  4. Sanity check on rule: using the sun as a condition for Group reactions
4 Posts 3 Posters 852 Views 3 Watching
    Goal: When in away mode I would like the blinds to shift from tilted to closed if I happen to still be out at the point sunset passes.
    The reason this is an ask for sanity check is I'm trying to use Groups in my Reaction.
    So I'm triggering on mode = away but also trying to see if I can trigger on the sun...
    ...to trigger my Reaction groups:
    12942c1e-8a10-4e82-b83c-c4458956098b-image.png 2f50d16b-b3aa-49d8-a8ac-d48a78b9f4b9-image.png
    In MY mind this reads as "mode must be away and the sun is between sunrise > sunset use the first group Reaction or sunset > sunrise and if that happens whilst in away then use the second group Reaction.
    Worst case I'm already sipping eggnog and can just split it apart into two rules but I wanted to see if this would work and make it all self-containable.
    And about eggnog. What is nog, exactly...? Until I know for certain, I'm not drinking the stuff.
    *Hubitat C-7 2.5.1.142
    Core 2026.7.4
    MSR: latest-26193-8dd8f854
      The 'can I fool the sun' condition group is basically useless in this scenario. You have two conditions, one being between sunrise and sunset and the other being between sunset and sunrise. At any time of day one of those conditions will be true so there's no real need to have it there.
      If I am following correctly you want your blinds to close either if you are away or if the sunsets? If that's the case in your triggers you want to make it an OR group and in there one trigger should be the away trigger and the other trigger should be between sunset and sunrise.
      In the actions settings you just wanna have the blinds close and in the reaction if so pleased you can have them open but I assume you don't want them to auto open.
        @Pabla Maybe explaining in this way will help:
        Daytime, blinds open. I leave, house flips to away and the blinds tilt to 20% open. If I come back, no problem, they open again. Easy.
        BUT.
        What if I'm away for the bulk of the day and the sun sets and now it's after dark?
        My usual evening mode has the blinds closing and I'd like that to happen here.
        So:
        • away during the day, blinds tilt to 20% open
          away continuing uninterrupted after sunset, blinds should close like they would if I were home in evening mode
        My sunrise/sunset OR is simply to act as the Condition noting the sun has "changed".
        Core 2026.7.4
          BUT.
          So:
          @gwp1 said in Sanity check on rule: using the sun as a condition for Group reactions:
          Yeah... doesn't work that way. between sunrise and sunset is true during the configured period, so the parent OR group is true. When sunset arrives, the first condition goes false but the second condition goes true in the same evaluation/instant, so the group remains true because both conditions were never false at the same instant, you just traded one for the other. There is no "dead period" between the two conditions, one changes to the other instantly, so the OR group never changes state (remains true forever with the conditions given).
          There are many choices to get to what you want. I'm going to leave it to your creativity to imagine/solve. Hint: you can do it without changing the structure of this rule or its conditions and reactions, just by choosing condition options carefully in the right places.
            135.7k
