
    @akbooer
    This is all coming along nicely - thanks.
    I've set up a Hue color/tuneable white light bulb as it's probably the most complicated of the lights. This is what it replies with when you do a "zigbee2mqtt/0xaa55aa55aa55aa55/set" with payload {"state": "TOGGLE"}
      "color_mode": "xy",
      "linkquality": 255,
      "state": "ON"
    Not sure if the "color_mode" is actually changeable. ie whether it's always XY color (CIE 1931 color space) or whether it can be RGB style. I note the Ikea bulbs just seem to be XY space.
    If I change a color in the zigbee2MQTT web page it sends (not sure about all the back slashes):
    'zigbee2mqtt/0xaa55aa55aa55aa55',
    payload '{\"color\":{\"x\":0.4339,\"y\":0.5008},\"color_mode\":\"xy\",\"linkquality\":255,\"state\":\"ON\"}'"}
    this is the reply from the bulb.
      "color": {
        "x": 0.6942,
        "y": 0.2963
      "color_mode": "xy",
      "linkquality": 255,
      "state": "ON"
    Here's "zigbee2mqtt/bridge/devices" for the light bulb only. You see there is a further lower level "features" below "exposes" ie "description,exposes,features". I've just cut & pasted the light bulb json description part below. It's just concatenated with the coordinator and the occupancy sensor, that you have already been using. I hope this is not getting unduly complex.
    The coordinator and the occupancy sensor are listed here in the json and this is the light bulb:
        "date_code": "20210331",
        "definition": {
          "description": "Hue white and color ambiance E26/E27/E14",
          "exposes": [
              "features": [
                  "access": 7,
                  "description": "On/off state of this light",
                  "name": "state",
                  "property": "state",
                  "type": "binary",
                  "value_off": "OFF",
                  "value_on": "ON",
                  "value_toggle": "TOGGLE"
                  "access": 7,
                  "description": "Brightness of this light",
                  "name": "brightness",
                  "property": "brightness",
                  "type": "numeric",
                  "value_max": 254,
                  "value_min": 0
                  "access": 7,
                  "description": "Color temperature of this light",
                  "name": "color_temp",
                  "presets": [
                      "description": "Coolest temperature supported",
                      "name": "coolest",
                      "value": 153
                      "description": "Cool temperature (250 mireds / 4000 Kelvin)",
                      "name": "cool",
                      "value": 250
                      "description": "Neutral temperature (370 mireds / 2700 Kelvin)",
                      "name": "neutral",
                      "value": 370
                      "description": "Warm temperature (454 mireds / 2200 Kelvin)",
                      "name": "warm",
                      "value": 454
                      "description": "Warmest temperature supported",
                      "name": "warmest",
                      "value": 500
                  "property": "color_temp",
                  "type": "numeric",
                  "unit": "mired",
                  "value_max": 500,
                  "value_min": 153
                  "access": 7,
                  "description": "Color temperature after cold power on of this light",
                  "name": "color_temp_startup",
                  "presets": [
                      "name": "coolest",
                      "value": 153
                      "name": "cool",
                      "value": 250
                      "name": "neutral",
                      "value": 370
                      "name": "warm",
                      "value": 454
                      "name": "warmest",
                      "value": 500
                      "description": "Restore previous color_temp on cold power on",
                      "name": "previous",
                      "value": 65535
                  "property": "color_temp_startup",
                  "type": "numeric",
                  "unit": "mired",
                  "value_max": 500,
                  "value_min": 153
                  "description": "Color of this light in the CIE 1931 color space (x/y)",
                  "features": [
                      "access": 7,
                      "name": "x",
                      "property": "x",
                      "type": "numeric"
                      "access": 7,
                      "name": "y",
                      "property": "y",
                      "type": "numeric"
                  "name": "color_xy",
                  "property": "color",
                  "type": "composite"
                  "description": "Color of this light expressed as hue/saturation",
                  "features": [
                      "access": 7,
                      "name": "hue",
                      "property": "hue",
                      "type": "numeric"
                      "access": 7,
                      "name": "saturation",
                      "property": "saturation",
                      "type": "numeric"
                  "name": "color_hs",
                  "type": "composite"
              "type": "light"
              "access": 2,
              "description": "Triggers an effect on the light (e.g. make light blink for a few seconds)",
              "name": "effect",
              "property": "effect",
              "type": "enum",
              "values": [
                "blink",
                "breathe",
                "okay",
                "channel_change",
