  3. Migrating Zwave & ZigBee stuff to MQTT - guidance needed.
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
73 Posts 4 Posters 43.9k Views 4 Watching
    #56
    A slight in convenience: no way to set color on the light bulbs. X,Y color space seems better than RGB as it allows you to specify white color temperature.
    A akbooerA 2 Replies Last reply
    • A a-lurker
      This vibration detection device and other similar devices should be "inferred" as a motion sensor. They expose "contact".
      Perhaps infer_device_type() could use some look up table or look at json string that could perhaps be later saved to a file that the user could fiddle with? eg some vague pesudo code. Whatever you figure would work.
      local deviceType = nil
      if (lookup.exposes.contact) then
          deviceType = lookup.exposes.contact
      • A a-lurker
        @akbooer said in Migrating Zwave & ZigBee stuff to MQTT - guidance needed.:
        Release development v22.12.6 separating switch and controller devices, and fixing nil function pointer
        Thanks for that - looks OK now.
        Have now got all my Hue stuff running with no Hue hub - that's good. A few complications here and there.
        Main complication:
        Conditions:
        z2m is running and openLuup is running.
        Then pair new device: in this case this Philips light bulb with z2m.
        z2m logs this to the terminal. I've prettied the json section so you can read it:
        Zigbee2MQTT:info  2022-12-10 10:40:28: Device '0x001788010363fcbf' joined
        Zigbee2MQTT:info  2022-12-10 10:40:28: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x001788010363fcbf","ieee_address":"0x001788010363fcbf"},"type":"device_joined"}'
        Zigbee2MQTT:info  2022-12-10 10:40:28: Starting interview of '0x001788010363fcbf'
        Zigbee2MQTT:info  2022-12-10 10:40:28: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x001788010363fcbf","ieee_address":"0x001788010363fcbf","status":"started"},"type":"device_interview"}'
        Zigbee2MQTT:info  2022-12-10 10:40:29: Successfully interviewed '0x001788010363fcbf', device has successfully been paired
        Zigbee2MQTT:info  2022-12-10 10:40:29: Device '0x001788010363fcbf' is supported, identified as: Philips Hue White A60 Single bulb E27/B22 (8718696449691)
        Zigbee2MQTT:info  2022-12-10 10:40:29: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '
        	"data": {
        		"definition": {
        			"description": "Hue White A60 Single bulb E27/B22",
        			"exposes": [{
        				"features": [{
        					"access": 7,
        					"description": "On/off state of this light",
        					"name": "state",
        					"property": "state",
        					"type": "binary",
        					"value_off": "OFF",
        					"value_on": "ON",
        					"value_toggle": "TOGGLE"
        					"access": 7,
        					"description": "Brightness of this light",
        					"name": "brightness",
        					"property": "brightness",
        					"type": "numeric",
        					"value_max": 254,
        					"value_min": 0
        				"type": "light"
        				"access": 2,
        				"description": "Triggers an effect on the light (e.g. make light blink for a few seconds)",
        				"name": "effect",
        				"property": "effect",
        				"type": "enum",
        				"values": ["blink", "breathe", "okay", "channel_change", "finish_effect", "stop_effect"]
        				"access": 1,
        				"description": "Link quality (signal strength)",
        				"name": "linkquality",
        				"property": "linkquality",
        				"type": "numeric",
        				"unit": "lqi",
        				"value_max": 255,
        				"value_min": 0
        			"model": "8718696449691",
        			"options": [{
        				"access": 2,
        				"description": "Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).",
        				"name": "transition",
        				"property": "transition",
        				"type": "numeric",
        				"value_min": 0
        			"supports_ota": true,
        			"vendor": "Philips"
        		"friendly_name": "0x001788010363fcbf",
        		"ieee_address": "0x001788010363fcbf",
        		"status": "successful",
        		"supported": true
        	"type": "device_interview"
        Zigbee2MQTT:info  2022-12-10 10:40:29: Configuring '0x001788010363fcbf'
        Zigbee2MQTT:info  2022-12-10 10:40:29: Successfully configured '0x001788010363fcbf'
        Looks like openLuup then responds to the topic zigbee2mqtt/bridge/event ?? and creates a Generic device. The openLuup log doesn't make it clear what topic it's responding to when it creates a device but you can see in the log that it has found a new device:
        2022-12-10 10:40:28.568   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.571   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:28.574   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.591   luup.zigbee2mqtt:0: New Zigbee detected: 0x001788010363fcbf
        2022-12-10 10:40:28.594   luup.create_device:: [20010] D_GenericZigbeeDevice.xml /  / D_GenericZigbeeDevice.json   (GenericZigbeeDevice)
