  3. Vera/openLuup plugins
  4. Netatmo – Oath2 login
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
B
B
Broadlink setup
Virtual Sensor Polling
B
Z
Scheduled Pinned Locked Moved Solved Vera/openLuup plugins
35 Posts 6 Posters 18.5k Views 6 Watching
    mrFarmer
    What I did is make a trace in my browser and login, then save as har file to look back at. Sometimes it helped me to make a python script first so I do not have to worry about the session handling, and then add that to the Lua logic. Not simple to do for sure.
      mrFarmer
      wrote on last edited by mrFarmer
      Hi Ak,
      I put in a workaround. You can get the access and refresh tokens from dev.netatmo.com. I put the access token in as Username and refresh token as Password. In your Netatmo.lua I changed the authenticate function to just return those values (no request to the Netatmo api site). This gets the plugin going again. I also updated the refresh_tokens to update the Username and Password values with the new token values. I expect that will get one through a Luup reload. Bit quick and dirty, but if your interested I can do a github merge request or get you the changes otherwise.
        Oh wow, that’s a great suggestion. I haven’t had the old system fail yet (although I haven’t restarted for a few weeks.)
        I can make those changes, or something similar. So when necessary, you just go to their website and generate a short-lived token. Seems an easy option. Let me give that a go. Season’s Greetings!
          By all means, please do suggest the change through GitHub so that your contribution is documented, even though I might not implement it in quite the same way.
            mrFarmer
            Created a pull request.
              #24
              Appropriately enough for this time of year, I've had an epiphany regarding Oath2 in general. Thanks, in large part, to @mrFarmer 's intervention above.
              Following that approach, you don't, in fact, need to retain both the access and refresh tokens between restarts, just the refresh one will suffice, since you only need that to retrieve a new access token. I have a further modification which now implements this.
              This has given me an incentive to dig further into the full Oath2 procedure, and I now realize that it's not necessary for the user to create their own app with client_id and client_secret. Instead, using the authorization code grant type, you can and should use one created by the developer (me, in this case.) It only requires you to allow the plugin access via the Netatmo site.
              I have most of the workflow now going, no thanks to at least one error in the Netatmo documentation for the topic. I can direct the user to the Netatmo login to allow the app access, and I can retrieve a return code via the redirected URI. Where I currently fail, though, is in using that code to get an initial set of access and refresh codes. This should be the easy bit! Having got them, the refresh cycle is exactly as before.
              I suspect another documentation error, but I will continue to try to get this working. The whole Oath2 workflow is, indeed, quite elegant, once the nitty gritty problems of actually implementing it can be overcome.
              Hopefully more later... (but probably not in the next few days.)
              Happy New Year everyone.
              AK
                Problem solved. Required reading the very fine print on the official Oath2 documentation and between the lines on the Netatmo ones!
                No need for individuals to create their own app definitions on the Netatmo developer website, all works very smoothly requiring just an initial authorization and luup restart. Thereafter it survives reloads, etc.
                Will post a new version in the next couple of days.
                • akbooerA akbooer marked this topic as a question on
                  #26
                  Latest master version (v23.1.6) available from AltAppStore, resolves this issue.
                  • no need for you to create your own App credentials on the dev.netatmo.com site
                  • one-off authorization via the Netatmo website to access your own weather station
                  • no user credentials stored in the app
                  After installing this update, the above one-off authorization is required. You can access this via the Authorize button on either the AltUI device page or the openLuup console device page. You are redirected to the Netatmo site to login and approve the request. After successful acknowledgement, you should restart openLuup.
                  A number of previously-existing device variables (all in the Netatmo1 service) will be marked with the value 'nil'. These may be manually deleted:
                  • ClientID
                  • ClientSecret
                  • Username
                  • Password
                  • TokenRefresh
                  • AppMemoryUsed
                  Thanks once again to @mrFarmer whose interim solution gave me the impetus to revisit and finally resolve this issue.
                  Also, please note that the latest master version of openLuup is recommended.
                  M 1 Reply Last reply
                  • akbooerA akbooer has marked this topic as solved on
                    • ClientID
                    • ClientSecret
                    • Username
                    • Password
                    • TokenRefresh
                    • AppMemoryUsed
                    Maipensato
                    @akbooer Does this update also work for Vera controllers without using openluup or Altui?
                      In theory, yes. The current version, no.
                      However, anticipating this, I have fired up my one remaining Vera to test things out. I had forgotten what a dreadful platform it is to try and do development on.
                      I would be interested to know if there are any others here interested in getting this working on Vera.
                        @akbooer thanks, but I’ve moved almost fully to Hubitat, Vera still running Sonos & Visonic alarm. Btw, Sonos plugin for MSR would be great!
                          Off topic but there is a mqtt server for sonos. I had wondered if that would be of any use.
                          • A a-lurker
                            @a-lurker said in Netatmo – Oath2 login:
                            It would be easy to support via custom mqtt templates. I’m doing the same for SwitchBot. MQTT payloads seems easy to implement.
                              @akbooer said in Netatmo – Oath2 login:
                              Having recently looked at their documentation, I see that this username/password authorization is now simply flagged as deprecated.
                              AFAIK, there is no set date for it actually being disabled, so current Vera users should be fine for the time being.
                                @Maipensato
                                The latest master version (v23.1.8) now works on Vera too.
                                Available from the AltAppStore (or GitHub.)
                                  Just received a further developer update from Netatmo regarding authentication changes.
                                  Happy to say that the latest Netatmo plugin code in the AltApp Store is already compliant, so no changes needed.
                                  (This is just in case anyone still uses this plugin... I do!)
                                    mrFarmer
                                    So do I 🙂
                                      158.7k