                "finish_effect",
                "stop_effect"
              "access": 1,
              "description": "Link quality (signal strength)",
              "name": "linkquality",
              "property": "linkquality",
              "type": "numeric",
              "unit": "lqi",
              "value_max": 255,
              "value_min": 0
          "model": "9290012573A",
          "options": [
              "access": 2,
              "description": "Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).",
              "name": "transition",
              "property": "transition",
              "type": "numeric",
              "value_min": 0
              "access": 2,
              "description": "When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).",
              "name": "color_sync",
              "property": "color_sync",
              "type": "binary",
              "value_off": false,
              "value_on": true
          "supports_ota": true,
          "vendor": "Philips"
        "endpoints": {
          "11": {
            "bindings": [],
            "clusters": {
              "input": [
                "genBasic",
                "genIdentify",
                "genGroups",
                "genScenes",
                "genOnOff",
                "genLevelCtrl",
                "touchlink",
                "manuSpecificPhilips2",
                "lightingColorCtrl",
                "manuSpecificUbisysDimmerSetup"
              "output": [
                "genOta"
            "configured_reportings": [],
            "scenes": []
          "242": {
            "bindings": [],
            "clusters": {
              "input": [
                "greenPower"
              "output": [
                "greenPower"
            "scenes": []
        "friendly_name": "0xaa55aa55aa55aa55",
        "ieee_address": "0xaa55aa55aa55aa55",
        "interview_completed": true,
        "interviewing": false,
        "manufacturer": "Signify Netherlands B.V.",
        "model_id": "LCT010",
        "network_address": 34172,
        "power_source": "Mains (single phase)",
        "software_build_id": "1.88.1",
        "supported": true,
        "type": "Router"
    zigbee2mqtt has individual device set up/review pages. You can see here that all the colors can be set up for example. The tooltip shows underlying stuff. In this case for color_hs.
      @a-lurker
      New testing version v22.11.29 should identify (some) lights, and it's plausible that the on/off control will work (the dimmer doesn't, and the internal state doesn't yet get updated.) Would be interested in the log when trying this.
        @a-lurker
        #34
        @akbooer
        Making great progress. The light is recognized and can be turned on & off. Also if I change the color with the zigbee2mqtt web page and then turn the light off and on in AltUI the color is retained.
        Here is one observed issue: I have in my own code with a subscription to the occupancy sensor and using that to set a switch in VirtualHTTP. Has been working and has now stopped working. You see the code here - line 415.. Looks like something in openLuup has stopped that functioning? See error in log below:
        luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true
        luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } })
        openLuup.context_switch::  ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)
        openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)
        openLuup.scheduler:: [211] Zigbee2MQTT device startup
        luup.set_failure:: status = 0
        luup.variable_set:: 211.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
        luup.variable_set:: 211.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
        openLuup.scheduler:: [211] Zigbee2MQTT device startup completed: status=true, msg=OK, name=Zigbee2MQTTBridge
        Start up of openLuup and then connecting to zigbee2mqtt server follows:
        openLuup.mqtt:: CONNECT tcp{client}: 0x2d4a968
        openLuup.mqtt:: ClientId: mqttjs_2080d9ee
        openLuup.mqtt:: WillTopic: zigbee2mqtt/bridge/state
        openLuup.mqtt:: WillMessage: {"state":"offline"}
        openLuup.mqtt:: UserName: ****
        openLuup.mqtt:: Password: ****
        openLuup.mqtt:: CONNECT tcp{client}: 0x25141a0
        openLuup.mqtt:: ClientId: mqtt-explorer-27e89756
        openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x25141a0
        openLuup.mqtt:: Packet Id: 0xa5b3
        openLuup.mqtt:: Topic: #
        openLuup.mqtt:: mqtt-explorer-27e89756 SUBSCRIBE to # tcp{client}: 0x25141a0
        openLuup.mqtt:: Packet Id: 0xa5b4
        openLuup.mqtt:: Topic: $SYS/#
        openLuup.mqtt:: mqtt-explorer-27e89756 SUBSCRIBE to $SYS/# tcp{client}: 0x25141a0
        openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x2d4a968
        openLuup.mqtt:: Packet Id: 0x6437
        openLuup.mqtt:: Topic: zigbee2mqtt/#
        openLuup.mqtt:: mqttjs_2080d9ee SUBSCRIBE to zigbee2mqtt/# tcp{client}: 0x2d4a968
        openLuup.mqtt:: PUBLISH tcp{client}: 0x2d4a968
        luup.zigbee2mqtt:0: Topic ignored : bridge/logging
        luup.zigbee2mqtt:0: Topic ignored : bridge/state
        openLuup.server:: request completed (871430 bytes, 55 chunks, 630 ms) tcp{client}: 0x29113e0
        openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=768995292&_=1669768933474 HTTP/1.1 tcp{client}: 0x29113e0
        openLuup.server:: request completed (1679360 bytes, 105 chunks, 1182 ms) tcp{client}: 0x29113e0
        Restart of zigbee2mqtt server to force devices to be announced by the zigbee2mqtt server. You see the zigbee devices being detected and set up by openLuup.