        2022-12-10 10:40:28.602   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.603   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:28.605   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.605   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/event
        2022-12-10 10:40:28.607   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.607   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:28.609   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.626   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.626   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:28.628   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:28.628   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/event
        2022-12-10 10:40:28.754   openLuup.server:: request completed (11333 bytes, 1 chunks, 2261 ms) tcp{client}: 0x43d0070
        2022-12-10 10:40:28.766   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=564556066&_=1670559272961 HTTP/1.1 tcp{client}: 0x43d0070
        2022-12-10 10:40:29.987   openLuup.server:: request completed (1723523 bytes, 108 chunks, 1220 ms) tcp{client}: 0x43d0070
        2022-12-10 10:40:30.017   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.017   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:30.018   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.018   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:30.020   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.032   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.033   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:30.034   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.035   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/event
        2022-12-10 10:40:30.036   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.036   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:30.037   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.037   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/logging
        2022-12-10 10:40:30.039   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.048   openLuup.mqtt:: PUBLISH tcp{client}: 0x3a7b670
        2022-12-10 10:40:30.052   luup.zigbee2mqtt:0: Topic ignored : zigbee2mqtt : / : bridge/info
        So it looks as the event returns the same data as "zigbee2mqtt/bridge/devices" does, as each new device is paired but it's parent json is a little different. The device definition is below "data" in the json:
        "data":
        With type set as follows:
        type="device_interview",
        and this must indicate success:
        data.status ="successful"
        Hope that's clear - bit hard to explain.
        Suffice to say I added a pile of stuff and ended up with a whole pile of generic devices, which I had to remove one by one with a openLuup restart for each. Got a bit ambitious!
        However; it looks like the ability to handle the addition of new devices on the fly without having to restart thez2m server each time to get the device definitions, would certainly be possible and a welcome addition.
        Looks like you just look for the event topic with {"type":"device_interview" and {"data": status":"successful".
        The json contains definition.expose.type = light so the function infer_device_type() should still do its work OK as it currently does.
        I can't test any new code on this as I have now added all my devices. Although I could unpair just a light bulb and repair it and see what happens.
        #58
        Can't see how that would happen. The bridge code is clear that anything other than bridge/devices is ignored:
        local function handle_bridge_topics (topic, message)
          local subtopic = topic: match "^bridge/(.+)"
          if subtopic: match "^devices" then
            create_devices (message)
          else
            ignore_topic (topic)
        and it should write Topic ignored... in the log. If it creates a device, it must be receiving the actual /devices topics. I take it that your "info" log messages are your own additions to the code. I could certainly make it respond to a /event topic. The Shelly and Tasmota bridges already create new devices on the fly, because they send their own configurations when they connect to MQTT.
        • A a-lurker
          Conditions:
          Having just added a scene controller to z2m and restarted the z2m server and openLuup has dutifully added it in and here it is:
          Great; so first thing to do next, is to link the scene controller to a scene: So create a new scene, dial up the scene controller and put a watch on to create a trigger:
          LastSceneTime	(new~=old)
          Problem is LastSceneTime is nowhere to be found - bit disconcerting at this point. In order to proceed, you have to push a button on the scene controller to get the variable to be created. Suggest the variable is created when the scene controller is first added to openLuup and set its time to Unix year zero.
          Yes, that's true. The root cause is actually that the service file for a scene controller S_SceneController1.xml does not contain a definition of that variable, or a default vaule for it. I could force this at device creation, but you have found a work-around alreay.
