  3. iPhone Locator error
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
34 Posts 2 Posters 13.2k Views 2 Watching
    Same errors, yes.
    Google version works properly in that I can access the settings etc.
    But 'Google returned an error' with regards to location. Not sure why that is, but I'm guessing it's the API key being wrong...
      Given the fact that I run the Here version just fine on openLuup and that I made no changes to these functions, this is getting really weird.
      Are you trying to access the settings from UI7 or from ALTUI?
      If from ALTUI, maybe go look at the ALTUI device and under settings/config field and find the sections calling out IPhoneLocator.
      I suspect there is something going on there which got modified.
      I am also wondering if the file gets compressed and/or placed in the wrong location and can't be found when you upload it from the UI on the new vera firmware being part of the problem.
        Cheers
        I've tried with both UI7 and AltUI
        UI7 gives the short error.
        AltUI gives the longer version
        I'm only running on 7.29
        Worth SCPing the files into the location as opposed to using the UI?
          Yeah I would try first to see what the dates are on the current files and make sure that they are indeed in the right folder: /etc/cmh. Sorry I don't have a vera to test this anymore.
          PS: Don't you love this auto update "feature"...
            Oh yes! 😄
              If you want, we can brute force our way through this by merging the two user-data.json from before the update (backup) with your current one. I have done this in the past... I can walk you through it if you want. Not much risk if you have a backup although it is very error prone and might get you very frustrated...
                -rw-r--r-- 1 root root 67935 Jun 9 22:16 L_IPhone.lua
                -rw-r--r-- 1 root root 26729 Jun 9 21:45 L_IPhone.lua.lzo
                -rw-r--r-- 1 root root 43216 Jun 9 22:16 J_IPhone.js
                -rw-r--r-- 1 root root 17241 Jun 9 21:45 J_IPhone.js.lzo
                I've reloaded Luup
                Using UI7 I get
                Error executing function iphone_Settings(): on the settings tab
                Error executing function iphone_Map(): on the Map tab.
                Although the address location is correct
                In AltUI settings tab:
                an error occurred while displaying the javascript tab. devid: 0-246 err:iphone_Settings is not defined
                stack:ReferenceError: iphone_Settings is not defined
                at eval (eval at _deviceDrawControlPanelJSTab (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3022:17), :1:1)
                at _deviceDrawControlPanelOneTabContent (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3717:8)
                at _displayActiveDeviceTab (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3744:4)
                at HTMLAnchorElement. (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:7036:4)
                at HTMLDivElement.dispatch (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:42571)
                at HTMLDivElement.v.handle (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:40572)
                at Object.trigger (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:70627)
                at HTMLAnchorElement. (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:71222)
                at Function.each (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:2777)
                And in Map tab
                an error occurred while displaying the javascript tab. devid: 0-246 err:iphone_Map is not defined
                stack:ReferenceError: iphone_Map is not defined
                That would be cool, but late for me now. I'll get a backup tomorrow and perhaps we can try then?
                As ever, appreciate your help!
                  I've reloaded Luup
                  Using UI7 I get
                  And in Map tab
                  @CatmanV2
                  Re-reading all the error, it all points to failure to read the js file and I don't know why. I have not changed this file in months until today.
                  In the ALTUI config you should see this:
                  "urn:schemas-upnp-org:device:IPhoneLocator:1": {
                    "StyleFunc": "ALTUI_IPhoneLocator.getStyle",
                    "DeviceDrawFunc": "ALTUI_IPhoneLocator.drawIPhone",
                    "ScriptFile": "J_ALTUI_iphone.js",
                    "FavoriteFunc": "ALTUI_IPhoneLocator.drawIPhoneFavorite"
                  which should not lead to your errors.
                  The JS file is called out by the D_IPhone.json file which also has not changed in years:
                  		"Label": {
                  			"lang_tag": "map",
                  			"text": "Map"
                  		"Position": "1",
                  		"TabType": "javascript",
                  		"ScriptName": "J_IPhone.js",
                  		"Function": "iphone_Map"
                  		"Label": {
                  			"lang_tag": "settings",
                  			"text": "Settings"
                  		"Position": "1",
                  		"Function": "iphone_Settings"
                    @CatmanV2
                    I just found out that I am not running the version posted on GitHub and I likely made some changes which I had not updated. I just reuploaded. Can you try it out?
                      Looking much better, sir. Thanks!
                      <dashes off to untick 'Auto Update'>
                        You may have noticed a change of icons on the map. I made a conscious decision to eliminate calls to Google... Sorry for the goof up. I must have uploaded a test file by mistake.
                          @rafale77 I did. and please don't apologise! It's all sorted. As ever I appreciate your help
                            163.6k