        openLuup.mqtt:: CONNECT tcp{client}: 0x2ac56b0
        openLuup.mqtt:: ClientId: mqttjs_689eab85
        openLuup.mqtt:: PUBLISH tcp{client}: 0x2ac56b0
        openLuup.mqtt:: SUBSCRIBE tcp{client}: 0x2ac56b0
        openLuup.mqtt:: Packet Id: 0x8099
        openLuup.mqtt:: mqttjs_689eab85 SUBSCRIBE to zigbee2mqtt/# tcp{client}: 0x2ac56b0
        luup.zigbee2mqtt:0: Topic ignored : bridge/info
        luup.zigbee2mqtt:0: New Zigbee detected: 0xRedacted1
        luup.create_device:: [20001] D_GenericZigbeeDevice.xml /  / D_GenericZigbeeDevice.json   (GenericZigbeeDevice)
        luup.zigbee2mqtt:0: New Zigbee detected: 0xRedacted2
        luup.create_device:: [20002] D_MotionSensor1.xml /  / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
        luup.zigbee2mqtt:0: New Zigbee detected: 0xRedacted3
        luup.create_device:: [20003] D_DimmableLight1.xml /  / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
        openLuup.server:: request completed (16218 bytes, 2 chunks, 4645 ms) tcp{client}: 0x2456b18
        luup.zigbee2mqtt:0: Topic ignored : bridge/groups
        luup.zigbee2mqtt:0: Topic ignored : bridge/extensions
        Here is the light being turned on & off noting that it actually does go on & off but I'm unclear about all the "Topic ignored". eg "0x_redacted_light_bulb/set/state"
        openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=20003&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1 HTTP/1.1 tcp{client}: 0x28ba940
        luup.call_action:: 20003.urn:upnp-org:serviceId:SwitchPower1.SetTarget
        luup.call_action:: action will be handled by parent: 211
        luup.zigbee2mqtt:0: Topic ignored : 0x_redacted_light_bulb/set/state
        openLuup.server:: request completed (35 bytes, 1 chunks, 16 ms) tcp{client}: 0x28ba940
        luup.watch_callback:: 12.urn:a-lurker-com:serviceId:Paradox_IP150_wps1.Zone_018 called [3]variableWatchCallback() function: 0x156a978
        openLuup.mqtt:: PUBLISH tcp{client}: 0x2b88a08
        luup.variable_set:: 10021.urn:micasaverde-com:serviceId:ZWaveNetwork1.LastPollSuccess was: 1669791951 now: 1669792831 #hooks:0
        openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=769116357&Timeout=60&MinimumDelay=1500&_=1669769862259 HTTP/1.1 tcp{client}: 0x1f620a0
        openLuup.server:: request completed (7375 bytes, 1 chunks, 120 ms) tcp{client}: 0x1f620a0
        openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=769116361&Timeout=60&MinimumDelay=1500&_=1669769862260 HTTP/1.1 tcp{client}: 0x1f620a0
        openLuup.server:: request completed (35 bytes, 1 chunks, 4 ms) tcp{client}: 0x28ba940
        openLuup.server:: request completed (6642 bytes, 1 chunks, 3272 ms) tcp{client}: 0x1f620a0
        openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=769116362&Timeout=60&MinimumDelay=1500&_=1669769862261 HTTP/1.1 tcp{client}: 0x1f620a0
        openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=20003&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0 HTTP/1.1 tcp{client}: 0x28ba940
        openLuup.server:: request completed (6870 bytes, 1 chunks, 4973 ms) tcp{client}: 0x1f620a0
        Here is the light being turned on & off being reported by zigbee2mqtt in the linux terminal.