          • A a-lurker
            Some investigation required here. The existing Color service definition defines three actions of interest:
            1. setColor
            2. setColorRGB
            3. setColorTemperature
            It's not clear from the service file definition what the possible value/syntax is for any of these commands, so that would mean delving into the UPnP documentation, which, previously, I've found to be an absolute nightmare (as are most international standard definitions.) Perhaps csomeone here can aleady tell us the answer?
            • A a-lurker
              Do you have the bridge/devices JSON for that device?
                ...and I have just done so in development v22.12.11.
                  No but I would see it as no different to checking "occupancy" in the motion sensor device.
                      else
                    The two logs are directly as they were spat out, except for uncollapsing of the json as mentioned above. I made no changes.
                    Yes - this is very odd - I can't see how the code would respond to anything else but the bridges/devices topic either. But certainly it appears to have done same; but unsuccessfully as all devices ended up being considered Generic. I may have to try repairing a bulb with more debug code.
                    Moving forward - responding to an /event topic would be good.
                      These messages:
                      …don’t come from my code. You mentioned that this was printed out to the console… something else must be doing this too.
                        1. setColor
                        2. setColorRGB
                        setColor
                        setColorRGB
                        setColorTemperature
                        I've done a lot of work on the color side of thing in the Vera, and my code used to work on openluup as well. Feel free to take inspiration from https://github.com/dbochicchio/vera-VirtualDevices/blob/master/L_VirtualRGBW1.lua
                        From line 134 you'll find all the formats that luup is supporting, at least on Vera's side. There's also W/D, for warn and cool white.
                          These messages:
                          #67
                          Yes - this is the output from z2m to its terminal, which I am monitoring. ie from the z2m server. Not from openLuup.
                          So the z2m server is interviewing the newly detected device and recognises it; next it ends up being created in openLuup!
                          • A a-lurker
                            #68
                            Mystery solved (partially.) From the docs:
                            ”Contains the devices connected to the bridge, this message is published as retained. Whenever a device joins or leaves this is republished.”
                            …but this doesn’t explain why the devices are not identified correctly.
                              #69
                              @akbooer
                              Well this turns out to be the case. Neither openLuup or z2m logged this, as you can see in the logs provided above. However I added logging some code to openLuup and yes and as expected the zigbee2mqtt/bridge/devices topic is published each time you add & remove a zigbee device, which is great. Would be good to see openLuup log the json info when any topic is RX'ed and when MQTT is in debug mode. mqttExplorer would have picked this up but it wasn't running at the time.
                              Here is the definition json for the dual general purpose outlet (GPO):
                              	"date_code": "",
                              	"definition": {
                              		"description": "Ikuü double power point with USB",
                              		"exposes": [{
                              			"endpoint": "left",
                              			"features": [{
                              				"access": 7,
                              				"description": "On/off state of the switch",
                              				"endpoint": "left",
                              				"name": "state",
                              				"property": "state_left",
                              				"type": "binary",
                              				"value_off": "OFF",
                              				"value_on": "ON",
                              			"type": "switch"
                              			"endpoint": "right",
                              			"features": [{
                              				"access": 7,
                              				"name": "state",
                              				"property": "state_right",
                              				"type": "binary",
                              				"value_off": "OFF",
                              				"value_on": "ON",
                              			"type": "switch"
                              			"access": 1,
                              			"description": "Instantaneous measured power",
                              			"endpoint": "left",
                              			"name": "power",
                              			"property": "power_left",
                              			"type": "numeric",
                              			"unit": "W"
                              			"access": 1,
                              			"description": "Instantaneous measured electrical current",
                              			"endpoint": "left",
                              			"name": "current",
                              			"property": "current_left",
                              			"type": "numeric",
                              			"unit": "A"
                              			"access": 1,
                              			"description": "Measured electrical potential value",
                              			"endpoint": "left",
                              			"name": "voltage",
                              			"property": "voltage_left",
                              			"type": "numeric",
                              			"unit": "V"
                              			"access": 1,
                              			"description": "Sum of consumed energy",
                              			"name": "energy",
                              			"property": "energy",
                              			"type": "numeric",
                              			"unit": "kWh"
                              			"access": 1,
                              			"type": "numeric",
                              			"unit": "lqi",
                              			"value_max": 255,
                              			"value_min": 0
                              		"model": "SPPUSB02",
                              		"options": [{
                              			"access": 2,