        Zigbee2MQTT:info  2022-11-30 18:20:30: MQTT publish: topic 'zigbee2mqtt/0x_redacted_light_bulb', payload '{"brightness":42,"color":{"x":0.5267,"y":0.4133},"color_mode":"color_temp","color_temp":500,"linkquality":224,"state":"ON"}'
        Zigbee2MQTT:info  2022-11-30 18:20:35: MQTT publish: topic 'zigbee2mqtt/0x_redacted_light_bulb', payload '{"brightness":42,"color":{"x":0.5267,"y":0.4133},"color_mode":"color_temp","color_temp":500,"linkquality":232,"state":"ON"}'
        Zigbee2MQTT:info  2022-11-30 18:20:40: MQTT publish: topic 'zigbee2mqtt/0x_redacted_light_bulb', payload '{"brightness":42,"color":{"x":0.5267,"y":0.4133},"color_mode":"color_temp","color_temp":500,"linkquality":224,"state":"OFF"}'
        Zigbee2MQTT:info  2022-11-30 18:26:51: MQTT publish: topic 'zigbee2mqtt/0x_redacted_occupancy_sensor', payload '{"battery":100,"detection_interval":30,"device_temperature":19,"illuminance":77,"linkquality":132,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"voltage":3189}'
        • A a-lurker
          @akbooer
          This is clearly a nil topic value in the call. Where that is supposed to come from, I don't know.
          The ignored topics are the reason that the openLuup device state is not changing – I simply haven't coded the monitoring side of things yet. The next step.
          I'm unclear because of your log edits whether the devices are using their ieee_address or their friendly_name as MQTT topics. AFAIK, it's legal to use either? I need to make some extra arrangements if so.
          Which devices are currently not being correctly identified?
            "The ignored topics are the reason that the openLuup device state is not changing – I simply haven't coded the monitoring side of things yet" - makes sense. Yes next step.
            "your log edits": - sorry about this. Being a bit paranoid. All the ieee_address(s) and their associated friendly_name(s) are equal to each other. I haven't changed them. They are still the hex "mac" addresses of the devices.
            "AFAIK, it's legal to use either? " It would certainly appear so. The use of the friendly_name(s) would certainly be needed to do topic filtering. ie plus & hash. But I've made no attempt so far to change the friendly_name(s). Trying to keep the change in all the variables to a minimum.
            "This is clearly a nil topic value in the call" - this is my separate code. I subscribe to the occupancy sensor and the openLuup handler routine is coded to set a virtual switch. Seems the topic is getting screwed up in the handler but may be red herring, so please don't take too much notice. However as far as I can see @thereadldb has not made any recent code changes.
            "Which devices are currently not being correctly identified?" - errhh none! Working very well so far.
            If I need to provide more info please let me know.
            akbooerA 2 Replies Last reply
            • A a-lurker
              Oh! ... wasn't expecting that!
              Currently working on the device variable status updates.
              • A a-lurker
                I did, at least, replace username and password in the MQTT diagnostics with "****"!
                These wouldn't anyway appear in the log at all if you had not enabled DEBUG in that module.
                  #39
                  New testing version v22.11.30 should now mirror the device status (on/off and brightness) and also enable the openLuup device on/off control to work. Brightness level not yet implemented.
                  Battery levels should be shown too (once the device has woken up.)
                  Does the occupancy sensor work too?
                    @akbooer
                    Looking good - using AltUI for the following:
                    Light bulb:
                    Works:
                    • on/off does control the bulb
                    • variable LoadLevelStatus reflects any brightness changes
                    • virtually all variables are loaded with a few exceptions - see below
                    Doesn't work:
                    • brightness slider (as you noted)
                    • light bulb icon does not change state in UI
                    • variable LoadLevelTarget is always zero
                    • variable linkquality is not loaded from the mqtt messages
                    • variable effect is not loaded from the mqtt messages
                    Motion detector:
                    Works:
                    • red dagger shows in UI when triggered
                    • last trigger time shows in the UI (30 secs later as per its set up parms)
                    • battery icon shows with percentage
                    Not loaded from the mqtt messages:
                    • detection_interval
                    • device_temperature
                    • illuminance
                    • illuminance_lux
                    • linkquality
                    • motion_sensitivity
                    • occupancy
                    • trigger_indicator
                    • voltage
                    Other:
                    • variable "BatteryLevel" (and UI icon) shows "100" and variable "battery" shows "numeric". mqtt exposes "battery", so maybe some mix up or duplication here. They're probably the same thing - one mios & one zigbee.
                    Start up problem:
                    Conditions:
                    • devices have all been previously detected and built and are available in AltUI.
                    • the zigbee2mqtt server is running.
                    OK now restart openLupp. Status of all devices are not updated by any incoming mqtt messages from then on. Log says: "Topic Ignored : 0x_ieee_address".