                              			"description": "Calibrates the power value (percentual offset), takes into effect on next report of device.",
                              			"name": "power_calibration",
                              			"property": "power_calibration",
                              			"type": "numeric"
                              			"access": 2,
                              			"description": "Calibrates the current value (percentual offset), takes into effect on next report of device.",
                              			"name": "current_calibration",
                              			"property": "current_calibration",
                              			"type": "numeric"
                              			"access": 2,
                              			"description": "Calibrates the voltage value (percentual offset), takes into effect on next report of device.",
                              			"name": "voltage_calibration",
                              			"property": "voltage_calibration",
                              			"type": "numeric"
                              		"supports_ota": false,
                              		"vendor": "Mercator"
                              	"endpoints": {
                              		"1": {
                              			"bindings": [{
                              				"cluster": "genBasic",
                              				"target": {
                              					"endpoint": 1,
                              					"ieee_address": "0x84b4dbfffecc0c6f",
                              					"type": "endpoint"
                              				"cluster": "genOnOff",
                              				"target": {
                              					"endpoint": 1,
                              					"type": "endpoint"
                              				"cluster": "haElectricalMeasurement",
                              				"target": {
                              					"endpoint": 1,
                              					"type": "endpoint"
                              				"cluster": "seMetering",
                              				"target": {
                              					"endpoint": 1,
                              					"type": "endpoint"
                              			"clusters": {
                              				"input": ["genBasic", "genGroups", "genScenes", "genOnOff", "seMetering", "haElectricalMeasurement", "manuSpecificTuya", "genIdentify"],
                              				"output": ["genOta", "genTime"]
                              			"configured_reportings": [{
                              				"attribute": "rmsVoltage",
                              				"maximum_report_interval": 3600,
                              				"minimum_report_interval": 5,
                              				"reportable_change": 5
                              				"attribute": "rmsCurrent",
                              				"reportable_change": 50
                              				"attribute": "activePower",
                              				"reportable_change": 1
                              				"attribute": "onOff",
                              				"minimum_report_interval": 0,
                              				"reportable_change": 0
                              			"scenes": []
                              		"2": {
                              			"bindings": [{
                              				"target": {
                              					"endpoint": 1,
                              					"type": "endpoint"
                              			"clusters": {
                              				"input": ["genGroups", "genScenes", "genOnOff", "manuSpecificTuya", "genIdentify"],
                              				"output": []
                              			"scenes": []
                              		"242": {
                              			"bindings": [],
                              			"clusters": {
                              				"input": [],
                              				"output": ["greenPower"]
                              			"configured_reportings": [],
                              			"scenes": []
                              	"friendly_name": "0x842e14fffe13d0d5",
                              	"ieee_address": "0x842e14fffe13d0d5",
                              	"interview_completed": true,
                              	"interviewing": false,
                              	"manufacturer": "_TZ3210_pfbzs1an",
                              	"model_id": "TS011F",
                              	"network_address": 64390,
                              	"power_source": "Mains (single phase)",
                              	"supported": true,
                              	"type": "Router"
                              To recognise this GPO, the function infer_device_type() needs to have a minor change:
                                  --elseif exp.switch then
                                  elseif exp.type == "switch" then
                              That's not going to help very much as the device has two outlets and hence two independently controllable relays. It also has Voltage, current & power measurement but to make everything more difficult the power measurement is the addition of the power consumed by both outlets. This implies the device needs to be represented as a single parent with two children. Gets a bit messy.
                              The json defines two "Endpoint"s: "Endpoint: left" & "Endpoint: right". I note that ZWave JS UI takes the same sort of approach of making use of endpoints for compound devices.
                              Looking through the zigbee devices database you see identifiers such as follows - for compound devices:
                              state
                              state_left, state_right
                              state_left, state_center, state_right
                              state_top, state_center, state_bottom
                              state_l1, state_l2, state_l3, state_l4  --> state_lX
                              state_top_left, state_center_left, state_bottom_left, state_top_right, state_center_right, state_bottom_right,
                              The dual GPO under discussion returns this payload regularly:
                                "current_left": 0,
                                "energy": 0,
                                "linkquality": 252,
                                "power_left": 0,
                                "state_left": "OFF",
                                "state_right": "OFF",
                                "voltage_left": 245
                              In fact, straight after purchase, it was returning this about every two seconds but fortunately in the z2m web page, you can change the reporting interval.