                    Referring to file L_Zigbee2MQTTBridge.lua: function handle_friendly_names line 407 . Table "devices" is empty, so "dno" and "D" are nil.
                    Reason: it appears the "devices" table is loaded by "function init_device" and this is only called when the devices are first created in "function create_devices".
                    The devices table needs to be loaded if the devices have already been created. The work around is to restart the zigbee2mqtt server, so it publishes the topic "zigbee2mqtt/devices".
                    Logging:
                    Another slight issue with logging: The log showed for example on occasion : "bridge/logging" when it's actually "zigbee2mqtt/bridge/logging". The prefix zigbee2mqtt is missing and it makes a little unclear what topic is actually being ignored. Just makes it a bit harder to debug.
                    Console -> openLuup -> About:
                    There is item labelled "Debug" - how do you set this to true?
                    Everything is coming together!
                    • A a-lurker
                      @akbooer
                      Light bulb:
                      Works:
                      Doesn't work:
                      Motion detector:
                      Works:
                      • illuminance
                      • illuminance_lux
                      • linkquality
                      • occupancy
                      • trigger_indicator
                      • voltage
                      Other:
                      Start up problem:
                      Conditions:
                      Logging:
                      #41
                      Next device I'm hoping to try out: a Xiaomi button.
                      The above has similarities with the Hue dimmer switch
                      And then there is the magic cube - that's a very interesting one. eg you can just rotate it to dim/undim lights. Flip it and control something else.
                        Thanks for the report… all exactly as I would expect. Indeed I had not done anything about initialisation apart from the bridge/device message. I now need to use the variables from existing devices to build the initial table.
                        I see what you mean about the error message. Will fix that. Will post separately on the debug switch. It may make sense to have console page for that.
                          @a-lurker
                          Latest testing version v22.12.01 should fix all reported issues.
                          I'm working on the switches. These will appear as scene controllers.
                            @a-lurker
                            Just pushed v22.12.01b with initial go at supporting those switches.
                              @a-lurker
                              @akbooer
                              Light bulb slider now working:
                              Issue with variable updating. Looks like api.lua handles this somehow in the meta verse:
                              openLuup.context_switch::  ERROR: [dev #0] ./openLuup/L_Zigbee2MQTTBridge.lua:166: ERROR - READONLY: attempt to create index illuminance
                              So added some debug code to this section - not sure how variable "S" is used:
                                -- update exposed values
                                local S = D.exposes
                                for n,v in pairs (message) do
                                  D[n] = tostring(v)
                              Motion sensor:
                              luup_log:0: D: table: 0x1b25f70
                              luup_log:0: S: table: 0x1680730
                              luup_log:0: n: illuminance
                              luup_log:0: v: 75
                              luup_log:0: n: device_temperature
                              luup_log:0: v: 20
                              luup_log:0: n: battery
                              luup_log:0: v: 100
                              luup_log:0: n: occupancy
                              luup_log:0: v: false
                              luup_log:0: n: detection_interval
                              luup_log:0: v: 30
                              luup_log:0: n: voltage
                              luup_log:0: v: 3177
                              luup_log:0: n: linkquality
                              luup_log:0: v: 255
                              luup_log:0: n: trigger_indicator
                              luup_log:0: n: power_outage_count
                              luup_log:0: v: 0
                              luup_log:0: n: motion_sensitivity
                              luup_log:0: v: medium
                              Light bulb. Note that "color" and "update" are table ptrs:
                              luup_log:0: D: table: 0x1b25a30
                              luup_log:0: S: table: 0xed39b0
                              luup_log:0: n: state
                              luup_log:0: v: ON
                              luup_log:0: n: color_temp
                              luup_log:0: v: 153
                              luup_log:0: n: color_mode
                              luup_log:0: v: xy
                              luup_log:0: v: table: 0x8ec4f8
                              luup_log:0: n: brightness
                              luup_log:0: v: 53
                              luup_log:0: v: 212
                              luup_log:0: n: update
                              luup_log:0: v: table: 0x3e0268
                                Ooops!