                              • A a-lurker
                                @akbooer
                                	"date_code": "",
                                	"definition": {
                                		"exposes": [{
                                			"endpoint": "left",
                                			"features": [{
                                				"access": 7,
                                				"endpoint": "left",
                                				"name": "state",
                                				"type": "binary",
                                				"value_off": "OFF",
                                				"value_on": "ON",
                                			"type": "switch"
                                			"features": [{
                                				"access": 7,
                                				"name": "state",
                                				"type": "binary",
                                				"value_off": "OFF",
                                				"value_on": "ON",
                                			"type": "switch"
                                			"access": 1,
                                			"endpoint": "left",
                                			"name": "power",
                                			"type": "numeric",
                                			"unit": "W"
                                			"access": 1,
                                			"endpoint": "left",
                                			"name": "current",
                                			"type": "numeric",
                                			"unit": "A"
                                			"access": 1,
                                			"endpoint": "left",
                                			"name": "voltage",
                                			"type": "numeric",
                                			"unit": "V"
                                			"access": 1,
                                			"name": "energy",
                                			"type": "numeric",
                                			"unit": "kWh"
                                			"access": 1,
                                			"type": "numeric",
                                			"unit": "lqi",
                                			"value_max": 255,
                                			"value_min": 0
                                		"options": [{
                                			"access": 2,
                                			"type": "numeric"
                                			"access": 2,
                                			"type": "numeric"
                                			"access": 2,
                                			"type": "numeric"
                                	"endpoints": {
                                		"1": {
                                			"bindings": [{
                                				"target": {
                                					"endpoint": 1,
                                					"type": "endpoint"
                                				"target": {
                                					"endpoint": 1,
                                					"type": "endpoint"
                                				"target": {
                                					"endpoint": 1,
                                					"type": "endpoint"
                                				"target": {
                                					"endpoint": 1,
                                					"type": "endpoint"
                                			"clusters": {
                                			"scenes": []
                                		"2": {
                                			"bindings": [{
                                				"target": {
                                					"endpoint": 1,
                                					"type": "endpoint"
                                			"clusters": {
                                				"output": []
                                			"scenes": []
                                		"242": {
                                			"bindings": [],
                                			"clusters": {
                                				"input": [],
                                			"scenes": []
                                	"supported": true,
                                	"type": "Router"
                                state
                                  "current_left": 0,
                                  "energy": 0,
                                  "linkquality": 252,
                                  "power_left": 0,
                                  "voltage_left": 245
                                Don't know how it missed this, given that the very first action in the MQTT module on receiving a message is...
                                  if message then
                                    pname = message.packet_name
                                    _debug (pname, ' ', tostring(client))
                                ...but there you go.
                                Not a fundamental issue – the Shelly, Tasmota, and ZWay bridges do this regularly. The up / down / sideways / ... states may be more of a challenge, in general.
                                The payload example you show is curiously asymmetric? (ie. some obvious values missing from the other switch.)
                                    if message then
                                  Yes - current/power/energy is as consumed by the addition of both outlets. Should be something like this but isn't:
                                    "current_total": 0,
                                    "energy_total": 0,
                                    "linkquality": 252,
                                    "power_total": 0,
                                    "voltage": 245
                                      if message then
                                    @akbooer
                                    I thought the MQTT messages would show up by setting this flag in the startup - which I have:
                                        local attr = luup.attr_set
                                        attr("openLuup.MQTT.DEBUG", true)
                                    but the console ABOUT page shows:
                                    DEBUG 	false
                                    Assume there are more than two flags in use? Checked the documentation but the only mention of a debug flag was for smttp.ABOUT.DEBUG How do set the other one?
                                      #73
                                      You can set the debug flag in startup or Lua Test with:
                                      local mqtt = require "openLuup.mqtt"
                                      mqtt.ABOUT.DEBUG = true
                                        163.6k