                                Looks like this should be:
                                    S[n] = tostring(v)
                                  #47
                                  @a-lurker
                                  ” Looks like api.lua handles this somehow in the meta verse:”
                                  Yes, FYI the new openLuup API maps device services and variables directly into the plug-in context. There are shorthand names for the otherwise unwieldy serviceIds:
                                  API[devNo][serviceId][varname] = value    -- sets the value
                                  value = API[devNo][serviceId][varname]    -- gets the value
                                  These are all standard Lua (metatable) structures, so you can write:
                                  D = API[devNo]    -- the device
                                  S = D[serviceId]    -- the service
                                  S[varname] = value    -- sets the value
                                  value = S[varname]    -- gets the value
                                  kWh = D.energy.KWH    -- get device energy usage
                                  It’s still evolving, but this much is stable. It’s so neat and readable compared to the usual luup.variable_set/get() calls, and I’m now using it all the time in new code development (since I’ll never be writing another Vera-compatible plug-in.)
                                    @a-lurker
                                    Switching to the development branch for updates...
                                    new v22.12.5 should update those table variables now (and fix the typo.)
                                      @a-lurker
                                      @akbooer
                                      This is all going nicely - but time will tell how reliable the system as whole would be. Have added in one of these Aqara buttons and it work fine.
                                      Zigbee2mqtt "interviews" a device while it's being paired. On occasion the interview is partially completed ie it fails and some variables are void or invalid but "Interview completed" is still set to true.
                                      With such a faulty pairing and with openLuup being subjected to same, more often or not, the function "infer_device_type" will default to "D_GenericZigbeeDevice.xml", of which the actual file doesn't seem to exist. So one occasion I observed this error, which appears to be related:
                                      openLuup.context_switch::  ERROR: [dev #0] ./openLuup/L_Zigbee2MQTTBridge.lua:438: attempt to call field '?' (a nil value)
                                      openLuup.mqtt:: ERROR publishing application message for mqtt:zigbee2mqtt/0x00158d000706951c : ./openLuup/L_Zigbee2MQTTBridge.lua:438: attempt to call field '?' (a nil value)
                                      You have to repair the device, delete the "Generic" device in AltUI and then restart the zigbee2mqtt server to get the correct device to show in AltUI.
                                      Inference: Looking at the function "infer_device_type: the code IMO should be split, so "switch" and "action" produce different devices ie an on/off switch or a scene controller:
                                      In GitHub: elseif exp.switch or exp.action then
                                      The nomenclature is bit tricky: switch is often conflated with power relay switches and say a scene controller switch. In Zigbee2MQTT speak, a "switch" is like a relay (mechanical or solid state) and a scene controller switch is considered something that has an "action".
                                      Composite devices will become an issue and hopefully that can be handled in the future (yes can of worms), especially dual outlet power sockets or multi gang switches, which are ubiquitous.
                                      Here is an example of sometime that doesn't fit the mold. These Aqara devices logically act as both a switch and a scene controller. Question arises if you do say a "double" click, what happens to the switch status. Likewise for say "hold_release". There are very few of these devices and they are nearly all made by Xiaomi.
                                      • A a-lurker
                                        @akbooer
                                        #50
                                        Is there some symptomatic problem I should know about?
                                        It does, in openLuup's virtual world. If you try http://openLuupIP:3480/D_GenericZigbeeDevice.xml you should see this in the browser:
                                        <?xml version="1.0"?>
                                        <root xmlns="urn:schemas-upnp-org:device-1-0">
                                         <specVersion>
                                          <major>1</major>
                                          <minor>0</minor>
                                          <minimus>auto-generated</minimus></specVersion>
                                         <device>
                                          <staticJson>D_GenericZigbeeDevice.json</staticJson>
                                          <deviceType>GenericZigbeeDevice</deviceType></device></root>
                                        I'll fix the error and review the infer_device_type() function. It was always going to evolve anyway as different device needs arise.
                                        I have tended to represent any sort of multi-action switch as a scene controller. There will always be difficult cases (sometimes resolved by using vendor/manufacturer) but I have shied away from an extensive configuration database. Plausible, I suppose, to pull this from the web...?
                                        I rely on Philips Hue for the few Zigbee devices that I have, so probably won't get to road test this for myself. You're going to want to do the whole thing again for Zwave JS ?
                                           <specVersion>
                                            <major>1</major>
                                            <minor>0</minor>
                                           <device>
                                          @akbooer said in Migrating Zwave & ZigBee stuff to MQTT - guidance needed.:
                                          I don't think so but who wants to set up heaps of devices in a new set up when everything has been going well for years with just openLuup and an old Vera war horse!
                                          Don't need to get to complicated too soon, as you just about have it all covered but I'm still thinking of one of these Hue Smart plugs. It's just a switch, as opposed to a scene controller.
                                          Arrhh you know you want to ditch that hub.
                                          Maybe after a cup of tea and good lie down. And yourself?
                                            163.6k
